Previous in Forum: Want to increase the speed of our electric go-cart   Next in Forum: is it essential to charge for eight hoursnokia mobile while it purchase?
Hot vs. Cold
06/18/2007 11:57 AM
How come there's no radiation to make things cold like there is to make things hot?
Pathfinder Tags: radiation
Good Answers: 247
#119
In reply to #117
Find in discussion
Re: Hot vs. Cold
06/28/2007 10:17 AM
On the contrary... it finally getting somewhere!
Good Answers: 50
#121
In reply to #117
Find in discussion
Re: Hot vs. Cold
06/28/2007 4:21 PM
Wait! I think I just got it... Peter Gabriel -> lead singer of Genesis -> the first book of the Bible! Woof!!! That's a stretch
In reply to #121
Re: Hot vs. Cold
06/28/2007 11:11 PM
How do you say 'well duhh' in Russian ?
Good Answers: 247
#120
In reply to #116
Find in discussion
Re: Hot vs. Cold
06/28/2007 10:33 AM
I believe our dyslexic friend Gwen meant to write: "No dog is female." I assume this would be in reaction to 1.) the negative connotations associated with the word "bitch" and 2.) the generally demeaning and limiting nature of gender labeling. I take Gwen's post as a hopeful and joyous cry: "Let every dog (and by extension every sentient being) be all that it can be!"
Good Answers: 50
#123
In reply to #120
Re: Hot vs. Cold
06/28/2007 7:30 PM
Wha?! Who?! Somebody actually used the "B" word in association to Gwen?!
In reply to #123
Re: Hot vs. Cold
06/28/2007 7:59 PM
Uh-uh. I got it Ken. And I concur.
B here, is not Gwen.
You don't even have to be dyslectic to see the obvious:
What's on everybody's mind, and keeps dropping the ball for some forty-thousand years?
A bitch.
Good Answers: 247
#118
In reply to #95
Find in discussion
Re: Hot vs. Cold
06/28/2007 10:08 AM
... and named for a trumpet player, and an anatomical part, I assume.
Good Answers: 247
#122
In reply to #91
Find in discussion
Re: Hot vs. Cold
06/28/2007 6:58 PM
How peculiar. I proposed a couple answers, just slightly off-color, and they apparently were deleted. Oh well, no great loss.
In reply to #74
Find in discussion
Re: Hot vs. Cold
06/22/2007 3:41 AM
It makes Peter Gabriel a bit nicer.
In reply to #74
Find in discussion
Re: Hot vs. Cold
06/22/2007 5:51 AM
Most science isn't written in the first person either. Dali didn't use 'I' much either. Leicester sounds confusing too.
Good Answers: 50
#110
In reply to #78
Re: Hot vs. Cold
06/27/2007 11:51 PM
But Dali did used the word "syphilitic" often when describing most people.
In reply to #110
Re: Hot vs. Cold
06/28/2007 1:57 AM
Didn't know that . He was kind of strung out though. He did some stunning 'realist' stuff which doesn't seem to get shown much. Those ants make me squirm whatever the interpretation.
Re: Hot vs. Cold
06/19/2007 11:20 AM
Google "Peltier Junction" for more information on electronic cooling.
Re: Hot vs. Cold
06/19/2007 1:49 PM
Isn't radiation just transfer of energy ? Outgoing radiation leaves cold ,and incoming radiation gives heat. I don't know , I must have recieved too much anti-relaxation today because I'm tired.
Re: Hot vs. Cold
06/19/2007 2:27 PM
"How come there's no radiation to make things cold like there is to make things hot?"
Our "Guest" is, I think, pulling our collective leg. Tell him to pull the other one!
Thermal energy allways flows from regions of higher to regions of lower temperature when left to fend for itself. It requires some mechanism such as a heat pump or refigerator to move thermal energy from a region of lower to a region of higher temperature.
See Thermodynamics 101.
Re: Hot vs. Cold
06/20/2007 4:04 AM
In fact there is a way to radiate your object cold: make sure that no radiation from other objects can get to the object and absorb the radiation that comes off.
This is how cooling in space works: keep your cooler away from the sun.
There are even Stirling engines build on the incoming radiation from the sun and the outgoing radiation of the cooler. (which needs to be much bigger)
As explained by the oldies in here: cold is the absence of heat.
Good Answers: 50
Re: Hot vs. Cold
06/20/2007 11:38 PM
In most American cities, coldness can also be caused by the absence of rent.
Re: Hot vs. Cold
06/20/2007 11:49 PM
duct tape and polyimide tape (kapton) are 2
very different things
Re: Hot vs. Cold
06/20/2007 11:57 PM
Just for posterity , here is vermins current quote-line ;
"__________________
In space, your duct tape doesn't work... " Ha-ha. Hang on , people may think I made this up .
Re: Hot vs. Cold
06/22/2007 1:25 PM
There really is a COLD beam. The hardware is "Right Chere" and this is the splaniation fot it.
http://en.wikipedia.org/wiki/Spallation
http://www.physics.princeton.edu/mumu/johnson/p-i-exam/pbartarg.htm
It is a beam that takes a higher level of energy and brings it down a notch ot two.
The "Gee Wiz" stuff does exist ya just gotta know who is playing with it.
Popular Science - Weaponology - New Member Engineering Fields - Aerospace Engineering - New Member Hobbies - Model Rocketry - New Member United States - Member - New Member
#100
Re: Hot vs. Cold
06/25/2007 5:04 PM
I didn't read through all the responses after several off topic ones, so I might have missed actual answers, so sorry if this is a repeat, but...
As far as the original question - the best way to start thinking about thermodynamics is to get rid of the hot and cold idea... there is no such thing as cold, only heat and lack of heat, or, more accurately, how much heat. Thermal energy flows 'downhill' from areas where there is a relatively high temperature to areas with a lower temperature. To make something 'cold' you have to remove heat, which requires the use of some energy and some process, like pumping water uphill.
On duct tape in space - I haven't taken the time to actually look up what the adhesive and backing are specifically, but the cotton is OK as long as it's dry so it won't freeze solid. The adhesive will boil when exposed to vacuum (partial pressure deal) and become something along the lines of asphalt (look up outgassing if you want). Same thing with oil based lubricants. The adhesive also becomes less effective (stiff) as temperature drops, but the vacuum is the main reason it won't work. The tape would be a useless lump long before any effect from radiation could be seen. Kapton tape with acrylic adhesive is basically the duct tape of space.
Good Answers: 50
#103
In reply to #100
Re: Hot vs. Cold
06/25/2007 11:56 PM
Bravo!!!
But the coldness of the sitation that I have absorbed has rendered my congitative thought prossess in a state of coldish fulidity, which robes me of my intuitive congunctiveness.
Oh, no! Here it come again! Duck!!!
Flogistan! Flogistan! My kingdom for some flogistan!!!
In reply to #103
Re: Hot vs. Cold
06/26/2007 1:37 AM
I bet you never looked for the Gecko Tape thread I alluded to, did you. Being a bit of a Threadworm I know these things !
Good Answers: 50
#105
In reply to #104
Re: Hot vs. Cold
06/27/2007 1:04 AM
I didn't have to look for gecko tape. I used to live with several of them. Dang! Do they like crickets or what?!
In reply to #105
Re: Hot vs. Cold
06/27/2007 1:37 AM
Yeah , those Ducts just haven't got the tongues for it. Silly quacking and trying to fly. Must have done something real bad in a former life.
Reply to Forum Thread Page 2 of 2: « First < Prev 1 2 Last »
1 nut (3); All About M.E. (2); Anonymous Poster (5); bhankiii (2); Blink (4); bmorrow492 (4); Butcher (1); dbdwoods (1); dkwarner (5); dovy (8); DVader1000 (1); Extremist (1); ffej (1); Gwen.Stouthuysen (11); Hendrik (1); Kris (18); ky (3); mgaulin (1); ozzb (1); Silas Marner (1); SmithsEng (3); Stirling Stan (2); syhprum (1); user-deleted-1105 (5); vermin (28); Yuval (12)
