Previous in Forum: Information on Cambi - THP Process   Next in Forum: Engine Parts Remanufacturing
17 comments
Velocity from 8m³ Tank
05/30/2014 5:01 AM
Please help me.
My domestic water tank is 2m x 2m x 2m = 8m³ volume. If I pierce a hole to the bottom of tank with F100mm, 0.1m, get the pressures is 2000kg/m², 0.196bar.
I want to know the velocity from this F0.1m hole.
Best regards
User-tagged by 1 user
Re: velocity from 8m³ tank
05/30/2014 5:34 AM
The answer may be obtained by looking at typical discharge co-efficients for the hole, which may be found in such publications as Perry, "The Chemical Engineer's Handbook", and Welty, Wicks & Wilson, "Fundamentals of Heat, Mass and Momentum Transfer". Clearly, at the beginning of the operation the velocity will be at its maximum and as the level in the tank falls, so will the velocity. Velocity will be affected by temperature, as temperature affects viscosity, which will in turn affect the flow through the hole. Other factors include the shape of the hole, the profile of the piercing, the length of any spout projecting from it and the distance the resulting jet has to travel before impacting any surface; the inclination of the surface to the direction of the jet will also have a weak effect.
At a guess the tank will be practically empty within 2 minutes. One hopes that the local drainage arrangements are sufficient to prevent damage or loss to the building, its contents and the occupants when this occurs.
05/30/2014 11:02 PM
Don't forget the pressure head!
Lehman57
05/30/2014 7:30 AM
You'll have to know what you coefficient is, also what type of penetration.
there is basic software for this called Engineering Power Tools. It uses imperial units, but still does the job, the software predetermines the coeffiencent.
Keep in mind your water column also changes.....
Anonymous Poster #2
05/30/2014 7:45 AM
You want to know, or does your teacher want to know if you have absorbed enough knowledge from previous discussions to calculate? From MANY of the posts in the various areas of CR4, it seems many people have graduated, and gotten jobs where they are making decisions that they have no knowledge or experience to make. This is a sad state. No wonder China's development is accelerating. At what point are you measuring the velocity?
Re: Velocity from 8m³ Tank
05/30/2014 11:25 AM
Full to zero. Take the average.
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
06/02/2014 7:27 AM
CR4 ADMIN: Deleted Post
Abuse/Attack: This post was deleted because it was an attack on another user. Please review the CR4 Site FAQ and the CR4 Rules of Conduct.
Dirt is for vegetables. Pavement is for racing.
05/30/2014 11:13 PM
Homework at home
devitg
Anonymous Poster #3
05/31/2014 12:21 AM
I'm a plumber, have fixed hundreds of tanks and respective pipelines. Pressure, yes, I know, though not by values but by feel. But, velocity, yes, heard of this during schooling, and what is that ?
05/31/2014 5:50 AM
is this hole at the true bottom,? so it is horizontal
Or it is at the lowest part of the tank´s wall?
It is a circle 100 mm diameter , or a 100 mm side square?
devitg
06/01/2014 11:58 PM
Yes friend
hole is 100Diameter, from horizontal area of bottom of tank.
Best regards
05/31/2014 1:29 PM
Dear Friend,
The Pressure and Velocity is linked by the equation V^2 = 2 x g x H or V = Sq.Rt of 2 x g x H where V is the THEORITICAL VELOCITY of the Water, g is the acceleration due to gravity, H is the Head of water.
We have to multiply the Theoritical Velocity by a factor called Cv which is 0.8 for water - Refer any standard Hydraulic s Book.
The Pressure given by you is 2000 Kg/M^2 which is equal to 0.2 Metre, of water column.
The theoritical velocity will work out to 14 Metres, by using the above equation and multiplying this theoritical velocity by Cv i.e. 0.8, the Actual Velocity will be 14 x 0.8 = 11.2 Metres/Sec.
The hole size has nothing to do with the velocity but for discharge calculation hole size is required.
DHAYANANDHAN.S
06/01/2014 5:19 AM
At a pressure of 2000 kgf/m2 , equivalent to 0.2 kgf/cm2 which is related to 2m of head. Not 0.20m. In which case the final velocity is about 5m/sec .
Tq.
06/01/2014 7:07 AM
Dear Mr. Satish Menon,
You are absolutely right. Pressure of 2000 Kg/m^2 is equal to 0.2 Kg/cm^2 is equivalent to 2.15 Metres of Water Column.
It is a mistake on my part, and for this 2.15 Metre Head of water will give a theoritical velocity of Sq.Rt of 2 x9.81 x 2.15 = Sq.Rt of 42.183 = 6.494 and After Cv correction it will be 5.19 M/Sec.
Thanks for your correction. To other CR4 Members, the error is regretted.
DHAYANANDHAN.S
06/01/2014 8:22 AM
Its oke, sir. We at times do make these errors with decimals. But your input on equating PE = KE was absolutely correct and a good basic method of deriving the velocity. That is good input to the forum, especially to the younger engineers.
06/02/2014 12:39 AM
Dear Mr dhayanandha,
Please can you explain me to this error as amplify? I kindly request because, i am poor to knowledge.
Please let me know, how to get the value of (velocity coefficient of water).
very thank
Best regards
06/01/2014 10:25 AM
Start Here:
http://engineering.wikia.com/wiki/Orifice_equation
06/01/2014 10:52 AM
Whom ever confirm my previous post , no the OP, off course.
Or it is at the lowest part of the tank´s wall? so it is vertical
With out it specification, all previous said by other poster have no value , just guessing
devitg
Reply to Forum Thread 17 comments
Anonymous Poster (2); bullardrr (1); devitg (3); dhayanandhan (2); Lehman57 (1); lyn (1); nt (2); phoenix911 (1); PWSlack (1); Satish Menon (2); unclefastguy (1)
