Previous in Forum: Probable Reasons of Black Smoke in Oil Fired Boiler   Next in Forum: Biodiesel Blend Problems in Duramax
16 comments
Need Help to Reinstall a Basketball Goal
06/19/2014 11:46 AM
My daughter moved her son's basketball goal and is having a problem reinstalling it. The original installation required that concrete be poured into the pipe from the top to bond with that in the hole where the pole was installed. We removed the goal and took off the concrete on the outside with a jackhammer and did not realize the pipe was filled with about 60 inches of concrete inside the 4" diameter steel pole. Is there any way to get this concrete out of the pole so it can be installed again? It was only in the ground about 24" originally and we don't know how deep to put it with the concrete inside so that it will be stable and won't lean or if there is enough height to let us install it deeper and keep the backboard at the correct height. We would like to install it per the original instructions and not buy a new pole ($350) if possible. Thank you for any help.
Good Answers: 918
Re: Need Help to Reinstall a Basketball Goal
06/19/2014 12:06 PM
This problem just proves why God made men. We will get to the beer part later.
I would not worry about the cement inside the pole.
I would get a shovel and dig a hole deeper than the frost line for your area or as deep as you need to bury the pole, whichever is deeper. The hole does not need to be larger than 12 - 18" in diameter. Some people prefer a post hole digger as it makes the job easier.
Now, for youths, the hoop is typically 8 feet above the ground. For the big boys, regulation height is 10 feet. How high you want it is up to you.
After the hole is dug out, lower the pole and support it with lumber or something to keep it vertical. A level should be used to confirm the pipe is truly level.
Mix up a bag of concrete in a wheel barrel and shovel it into the hole around the pipe. You may need a few bags, but your local hardware store or lumber store will have the cement and can tell you how much you need if you tell them how big the hole is.
It will take about 24 hours for the concrete to harden. Just follow the instructions on the bag.
Now it's Miller time.
06/19/2014 12:31 PM
Drill holes into the concrete so you can insert rebar into each hole. Make the holes larger than the rebar, and about 12 inches deep. Fill the holes with concrete, then force the rebar in. Once the concrete is set, install the pole in its new location.
That's the safe way to go.
If you plan to follow Anonymous Hero's suggestion, install the pole into a 8 inch quikrete tube sticking about 24 inches above the ground. That would give you 2 inches of concrete all around the pole.
06/19/2014 12:43 PM
I would take a hammer drill with a 1 1/2" bit and drill into the concrete in the center of the pipe about 1'....insert #10 rebar (or ~4 1/2" pieces)into hole covered in epoxy, hammer it in all the way....Have about 36" protruding from the end of the pipe(4' piece of rebar) ...dig 3' deep by 2' round hole, and fill with concrete....Prop pole in vertical position by whatever means available, and let set....
http://www.harrissupplysolutions.com/10-rebar-10-reinforcement-steel.html
http://www.thomasnet.com/products/rebar-66281700-1.html
06/19/2014 8:44 PM
I don't understand the reason for the rebar. Is part of it to protrude out of the end of the pole and be sunk into the the ground to extend deeper into the earth like a piling? Or is it all driven into the concrete and flush with the end of the pole? In the installation instructions for a replacement pole, cement was put into the bottom of the pole, rebar forced up into the cement, and then a cap placed on the end of the pole before placing the pole into the hole on bricks before filling the hole with concrete. This made us think that using the pole with the concrete already in it was just this step already done so I think we will just put it in without trying to remove the concrete but am puzzled about the reason for the rebar. I do very much appreciate all your help and suggestions!
Good Answers: 918
06/19/2014 8:50 PM
How much of the pole is to be underground?
06/20/2014 11:08 AM
It was originally concreted about 18" in the ground, was extremely stable and withstood strong winds in its location between two houses. The pole is tall enough to let the backboard move up and down to adjust the height so we could probably put it about 2 feet in the ground.
Good Answers: 918
06/20/2014 12:01 PM
That's what I would do. Dig a hole, drop it in, and pour concrete around it. Don't fuss about it.
Your local hardware store will have someone that can help you with the details of what toi buy and how to mix it.
06/20/2014 12:52 PM
I'll second AH's solution as the most direct solution requiring the minumum of equipment and experience.
As engineers, the KISS principle reigns supreme.
Good luck with your quest.
06/19/2014 9:33 PM
Well I was thinking since you had to remount the pole that you could raise it up 2 ft. for increasing basket height now or in the future...The rebar inserted into the pole 1 ft and sealed with epoxy would provide enough support with 3' into the concrete, to make a solid mount....now if you don't want to raise the pole and are happy with the height, then you can just bury the pole in the concrete 2' and be fine....I'm guessing it's a 10' pole, and the extra height might be desirable if not now then some time in the future....If the basket is adjustable height then you could raise the pole and lower the basket to original height as an option, and then have the option of raising it...Regulation height is 10', but junior sets start lower to make it easier for the kids....but at some point you usually want to raise it....
06/20/2014 11:16 AM
Thank you for the drawing! That's what I thought you had in mind but I don't think we need extra height. The goal is made with a pole that is long enough to allow the backboard to be moved to different positions when it is installed 18" or so in the ground. The original installation instructions called for a piece of rebar to be inserted into the bottom end of the pole after filling the bottom 3 feet with concrete. The bar did not extend out of the bottom of the pole into the earth so I was curious as to its purpose.
06/20/2014 1:15 PM
OK you're good to go then....the rebar and concrete in the pole was used to strengthen the base....just a hole, concrete, level and supports....The amount of concrete on the base mount will depend on the size of the kids playing(whether they like to hang and swing on the basket)....
Good Answers: 203
06/19/2014 10:20 PM
Forget the rebar, tubes, the cement inside the post and other miscellaneous stuff. They just make it harder to install and are not necessary. If the pole is 4" diameter dig a hole 12-18 inches in diameter about 3 ft deep if you have the available depth. Do Not clean the sides of the sides of the hole so that they are smooth, leave it rough but firm. A post hole digger is also good.
Put about 6" of 3/4" stone or gravel in the bottom of the hole. Place the pole in the center of the hole. Tape two torpedo levels with the "v" side on the pole at right angle to each other. Put them at eye level. Plumb the pole and brace it with 1x3 wood to stakes in the ground. Mix the concrete mix and put it into the hole. Every 6" tamp the cement to drive out any air. Wait overnight and put the backboard and rim on. The easiest way to adjust the rim to the correct height, 10ft. is to take a length of 1/2" EMT 10'-0" long and use it to measure between the playing surface and the top of the rim. Make sure the rim is level in all directions. This way you have a solid "measuring tape" that is easier to handle. Put the net on and shoot some baskets. Play some "horse" and see whose better on the court.
A long. long, long ago former hobby basketball player.
Good Luck, Old Salt
Good Answers: 109
06/19/2014 11:00 PM
The cement inside the pole and outside from the pole do not come in touch other at the end of the pole. This bond will be reacreated when you stick the pole in wet cement again. Thus there is no need to change anything. I believe the cement inside was there to give the pole more weight on the bottom and also to prevent standing water below the earth line. All this is still given. So dont worry and just dig the new hole and put the pole in at the desired depth.
Done. Have fun!
06/19/2014 11:35 PM
There are good suggestions on this list. I always get the list after almost everyone that is going to respond has done so. Not sure anything I can do about this. Now. If it was mine. I would be concerned about a pole 10' without any supports around it and NOT use Somethig that allows the Concrete to grab onto. Keep in mind this pole is heave mostly at the bottom but still heavy. With the back plate and the pole and a high wind it will NOT come out of the hole but will in time work its way loose if you get too much wind. You also over time get temperature differences that move things around as they get large and small. So I would not go as far as rebar. But if this is steel and you have access to a welder or a pickup to take it to a welding shop and let them weld about 6 bolts Any good quality bolt about 1.2 inch in diameter and about 3 to 5 inches long. Have some of them welded about 5 inches from the bottom and have one going North and one south and east and west etc.. The direction is not the point. But have at least 4 pointing in 4 directions so you get extra material rather than a smooth pipe for the Cement to grab on. The cost to weld this will be very low and will take less than 5 Min to do. I would have the set near the low and and then just add a few more 2 or 3 maybe up a little higher but still below the cement level. Then As has already been stated. Dig the hole. Put in the post and then stabilize and level the pole. I would wait two days or even 3 days before attaching or even touching the thing. Cement does harden in one day in most conditions but it does not reach anywhere near as hard as it is going to get in one day. So a little extra time without any movement makes the thing more stable. As to how much to use of cement. Several folks gave good answers to that. And I do like the idea of putting the pole high enough to go both 8 feet and 10 feet. If the pole is not long enough to go down 3' and if it is weldable and all metal is other than some rare metals I would have while at the weld shop a little more length to the thing. Now You have one more problem to deal with. This thing is also a lightning magnet. You should get a lighnigh ground rod and put it in the hole below the pole. They are not to hard to drive into the ground if the ground is not too hard and if it is it just takes longer. sold with any place that sells grounding rods are hammers that go around the rod and and are used for lots of things like fence posts and grounding rods. They only cost about $30 and can be used for other things around the yard. After driving the rod into the ground just add the clamps that are sold to connect to the grounding rod. Then use the proper wire ( they will have it at the hardware store that has the rod. The cost a $2 or so.) So put one clamp and wire on the rod and run the wire to the pole and attach with some radiator hose clamps hooked together so as to make it fit around the pipe. Make sure to file the area where the wife contacts the pole. Or you can even better put a nut on one of the bolts you weld to the bottom of the pipe i mentioned above. Now this is a very good thing to do. Why. Because in most dirt 3 feet deep and two feet around is not enough contact to handle a good lighting strike. And the other reason to do this is a good grounding rod helps reduce a lighting strike. It allows for the different charges between ground and the air dissipate and makes it less likely to cause a strike as you are dissipating the charge. Keep in mind. A good stoke from lighnign could vaporize the cement. Cement hardens but is full of water for years and decades and that water will turn to super heated steam and blow that cement like a small bomb. Or at least like popcorn. But this will give you the same as the rebar and it will last for as long as you want it too. Also cap the top after a few days with anything you can. Plastic or a coffee can etc.. I would also spray some wd40 down the inside of the pipe before caping it with the coffee can. Have a good time. Jim
06/20/2014 10:02 AM
Or you could cross drill two holes through the pipe & concrete with the hammer drill at two different heights & orientations. Then just insert two long bolts or threaded rods so they extend out both sides of the pipe. Add nuts to secure in place. Then concrete into the new hole as needed. This will keep the pole sufficiently attached to the new concrete and prevent it from ever rotating or coming out.
Good Answers: 203
06/20/2014 1:02 PM
Referring to #7 and several other answers---
It is the grandson's basketball set up, unless he has aspirations of being another Larry Bird or Dr. "J" he wants to shoot baskets and almost anything will do for him.
The kind of dirt it is being placed in really dictates how deep to put the pole. If it was beach sand or a swamp 5 ft would be more appropriate, granite rock 6" would be enough. The concrete's purpose is several fold. It increases the effective diameter of the pole inserted into the ground; weighs down the base so it isn't top heavy; and keeps kids from hanging on it and trying to tip it over.
You have one very important thing in your favor--- It worked before, it will work again.
The plumbing and leveling parts are of concern but overly of concern. If it is not noticeable to the naked eye it isn't of big concern. The reason for using the levels to do this is so you have something that is better than what people recognize so they wont be able to see if something is wrong.
Good Luck, Old Salt
Register to Reply 16 comments
Anonymous Hero (3); Becky0519 (3); Brave Sir Robin (1); IdeaSmith (1); jimmyjoejetter (1); JustCurious (1); old salt (2); SolarEagle (3); Usbport (1)
