Previous in Forum: Connection Details for Ground Fault Condition   Next in Forum: Regarding GD Square
21 comments
Watts to Ampere Hours
06/24/2014 7:13 AM
What is the formula to determine inverter charger watts requirment for a 42VDC battery @ 20.8 AH ?
Pathfinder Tags: P from AH
Re: watts to ampere hours
06/24/2014 7:33 AM
Clue 1: how much energy is there in a 42VDC, 20.8Ah battery?
Clue 2: how long would need to be allowed to charge it?
Clue 3: what is the first divided by the second?
Rhetorical question 1: what on earth gets taught in CGSE Physics classes these days?
Good Answers: 141
06/24/2014 3:27 PM
1. 873.6 Watts
2. (10% to play safe over) 10 hours or longer?
3. 2.01923077 should be perhaps Ohms, for what it serves the purpose in his question?
What can somewhat forget after CGSE classes? I even do not know what CGSE means.
Plenty of room here
Good Answers: 141
06/24/2014 3:31 PM
Sorry
1. 873.6 Watts for 1 hour
1a. 87.36 Watts for 10 hours
1b. 8.736 Watts for 100 hours
theoretical.
Plenty of room here
Good Answers: 266
06/24/2014 7:35 AM
PIE
Good Answers: 122
06/24/2014 8:46 AM
Power (watts) = Volts x Amperes
Good Answers: 203
06/24/2014 12:30 PM
How about an efficiency factor in there also when using an inverter? Maybe yes? Maybe no? Maybe maybe?
Good Luck, Old Salt
06/24/2014 2:09 PM
good call !
Good Answers: 122
07/01/2014 2:35 PM
Definitely a factor to consider if designing and building a charging system from scratch.
If purchasing an already assembled unit with a predetermined efficiency rating the formulae would be accurate to identify the batteries requirements then you would simply match the numbers to the charger/inverter OEM specifications. Yes?
Re: Watts to Ampere Hours
06/24/2014 1:34 PM
Why do you want to know? What will you do with this fundamental knowledge? Why do you not trust your own ability to look things up? Do you know anything about rechargeable battery chemistry? What will you do with a formula that uses symbols you do not understand? Where's Waldo? Why do people expect they can use an answer without comprehension? How many inane questions can there be in one reply?
06/24/2014 2:02 PM
Interesting answer; my Answers are: Becasue I want to size the inverter going to the charger.......I understand a little about chargers but not an expert......How do you know what I understand and don't ? I am sorry if I wasted your time reading my question but I did learn so on my end it was worth it, on yours ? What can I say your probably need to turn on Obrah and chill......
06/24/2014 2:36 PM
A very interesting reply to my series of questions. I'm glad you took it in the jovial manner I meant instead of the mean spirited way I now see it could have been taken.
First, you certainly added something good to my day. I hope that I return the favor.
Battery chemistry is where I believe you should start to eventually answer your questions. The discharge rates, venting, temperature, total energy stored will all effect which type of rechargeable battery you choose. The charge rate and incoming voltage range will help to establish which type of charger you should get to maximize the lifetime of your battery. All of your power sources [battery, solar, wind, power line] should then lead you to an inverter topology.
Oh and a formula [PIE] without any definition of what the variables mean [and with a key symbol missing] is difficult for those who already understand it.
As for Waldo, he found me. He just left my cubicle and work for the day. Yay, the mice can play!
Who or what is Obrah? Does it possibly age in a charred oak barrel?
Good Answers: 203
06/24/2014 2:57 PM
If you are interested in it, I have found and used a good site for basic to intermediate level battery information;
http://batteryuniversity.com/
It is good for what it is but will never make anyone the guru of batteries and battery chemistry. I often use it as a refresher when things can get more confusing than what the memory can keep straight. Won't put you asleep but won't win an academy award.
Try it, it may be of interest.
Good Luck, Old Salt
06/24/2014 4:40 PM
You Sir are a gentlemaqn and a scholar ! many thanks, lee
06/25/2014 3:26 AM
This appears to be a small motor cycle battery or similar, it can run at best a very tiny inverter....tiny, tiny, only good enough to run say a mobile phone charger or similar....and not for very long either....
A 100 watt inverter will take almost 10 amps continuously......such a battery will soon collapse.....discharging for any length of time below 12.6 volts will eventually damage the battery.....
Is that your intention?
I have always planned such things usually more with the final load in mind, not the other way round....
No information about final voltage, frequency / output power needed either....
Lots of inverter styles are either efficient but with a "square" sine wave (not suitable for sensitive electronics), or have a good well formed sine wave but are not efficient...seldom do you see one that achieves both...unless you believe the advertising hype....
Is this a homework question?
06/25/2014 7:21 AM
This is for a small robot used by the Military. I am trying to size the inverter for the charger for the 42.5 VDC @ 20.8 Ampere Hours battery
06/25/2014 10:24 AM
Something is very strange here. An inverter changes DC to some form of AC. A charger does the opposite, with some form of control to avoid overcharging.
Are you charging the robot battery from some other (larger, different voltage) battery?
I suspect a language translation problem here.
06/25/2014 11:27 AM
out in the field AC is not available, therefore usually use the Humvee battery which is DC, then use a DC to DC converter to the actual charger for the robot battery to be charged....I am trying to size the DC to Dc converter.....
thanks
06/25/2014 12:27 PM
OK, now that makes more sense.
The next thing to know is how rapidly you want to charge the battery. The faster you try to charge it, the more power will be required. Unless you have a charger designed for the specific battery chemistry of the robot battery, you are in danger of overcharging and destroying the battery.
If you already have the charger on hand, then it should specify required input power, voltage, waveshape (square wave should be OK for most). Just specify an inverter with a rating 10-50% higher than the input power required by the charger, and you should be good.
06/25/2014 12:29 PM
A typical car battery (12V 40 AH) has about 1.8 million Joules of energy. I have no idea how much your Humvee battery contains but your fully charged robot battery contains about 3.1 million Joules of energy. Before including the energy lost from cabling, step up conversion, battery heating and a plethora of other losses, you cannot fully charge your robot battery with just your Humvee battery. You might be able to use the alternator of your running Humvee to charge these batteries. However, battery chemistry of this robot battery will limit how quickly and efficiently this battery can be safely recharged. Then there's a little uncertainty in the power output of your Humvee alternator.
If charging this robot battery with a Humvee was my engineering task I'd just add a second alternator to the engine with an appropriate output voltage, power and voltage regulator for charging this higher voltage battery.
06/25/2014 12:34 PM
great Idea !
Lee
Good Answers: 203
06/25/2014 1:58 PM
While looking into the second alternator for installation, look at a single alternator to take both the truck and the robot load. It might be not be feasible to locate the extra space for the alternator, belting or wiring
Alternators up to and exceeding 300amps at 12 volts are available readily. I'm sure there are also higher voltage alternators since many trucks and big equipment, especially off-road construction, have 24 and 48 volt systems. Check with a large truck parts outfit or contact high output alternator suppliers/manufacturers.
Try: http://www.elreg.com/high-output-alternators.html
http://www.delcoremy.com/Home.aspx
Good Luck, Old Salt
Register to Reply 21 comments
Andy Germany (1); dkwarner (2); dvmdsc (2); old salt (3); ozzb (1); PWSlack (1); redfred (3); SHOCKHISCAN (2); stinky00 (6)
