Previous in Forum: Transformer Question   Next in Forum: Transformer Synchonization
20 comments
How to Calculate Disel Fuel Consumption
07/10/2014 11:23 AM
Dear All
How can I calculate diesel fuel consumption for a 245 KW gen set?
Good Answers: 104
Re: How to Calculate Disel Fuel Consumption
07/10/2014 11:28 AM
Search this forum - it's been covered infinitum.
07/10/2014 12:45 PM
The result must be in liters per hour!
Then it is fuel volume over time!
Good Answers: 70
07/10/2014 1:09 PM
With a flow meter calibrated for diesel
07/10/2014 1:10 PM
With a clock, a tape measure and a dipstick, of course.
Good moaning!
07/10/2014 1:20 PM
Oh - there is another way. Divide the fuel volume delivered by the interval since the last one, Boss. All you need are the delivery driver's dockets.
Good moaning!
07/10/2014 1:43 PM
Take your bill for the diesel fuel you bought when you filled your tank and divide the bill total (minus tax) by the price per gallon, or liter. This number will be the total gallons you used if it was filled previously.
07/10/2014 3:11 PM
See if the manual gives the fuel consumption rates for various levels of generator loading. You will have to estimate how the load may vary, unless known to be steady.
07/10/2014 3:57 PM
Fill the tank. Weigh gen-set.
Start and run gen-set. Note time run and load.
Do this till the tank is empty.
Calculate usage by using density of fuel.
07/10/2014 11:26 PM
refer manufacturer's literature
pnaban
Good Answers: 42
07/11/2014 12:01 AM
Julius
Good Answers: 203
07/11/2014 12:29 AM
Use a totalizing fuel oil delivery meter. The thing that the driver uses to tell how much he has delivered. Put the meter in the fuel line supplying the fuel from the tank to the engine. Read the start reading on the meter and the start time. Read the end reading of the meter and the finished time. Subtract the end from the start and that is the quantity used. Subtract the start time from the end time and that's the time period.
Fuel used/time period = fuel consumption of volume per KW
Nice thing about this set up is you can also determine the flow at any time by reading the flow meter only .
Good Luck, Old Salt
Reply Score 1 for Off Topic
07/11/2014 1:25 AM
That is easy. get complete details about your question visit here.
http://www.sagmart.com/category/Automobiles/Cars
Reply Off Topic (Score 6)
Good Answers: 27
07/11/2014 8:48 AM
Which one do you need, the actual or the theoretical calculations?
vsar
Re: How to Calculate Diesel Fuel Consumption
07/11/2014 9:15 AM
They probably need the actual calculation from on site usage. They probably think that they want the theoretical calculation but they obviously do not have the background to attempt this useless calculation. To attempt this calculation requires an excellent understanding in Newtonian Physics, mechanical engineering theory, diesel engine design (both theory and the actual engine used), electrical engineering, power distribution, the anticipated electric load and the trivial factors that effect all of these of the weather. As this partial (I'm sure I missed something) list should show there are many variables that will change the theoretical fuel consumption rate. Many of these variables can be minimized once one understands how to properly apply the mathematics of statistics and random process variables.
The simplest and most practical thing they should do is to not calculate anything but to look for the manufacturer's propaganda on fuel consumption rates. This will probably be available at their web site or the operators manual. [RTFM]
Good Answers: 27
07/11/2014 1:48 PM
I concur RedFred. You are correct in your assessment, and that was why I raised the question to the OP. I'm not sure if the OP is aware of the big difference between the two?
vsar
07/11/2014 9:36 AM
Both .
Thanks.
07/11/2014 10:08 AM
If you have the actual, why would you need the THEORATICAL?
Good Answers: 27
07/11/2014 1:56 PM
ebjoe -
Is it of any significant to you to know both? What will you do when you realized that the results are NOT going to be the same no matter what you do?
vsar
Anonymous Poster #2
07/13/2014 3:18 PM
These are the practically measuring systems
If the diesel tank seperate from the diesel generator,arrange a flow meter.
other wise using dipstic system also u can measure the diesel consumption hourly based.
and diesel consumption depends on the load on the DG set means full load DG consumed
diesel more than the DG at 80% laod on the dg set.
08/08/2014 1:31 AM
Fill up 1 litre of fuel in to the generator and see how long it take to run before is run out of fuel again.
Reply to Forum Thread 20 comments
7anoter4 (1); Anonymous Poster (1); bigg (1); Crabtree (2); dj95401 (1); ebijoe (1); IdeaSmith (1); lyn (2); old salt (1); pnaban (1); rakesh1234 (1); redfred (2); Simon Wan (1); Tornado (1); vsar (3)
