Previous in Forum: Conversion of Energy   Next in Forum: Paradox or Not?
20 comments
One Stroke Engine
07/15/2014 10:17 AM
A inventor named bourke invented one stroke engine called bourke engine 30.
Here's about it;
Bourke 30
Built in 1954. This is Russell's first 30 cubic inch, 30+ HP production engine built for public use. The claims made, except for the unusually high rpm's or the workability of extremely high compression ratios, are true based on real world tests. The key to it's much higher efficiency is simply increased time at Top Dead Center 'TDC'.
Back in the 1940's Russell Bourke set out to solve various problems with the conventional engines of that era. During his career as an instructor on internal combustion engines he soon ended up discarding many pre-conceived notions, fixed ideas and incorrectly duplicated theories of how to create the same end result as a steam engine using pressure as the prime mover by converting hydrocarbon based fuels to create pressure against a piston driving it downward in a cylinder and converting it into rotary motion.
The first basic and workable theory was in order to create the needed pressure against a piston, combustion of hydrocarbons and air in an enclosed chamber was mandated! In order to accomplish real work it was theorized that 4 separate cycles. 'INTAKE' of air and fuel, 'COMPRESSION' thereof, spark or pressure ignited expansion of those gasses ' POWER' and finally removal of the spent gasses, 'EXHAUST' was necessary.
Long ago, Dr. Otto came up with the first practical working engine based on this theory which was a 4 stroke type. It completed 4 cycles in a very literal way in that it had an INTAKE stroke, a COMPRESSION stroke, a POWER stroke and finally and EXHAUST stroke. Do you see the literal translation? The 4 Stroke Cycle was born.
The combustion chamber had to be valved in order to enable the cylinder to admit air and fuel and to emit spent gasses and it needed a crankshaft to drive things. There was quite a bit of parasitic power robbing equipment added to accomplish the above complete cycle. Anyway, the first internal combustion piston engine was born and basically it hasn't changed one bit since!
Ever since then we have been basically stuck with the Otto cycle to drive anything that requires a 4 stroke/cycle diesel or gasoline engine. The problem isn't so much in Dr. Otto's interpretation of original theory or Dr. Diesel's decision to stick with what works.
This includes 2 stroke and turbine engines as well. They are although much simpler and able to yield more power per pound of weight, still prone to similar limitations.
Thermodynamically speaking they are flawed relative to their stoichiometric limitations and their complete inability to achieve even a hint of adiabatic efficiency.
Although they do work, none of these engine types are capable of adiabatic operation in that their efficiency is gauged based upon fuel rich stoichiometric ratios.
Regardless of an engine, be it 2 stroke, 4 stroke or turbine type, they are all inefficient stoichiometric engines in that they emit harmful waste products into the atmosphere! They needlessly pollute our world due to an incomplete combustion process with a great deal of lost heat energy that could and should otherwise be put to work!
Regardless of that and to be fair, It remains a fact that conventional engines have worked well for decades and kept the world chugging along faithfully for a long time. But at what cost?
We are all seeing the cost now as Russell Bourke predicted decades ago and tried to help prevent! I don't have to tell you what that is as you wouldn't be reading this now if you didn't know or at least suspect that something can be done about it! Yes, the effect is overall environmental degradation due to improperly and incompletely converted hydrocarbons and other toxic substances and gasses!
The work engineers and chemists have done, their innovations as well as improvements of conventional engines and hydrocarbon fuels of all types are greatly acknowledged and appreciated. From my perspective, engineers are generally extremely bright intelligent people who solve problems and create! The greater majority of them have a passion for helping their fellow inhabitants live better, take care of and preserve our natural resources.
Re: one stroke engine
07/15/2014 10:35 AM
Energy is just another form of wealth, anytime there is a lot of it being spread around, there's bound to be a lot of waste....but after a while, when it becomes well managed, the waste declines to a minimum....I don't see any great wisdom here, just a lot of hard work.... some common sense....and a reasonable amount of time....
07/15/2014 10:35 AM
Around here, it is considered bad form to post content without giving credit.
http://bourke-engine.com/index1.htm
This appears to be a sales pitch... prolly belongs in Commercial section.
07/15/2014 10:47 AM
07/15/2014 10:43 AM
this is a good idea to re-create this in vehicles.
Good Answers: 122
07/15/2014 7:55 PM
The "one stroke" engine already exists.
It is commonly called a rocket engine.
Once it ignites the object it is attached to moves in one direction until the fuel is depleted/spent or until the object makes contact with another mass that alters the direction or dissipates the energy.
Seriously; I would think that a piston driven engine would have to exhaust most of the created gasses and then replenish the fuel-to-air mixture for combustion before it could be capable of creating more rotational energy.
I know I am limited but I cannot see how a piston type combustion engine could efficiently complete the energy conversion in less than two (2) stokes when pre-ignition compression is the only way to extract the stored energy in fuel.
What am I missing?
Re: One Stroke Engine
07/15/2014 11:16 AM
A one stroke engine? If the "piston" makes only one stroke and never returns back, how does it get to the original position in the first place. This sounds more like a breach loaded firearm than an engine.
07/15/2014 12:44 PM
Perhaps an engine with disposable pistons?
07/15/2014 2:00 PM
Bullseye!
Good moaning!
Good Answers: 92
07/15/2014 10:38 PM
You get a GA for a well targeted reply .
ps- forgot to mention it, but those ones come with disposable cylinders too!
07/15/2014 4:40 PM
I found this link showing how the thing works (the Bourke website video links didn't work).
http://fuel-efficient-vehicles.org/energy-news/?page_id=1081
I couldn't find any examples in actual use however or obvious independent tests thou. Patents are expired too (apparently), so not looking so good as in "hey this fantastic claim design is totally free automotive and aeronautical industry to replace your engines".
07/15/2014 4:30 PM
They call those rockets no days.
07/15/2014 4:33 PM
Looks dodgy with claims not borne out by actual witnessed tests.
http://en.wikipedia.org/wiki/Bourke_engine
Likely explains why they are not in common use like so many other alternative internal combustion designs (and there are MANY around). PESWiki has a page on it too (which is not a good sign either).
Good Answers: 50
07/15/2014 8:43 PM
This engine is a two stroke as stated in the link provided by 'Jack of all trades'. They have their place, but if they were an improvement to the conventional design 4 stroke, they would be common place in autos.
rishie, if you think this is an improvement, go and build an auto empire based on this.
ignator -
Good Answers: 122
07/15/2014 10:15 PM
Rishie,
Below is a link to a documented horsepower-to-fuel consumption experiment executed in Nevada in 1979 on the Bourke engine design by Mr. Nielsen and his crew.
FYI: In comparison to a modern high efficeincy engine that has a ratio of 2.0 to 1, the Bourke engine has a ratio of that approaching 1 to 1 which is quite inefficient.
http://www.niquette.com/books/sophmag/bourke.htm
Of course this report/article may be as off center as any other of the countless unsubstantiated opinions floating around on the internet in today's "spin it up" world.
07/16/2014 2:45 AM
A hundred-stroke engine is more enjoyable.
07/16/2014 7:04 AM
See here:-
Bourke 30
07/16/2014 3:56 PM
Hey, that's my post #10 link.
07/16/2014 4:03 PM
You posted first.
Good Answers: 203
07/16/2014 11:04 PM
These are used for machines that only have to go 1/2 a revolution. An example of this would be a ferris wheel for extremely heavy people from the fat farm. People sit in the bottom seat, engine fires, propels the people up to the top and gravity brings them back down. They are also used to power half as$ experiments that won't work. Connect the shafts of two of them together and you have two half as$ motors.
They are also used to power airplanes that are flying full of passengers holding one way tickets.
Good Luck, Old Salt
Good Answers: 183
07/17/2014 7:28 AM
I do not understand why it is called "1 stroke" since it is the most classical 2 strokes engine. The ONLY difference is the transformation from linear to rotational movements.
The linear bearing is quite difficult to lubricate ans sensitive to wear.
Detonation does NOT mean more energy only same energy delivered in a shorter time.
The high speed pressure increase leads to a higher fatigue of used materials.
I do not see a "+" in comparison with classics. I also doubt the higher efficiency since it is known that 2 strokes engines with windows controlled in and outlet have a worse one since it can not be -as valves- adjusted with speed variations= distribution is FIXED and same for all cycles.
Register to Reply 20 comments
Andy Germany (2); Crabtree (1); Doorman (1); ignator (1); jack of all trades (3); JNB (1); lyn (1); nick name (1); old salt (1); r&ddoc (1); redfred (1); rishie (1); SHOCKHISCAN (2); SolarEagle (2); Tornado (1)
