Previous in Forum: DC Motor   Next in Forum: Multiple Cables Per Phase
18 comments
Weight of Cable
07/16/2014 2:02 AM
sir,
How can we calculate the cable weight/meter or yard
for example what will be the weight of one meter of 185 mm2x3.5 core non armoured cable.
please i need detail formula or calculation
thanks
Re: Weight of Cable
07/16/2014 2:26 AM
Easy! Cut 10 cm of the cable and weigh it.
Take the weight and this times 10 is your weight per meter!
Re: Weight of Cable
07/16/2014 4:10 PM
You forgot to mention the cable should not be powered when you cut it.
Given some of the questions asked here on CR4 I wouldn't guarantee this obvious common sense step would naturally be taken.
Re: Weight of Cable
07/16/2014 4:27 PM
Aw, you're no fun. Some people will earn a Darwin Award no matter what we do.
Re: Weight of Cable
07/17/2014 10:11 AM
I never try to think when answering those questions, but I think I thought that while the cable is installed already nobody out of his mind would actually go and try to find out the weight. Unless of course a smart head has seen the cable tray bending and had the bright idea to check the cable weight.
In which case me thinks I was not thinking what OP was thinking, leaving me with a headache now . . .
Thanks for nothing!
Re: Weight of Cable
07/16/2014 2:41 AM
Consult the manufacturer's catalog.
Or, weight = volume x density.
Good Answers: 11
Re: Weight of Cable
07/16/2014 3:05 AM
Quick and dirty with big assumptions:-
Assume copper cable
Ignore weight of insulation
185 * 3.5 * 8.9 /1000 = kg/m
Add 20 to 50% for weight of insulation
Should really be used only as a sanity check - better to check with manufacturer as stated previously.
rogerggbr
Re: Weight of Cable
07/16/2014 5:07 AM
Calculate? Look it up in the cable manufacturer's sales literature! If it isn't there, get on the phone and ask!
Good moaning!
Good Answers: 181
Re: Weight of Cable
07/16/2014 5:13 AM
"please i need detail formula or calculation"
Why, these figures are readily available.
Re: Weight of Cable
07/16/2014 5:58 AM
The quality of today's education systems never ceases to amaze.
Re: Weight of Cable
07/16/2014 6:26 PM
And disappoint!
Re: Weight of Cable
07/16/2014 8:39 AM
The only individuals I can think of that might have a valid need to calculate the weight per unit length of a cable design would be people working at the cable manufacturing/design place. These individuals will have access to all of the relevant data and I would expect the training to produce a valid set of numbers. These numbers would be the average weight per unit, the maximum and minimum weight per unit, along with the critical standard deviation (σ, aka sigma) for proper quality control. Everyone else will refer to these calculations and maybe additionally measure purchased cable to assure that all of the cable meets the claimed quality control.
In other words, if you have to ask, you are not qualified.
Re: Weight of Cable
07/16/2014 11:37 AM
Good Answers: 42
Re: Weight of Cable
07/16/2014 11:48 AM
IMO, you may follow the proceeding of IEC 60502-1[up to 1 kV rated] or IEC 60502-2 [from 6 to 30 kV rated], Annex A (normative) Fictitious calculation method for determination of protective coverings and take an average specific weight for copper 8.96 g/cm^3, 2.7 for aluminum, 7.8 for steel, 1 g/cm^3 for polyethylene and 1.4 for pvc.
Julius
Re: Weight of Cable
07/16/2014 4:16 PM
It's in the cable datasheet. Any formula or calculation offered here is going to be near worthless as you haven't specified what the voltage rating of the cable is and its application. For example high voltage cable insulation weighs more than low voltage cable insulation, heck you haven't even specified if it is copper or aluminium core!
Consult the datasheet. If you cannot find it then find an equivalent cable on the internet and consult its datasheet.
Good Answers: 203
Re: Weight of Cable
07/16/2014 10:23 PM
What type of cable are you working with? Coax with a insulator between the conductor and the mesh? There are different materials for the same type wire. Insulator separated open wire, looks like a ladder. What type and size of NM or other non-armored electrical wire. Quality standards for the fluctuations in size, diameter of conductors, type of insulation, etc. Are all conductors the same size or are they a combination of sizes. Does the wire have a messenger? Are there any line amplifiers in it (such as underwater telephone cables).
If there is a universal formula or calculation for determining the weight, by the time you find one and make the calculations you could have telephoned the manufacturer and gotten the information 20 times. There are some things in this world that are not just worth figuring out on your own. It was probably much easier for you to write this or any other written communications like this on a computer with a word processer software than to use the hunt-peck method on an electric typewriter.
Good Luck, Old Salt
Good Answers: 117
Re: Weight of Cable
07/19/2014 8:23 AM
Ask a re-cycling forum or a scrap dealer. They know! That stuff comes into their shop all the time, usually ripped off from corporate owner who just writes it off as the cost of doing business.
Re: Weight of Cable
01/03/2023 4:15 AM
The manufacturer will have this information, for assessing shipping.
Pick up the phone, and ask.
Re: Weight of Cable
01/03/2023 6:26 AM
7129 kg/km
Reply to Forum Thread 18 comments
7anoter4 (1); Crabtree (1); IdeaSmith (2); jack of all trades (2); lyn (1); old salt (1); PWSlack (2); redfred (2); rogerggbr (1); SolarEagle (2); TonyS (1); Tornado (1); Yusef1 (1)
