Previous in Forum: Voltmeter   Next in Forum: CBCT
Transformer
07/23/2014 6:00 AM
A single -phase transformer is rated at 100 KVA, 5000/250V. The full load copper losses are 1KW. The load KVA for maximum efficiency is?
Re: Transformer
07/23/2014 6:23 AM
...exactly what it says in the question unless the manufacturer says otherwise in the operation manual, the technical datasheet, or over the phone.
Re: Transformer
07/23/2014 9:24 AM
I want you to read very carefully this line from the CR4 FAQ.
  • Do your own homework. CR4 is not a homework cheat site. While some here might relish the opportunity to sharpen up old rusty skills by working the homework problem, consider the following and consider it well. If you cheat on your homework by using someone else's answers, you are only cheating yourself, because the purpose of any homework or other academic assignments is to help you learn - by practice, repetition, and self-discovery.
Location: I live in USA, Colorado in the houses of 7 Summits
Re: Transformer
07/25/2014 3:05 AM
As transformer start working at constant voltage and frequency, its efficiency varies with the load, the efficiency of the transformer becomes maximum at a certain point, and after this point if the transformer again start loading then its efficiency will decreasing.
Re: Transformer
08/01/2014 11:32 AM
Dear Mr.Prajith oc
Your question is "
For a Transformer and DC Motor, the CONDITION for MAXIMUM EFFICIENCY is CONSTANT LOSS should be EQUAL to COPPER LOSS i.e. I^2 x R LOSS.
So, for your Transformer the CONSTANT LOSS (Or CORE LOSS) should be equal to 1 KW. It is not known from your statement - what is the core loss.
DHAYANANDHAN.S
Register to Reply 4 comments
dhayanandhan (1); PWSlack (1); redfred (1); ShawnHoppe (1)
