Previous in Forum: Walking Rocks   Next in Forum: Heat Signature Question
26 comments
Good Answers: 94
Camera & Mirror
08/29/2014 4:39 AM
Having trouble getting my head around this one, I think it works OK but could do with some reassurance.
We add cameras to our detectors frequently & they work fine. One customer wants the camera to one side which means using a 45° mirror. I can see from the sketch below that both sides of the image X & Y travel the same distance to the camera so the camera should see the image as being flat. I keep thinking however that the camera sees the image in the mirror as having the depth of field D. Can you tell me that this is wrong?
Re: Camera & mirror
08/29/2014 7:48 AM
I don't think that has anything to do with what "depth of field" means. The presence of the (flat) mirror changes neither the focal length nor the depth of field.
Good Answers: 94
Re: Camera & mirror
08/29/2014 8:05 AM
That's what I was thinking & have pursued the design in that way but the 'depth of field' issue kept bothering me.
Good Answers: 114
Re: Camera & mirror
08/29/2014 8:13 AM
The only difference that I see is that the image will be a mirror image.
Re: Camera & mirror
08/29/2014 8:19 AM
Then you will have to be careful about saying such things as "the left-handed burglar..."
Good Answers: 94
Re: Camera & mirror
08/29/2014 8:28 AM
Correct & I'm not sure at this stage which way the customer expects to see the image so I've made the camera mounting reversible.
Re: Camera & mirror
08/29/2014 10:29 AM
Most software can easily reverse the image. An easy solution to avoid confusion is to have some obvious non-symmetrical object (e.g. text) in the image field.
Good Answers: 94
Re: Camera & mirror
08/29/2014 10:59 AM
In this case the image will be from random protons & neutrons. The only reason for having the mirror is that the neutrons will probably pass straight through the whole assembly & could damage the CCD sensor.
Re: Camera & Mirror
08/29/2014 9:55 AM
Shouldn't make any difference to zip, except maybe how the camera measures distance to an object to focus? Will it try to focus on the surface of the mirror? My experience with auto focus is it will ficus on anything other than the object you want... they just don't want to focus on a bow limb held up dead centre of frame... instead it focuses on a bloody flowerbed 25' away.
It tickles me that the face recognition will pick up on Sophie's cat face
Good Answers: 94
Re: Camera & Mirror
08/29/2014 10:56 AM
Auto focus is a pain in our applications so we always use manual.
Re: Camera & Mirror
08/29/2014 10:25 AM
I believe we have an error in terminology. The depth of field is not D in your diagram it is the region from the camera that is in focus. The depth of field will change with focusing and the f-stop of your camera lens iris. The blurring of an image outside of the depth of field will be related the the shape of the iris aperture.
In your diagram D is the minimum dimension of the mirror to capture all of the desired reflected image.
Good Answers: 918
Re: Camera & Mirror
08/29/2014 1:06 PM
I gave you a second GA for a good catch and explanation of DOF.
I think he meant focal distance, which his analysis as to the plane or field of focus will be the same as it would for the same distance without the mirror.
Good Answers: 94
Re: Camera & Mirror
08/29/2014 8:07 PM
Depth of field as I understand it is the distance from the nearest object in reasonable focus to the furthest object. I was concerned that the lens would have to focus over distance 'D' in my sketch but I'm convinced now that this is not the case.
Re: Camera & Mirror
08/29/2014 10:40 PM
You will have to use a first surface mirror if you don't want a double image (both surfaces of a conventional mirror will reflect the image, the closest surface will reflect a faint image and the mirror coating on the backside will provide the strongest reflection). but there will be a ghost image present if you don't use a first surface mirror.
If this is an important installation and maintenance would be a problem (first surface mirrors are delicate) you might consider using a prism.
DOF, which is related to the Circle of Confusion in the optics world is what you are going to have to deal with. http://en.wikipedia.org/wiki/Circle_of_confusion for more info.
There was a 'spy' lens on the market that had a 45 degree mirror in the barrel so one could shoot without alerting the target. Might be good enough.
Another way to 'turn the corner' is with a coherent optical fiber bundle. They can be tied in knots and still deliver a good image although the edges of the individual fibers are thin but dark.
You don't say why they want it to one side or why the geometry of the setup wouldn't allow you to just turn the camera 90 degrees.
It was burning when I put it down!
Re: Camera & Mirror
08/29/2014 11:24 PM
Beat me to it. Yes a mirror as used in Newtonian telescopes is required for the reasons you elucidate. A GA from me. A prism from an old reflex camera would work as well. I once used a cover slip ( used for microscope slides ) as a beam splitter to light the object and simultaneously view it. Viewing it at 90deg whilst lighting it perpendicularly. It worked because the glass was so thin.
Jim
Good Answers: 94
Re: Camera & Mirror
08/30/2014 1:52 PM
Yes, I'm using 1st surface, once built the mirror will be sealed & protected. The reason for all this was in post #10, our customer is looking at protons & neutrons. The neutrons have enough energy to pass straight through our detector & would probably damage a CCD sensor in direct line.
Re: Camera & Mirror
08/30/2014 5:21 PM
Then you must be shielding the camera with poly or something similar?
If the Neutron flux is high enough to damage the CCD, then, eventually, it will activate the mirror and surrounding bits and the radiation from the activated components will interfere with proper CCD operation in any event. Or is this a short-term use?
Good Answers: 94
Re: Camera & Mirror
09/01/2014 4:15 AM
The customer will not give us full details, (not unusual) so we don't know the frequency of the neutrons but you are right, long term use will activate other components. It may be that these parts will have to be replaced at some point.
Re: Camera & Mirror
09/01/2014 9:56 AM
One detail you should insist upon, any returns for repair must be first surveyed for radiation activation and contamination at the customer's expense before being shipped anywhere.
Good Answers: 94
Re: Camera & Mirror
09/01/2014 10:43 AM
That's a standard part of our conditions, we don't accept anything back without a contamination statement.
Re: Camera & Mirror
09/01/2014 9:52 PM
HELP! I haven't a clue what you guys are talking about. Protons and neutrons being photographed? They are so small and you worry about depth of field? Please give me a link to your work, or your clients' work so that I can learn something here.
Jim
Re: Camera & Mirror
09/01/2014 10:00 PM
The Protons and Neutrons are actually striking what is known as a phosphor flag. The camera is looking at a reflected image of the flag. The CCD and all of the support electronics is not directly exposed to the particle beam.
Re: Camera & Mirror
09/01/2014 10:10 PM
Phosphor flag? As in the back of a CRT? Or again is this on a first surface?
Thanks for the reply, by the way.
Jim
Re: Camera & Mirror
09/01/2014 10:24 PM
As in the back of a CRT screen, yes. Most of the time the target will be after the flag and frequently the flag is inserted only for trajectory adjustments but I do not know if Nigh's customer will be using it in this fashion.
Good Answers: 94
Re: Camera & Mirror
09/02/2014 11:51 AM
Not quite the same but you have the function right. Most of our devices have input & output optics with the output one having having a coating of phosphor. This particular device has no input optic but will be bolted onto a vacuum chamber of some sort in which the protons & neutrons are generated. The protons will cause the phosphor to scintillate & the CCD camera will read the scintillations. Unfortunately I don't know the function of all this, the customer is a research institute & are not sharing the details of their research with us, some do, some don't.
Re: Camera & Mirror
08/29/2014 11:29 PM
I suspect you should have drawn your expected DOF between x2 and y2. But it doesn't matter anyway as it is O.K.
Jim
Re: Camera & Mirror
08/30/2014 2:10 AM
Depth of field is a function of the camera, the F-stop. The larger the "hole", the shorter the depth of field (less is shown to be in focus). With a smaller hole, the greater the distance shown "in" focus.
As far as I am aware, a normal flat mirror will not change the depth of field.
Having a good light sensitive (years ago "film") camera allows a photographer more leeway with using depth of field to his or her advantage, or not.
An insensitive camera has fewer possibilities, especially when light is low.....
On (older) cameras, there is sometimes a ring to adjust focus and it also shows the depth of field with regard to the aperture chosen....maybe high level cameras of today have it also, I never noticed....
Obviously in a camera, the f.stop and the shutter speed work together to allow a specific "volume" or "amount" of light through, that the film or the photo element need to produce a correctly lit picture....
With video or movies, you have less leeway with timing, sometimes none and the whole exposure is controlled by the f.stop and depth of field is affected by the amount of light or not on the subject.....you are stuck with the timing, so to say....
Here is a reasonable article on the subject:-
Achieve-Depth-of-Field-in-Photography
I feel that its easier to understand the phenomena in still photography first, before applying it to video or movies.....
I hope this helps.
Register to Reply 26 comments
Andy Germany (1); Anonymous Hero (1); JIMRAT (4); mrehmus (2); Nigh (9); passingtongreen (1); redfred (5); Tornado (2); user-deleted-1105 (1)
