Previous in Forum: Husqvarna E-Series 142 Keeps Dying Like the Chain Brake is Engaged   Next in Forum: PF Fired Boiler Fireball Angle Measurement
8 comments
Installation Tube Bundle CEU Heat Exchanger
08/31/2014 1:42 AM
Dear All,
there is a CEU heat exchanger (channel integrated with tubesheet), the total length include tubebundle is 9145 mm. tubebundle itself is 6642 mm length. the weight is about 30 ton. for designing the spreader bar i need to know the maximum length of tubebundle need to be supported to avoid damages. anyone have experienced for this?
Re: Installation tubebundle CEU Heat exchanger
08/31/2014 7:11 AM
A drawing would help, showing particularly the tube diameter and any baffles that may already be present.
08/31/2014 9:30 AM
please find above the dawing, could you please share thel length minimum shall be supported
08/31/2014 2:11 PM
Not here. You need to discuss the lift with the contractor(s) actually doing the job. Get on the phone and arrange a meeting over the drawings of the equipment and the site.
Good moaning!
Good Answers: 122
09/01/2014 10:35 AM
You would be best served to contact the heat exchanger and/or tube sheet manufacturer to get the correct lifting requirements and technique.
Failure to adhere strictly with the factory lifting recomendations will result in damage to the unit and subsequent failure.
09/01/2014 5:09 PM
Thank you all, i am still waiting confirmation from fabricator. Anyone have a photos related this bundle installation or removal?
09/02/2014 3:41 AM
Try the fabricator. After all, it will be available to photograph at all stages during its construction.
Good Answers: 38
Re: Installation Tube Bundle CEU Heat Exchanger
09/03/2014 12:12 PM
The correct bundle lifting method and CG should be noted on the HX bundle drawing.
Do you have any drawings or were they thrown away by the previous plant owner?
Your HX bundle is rather large, heavy and should have internal rails installed inside the shell for support during removal. Do you have these? Are there any drawings?
Some large horizontal HXs are designed for bundle removal by a specific device
https://www.youtube.com/watch?v=jKMsJmrfSMw
I believe that the use of a spreader beam could be a mistake
Please complete this thread.....let us know of your final decision
09/27/2014 11:17 AM
OP needs to listen carefully to all other posters, especially those like Crabtree who recommended a serious tailgate meeting to plan the install lift. All of the site details will be pertinent. MJCronin also offers up sage wisdom here.
Register to Reply 8 comments
alfonsus_wm (2); Crabtree (1); James Stewart (1); MJCronin (1); PWSlack (1); SHOCKHISCAN (1); Tornado (1)
