Previous in Forum: Which Is Good Centrifugal Or Piston Pump   Next in Forum: Gearbox & Shaft Mounting Position
13 comments
Tube Expansion
09/18/2014 9:42 PM
I want to know the tube expansion tool selection and setting.
I know for normal reduction in wall thickness and what whould be the final tube dia.
from,
((dl-d)-c)*100/2T
d= id
dl=id after rolling
D= hole dia
do=tube OD
c=tube clearence with hole
T=wall thickness
But I dont know how to set these values in a machine. or how to give the torque value?
Pathfinder Tags: Tube Expansion
Re: TUBE EXPANSION
09/18/2014 10:02 PM
No one can help you.
You give no useful information.
Read the machine manual. You do have a manual, correct. And a real machine to use.
If yes, give the details.
We can't read your mind.
Good Answers: 203
Re: TUBE EXPANSION
09/18/2014 10:12 PM
The answer is PIE ARE SQUARED!
Good Luck, Old Salt
Good Answers: 26
Re: TUBE EXPANSION
09/19/2014 8:29 AM
NO NO! Pie are round, cake are square.
Good Answers: 109
Re: TUBE EXPANSION
09/18/2014 10:30 PM
What machine is it and where is the torque coming from???
Re: TUBE EXPANSION
09/19/2014 3:20 AM
All you are trying to achieve is no leaks at the test pressure. I'd leave it to those practised in this art.
Good moaning!
Re: TUBE EXPANSION
09/19/2014 4:01 AM
I aasume, you are a mekkanical designer. Better quit designer job today itself and find a job in production dept. or QA/QC Dept. to see what is happening in real manufacturing world.
Good Answers: 109
Re: TUBE EXPANSION
09/19/2014 4:03 AM
Clearly you have to give us more context.
Asking for setting values on a machine that we dont know what it is (other than it seems to be a tube expansion machine) is like asking for the torque rating of the engine from a car.
Which car you might ask. Exactly which machine is it?
Can you give me the tyre pressure settings for the above car please?
Where is the torque coming into play when a pipe expansion should be achieved by pull force for an expansion cone.
What settings are needed?
Re: TUBE EXPANSION
09/19/2014 4:22 AM
Tube rolling (expansion) into tubesheets is a specialty that depends on specific design of the chosen method, including grooves (if any), hole roughness (if relied on), sealing elements such as O-rings (if any), material compressibility, return flanges on tube ends, etc.
These elements can be calculated from first principles, but I think it is more usual to follow advice from rolling-tool vendors. RTFM, for one thing, but be prepared to understand the principles involved.
The OP is asking decent questions, but so far it seems that none of the repliers has experience with tube rolling.
Re: TUBE EXPANSION
09/19/2014 5:21 AM
This may be useful
Re: TUBE EXPANSION
09/19/2014 5:48 AM
That might be useful, but only if readable.
Re: TUBE EXPANSION
09/19/2014 12:01 PM
It won't matter to the OP.
Re: Tube Expansion
09/19/2014 12:18 PM
Dear Mr.libin babu,
Tube Expansion - You have lot more details in the following links. Pl. open the link and you will find answer for your doubts.
https://www.google.co.in/?gfe_rd=cr&ei=pw4EVLSGC8aFoAPikYLQDA&gws_rd=ssl#q=*tube+expansion *
http://www.sugino.com/site/qa-e/exp-technical-strongpoint01.html Cutting High Pressurization Parts Washing and Deburring Drilling and Tapping Machining Process Tube Expansion and Pulling Surface Property Modification
TUBE Expn RESIDUAL STRESS:
http://www.dailymotion.com/video/x6vcd7_hydraulic-tube-expansion_news
I believe the above links, will be useful.
DHAYANANDHAN.S
Re: Tube Expansion
09/29/2014 9:14 PM
thank you all. I got some real inoformation
Register to Reply 13 comments
Anonymous Poster (2); Crabtree (1); dhayanandhan (1); IdeaSmith (2); libin babu (1); lyn (2); old salt (1); texasron (1); Tornado (2)
