Previous in Forum: VFD Drive   Next in Forum: Purge In Control Panels.
16 comments
Control Panel Specification
09/21/2014 9:55 PM
Hi,
What are the major parameters needed to be addressed for 400 volts control panels? These are to be used for controlling 18 gates of barrage? One control panel for one gate is planned.
Motors of appropriate rating should be controlled by each control panel for uprising or lowering gates. Gate position, Water level etc should be indicated.
Regs,
Re: Control Panel Specification
09/21/2014 10:35 PM
The major parameters are those that will be determined by the project manager and the project electrical, controls, mechanical and instrumentation engineers.
You are likely not in that group and should wait to be told what to do.
09/21/2014 11:35 PM
Seek literature on UL508, Industrial Control Panels. It has been some years since I worked in a UL508 panel shop, but if you have some specifics, I might be able to help. You need to protect the motor and wiring properly, and to account for the environment at the panel and motor installation.
09/22/2014 12:05 AM
Hi, general specs can be the following:
1. Standard size (for 400 volts)
2. Power Switch Device (SCR etc)
3. Shutdown device on SCR panels
4. Temperature Control Zones
5. Temperature Controller
6. Overtemperature Controllers
7. Main disconnect
8. Special features - gate position indication, water level indication, siren on/off indication, motor overload/overspeed protection, Load fusing, Load circuit breakers, On/Off switch, Ammeter, Voltmeter, GFI reset push button, Enclosure heater, Z purge, X purge, Partial load failure indication, AC on-off indication, shorted SCR detection, current transmitter, floorstand, panel lighting, pilot lights, dry contact output, others...............etc.
09/22/2014 4:24 AM
That list seems to be able to answer the original question. Well done.
Good Answers: 122
09/22/2014 3:01 PM
Do not forget to specify the NEMA or whichever enclosure rating specifications you are subject to at your location for the ambient environment.
NEMA 1, NEMA 2, NEMA 3, NEMA 4, ?
09/23/2014 2:45 AM
NEMA 1
NEMA 1 enclosures are typically used for protecting controls and terminations from objects
and personnel. This style of enclosure, while offering a latching door, does not have a
gasketed sealing surface. NEMA 1 enclosures are used in applications where sealing out
dust, oil, and water is not required. Motor start/stop stations are often housed in NEMA 1
enclosures.
NEMA 3R
NEMA 3R enclosures are typically used in outdoor applications for wiring and junction
boxes. This style of enclosure provides protection against falling rain, sleet, snow, and
external ice formation. Indoors they protect against dripping water. This style of enclosure
does not have a gasketed sealing surface. Some models have hasps for padlocking.
NEMA 3S
NEMA 3S enclosures are intended for outdoor use primarily to provide a degree of protection
against windblown dust, rain, sleet, and to provide for operation of external mechanisms
when ice laden.
NEMA 4
NEMA 4 enclosures are used in many applications where an occasional washdown occurs
or where machine tool cutter coolant is used. They also serve in applications where a pressurized
stream of water will be used. NEMA 4 enclosures are gasketed and the door is
clamped for maximum sealing. They have continuous hinges, mounting feet, and padlock
hasps. NEMA 4 enclosures are available in sizes from small wall mounts to two-door floor
mount models.
NEMA 4X
NEMA 4X enclosures are made of stainless steel or plastic. NEMA 4X enclosures are used in
harsher environments than standard NEMA 4 units. Applications where corrosive materials
and caustic cleaners are used necessitate the use of a NEMA 4X enclosure. Applications
include food, such as meat/poultry processing facilities, where total washdown with disinfectants
occur repeatedly and petro-chemical facilities, including offshore petroleum sites.
NEMA 4X is used when protection from the worst environments is required. NEMA 4X
enclosures are available in sizes from small wall mounts to two-door floor mount models.
Wiegmann NEMA 4X enclosures are made of 304 stainless steel.
NEMA 6P
NEMA 6P enclosures are intended for indoor or outdoor use primarily to provide a degree
of protection against the entry of water during prolonged submersion at a limited depth.
NEMA 12
NEMA 12 enclosures are designed to prevent the ingress of dust, water, and oil. NEMA 12
enclosures are most often used for indoor applications of automation control and electronic
drives systems. Some examples are packaging, material handling, non-corrosive process
control, and manufacturing applications. Gasketed doors seal the enclosure's contents from
airborne contaminants and non-pressurized water and oil. NEMA 12 enclosures are available
NEMA 4 & 12
Wiegmann's "412" enclosures combine the attributes of NEMA 4 and NEMA 12 in an attractive,
clean line enclosure. This enclosure features reversible doors for left or right opening,
concealed hinges, and rear mounting holes for a more attractive installation. Optional
mounting feet are available for conventional wall mounting. Wiegmann's 412 enclosures are
available in wall mount models up to 60" x 36".
NEMA 13
NEMA 13 enclosures are intended for indoor use primarily to provide a degree of protection
against dust, spraying of water, oil, and non-corrosive coolant.
Reply Score 1 for Off Topic
09/23/2014 8:13 AM
I am seeing "400 volts" and thinking - this is in IP rating territory. NEMA is not relevant there. Try IP 55, IP 65, whatever.
09/23/2014 8:57 AM
I think NEMA rating is used to signify a fixed enclosure ability to withstand a certain environmental conditions.
NEMA type designations:
1
Indoor use primarily to provide a degree of protection against limited amounts of falling dirt.
Indoor use primarily to provide a degree of protection against limited amounts of falling water and dirt.
Outdoor use primarily to provide a degree of protection against rain, sleet, wind blown dust and damage from external ice formation.
3R
Outdoor use primarily to provide a degree of protection against rain, sleet, and damage from external ice formation.
3S
Outdoor use primarily to provide a degree of protection against rain, sleet, windblown dust and to provide for operation of external mechanisms when ice laden.
Indoor or outdoor use primarily to provide a degree of protection against windblown dust and rain, splashing water, hose-directed water and damage from external ice formation.
4X
Indoor or outdoor use primarily to provide a degree of protection against corrosion, windblown dust and rain, splashing water, hose-directed water, and damage from external ice formation.
5
Indoor use primarily to provide a degree of protection against settling airborne dust, falling dirt, and dripping non-corrosive liquids.
6
Indoor or outdoor use primarily to provide a degree of protection again hose-directed water, and the entry of water during occasional temporary submersion at a limited depth and damage from external ice formation.
6P
Indoor or outdoor use primarily to provide a degree of protection against hose-directed water, the entry of water during prolonged submersion at a limited depth and damage from external ice formation.
7
Indoor use in locations classified as Class I, Division 1, Groups A, B, C or D hazardous locations as defined in the National Electric Code (NFPA 70) (Commonly referred to as explosion-proof).
8
Indoor or outdoor use in locations classified as Class I, Division 2, Groups A, B, C or D hazardous locations as defined in the National Electric Code (NFPA 70) (commonly referred to as oil immersed).
9
Indoor use in locations classified as Class II, Division 1, Groups E, F and G hazardous locations as defined in the National Electric Code (NFPA 70) (commonly referred to as dust-ignition proof).
10
Intended to meet the applicable requirements of the Mine Safety and Health Administration (MSHA).
12/K
Indoor use primarily to provide a degree of protection against circulating dust, falling dirt, and dripping non-corrosive liquids.
13
Indoor use primarily to provide a degree of protection against dust, spraying of water, oil, and non-corrosive coolant.
Regs,
09/23/2014 9:02 AM
there is a correlation between NEMA ratings and IP ratings. However, this correlation is limited to dust and water. Please note that while it is possible to compare NEMA ratings and IP ratings, any such comparison is only related to the protection provided against dust and moisture.
NEMA type
09/23/2014 9:11 AM
Don't know how the inspection process goes where the IEC rules are involved, but do know that even an IP 67 rating is considered NEMA 1 in the USA in an inspection. I've disappointed many well meaning European companies that forced me to use a device that penetrates the type 4 panel wall but was only rated with an IP system rating, not a NEMA rating. This immediately makes the panel a type 1 in the USA under UL 508A standards.
09/23/2014 9:06 AM
Please forward me with UL508 standard. I am not able to find.
Regs,
09/23/2014 9:21 AM
Buy it.
09/23/2014 10:16 AM
Welcome to the capitalist world. UL claims to be a non-profit organization, but EVERYTHING they do costs you money. The 508A standards, as ALL of their standards, are never free.
09/23/2014 10:51 AM
Yes, I've had products tested and registered by them. They are not cheap.
09/23/2014 10:59 AM
We tried to get a heating unit, that they considered as Medical/Dental device (don't ask -it is very complicated) that we produce about 20 of a year labeled - we were looking at 7 years to break even. The real issue is we do custom work, so about half of the 20 would have been considered a different design by UL and also would need the inspection process. We realized quickly, we would never break even unless we sell hundreds per year. Actually makes the cost of a 508A inspection seem very cheap.
09/23/2014 10:00 AM
looks like NEMA, ANSI all deals with 60 Hz and only IEC and IS deals with 50 Hz. Is it like that?
Regs
Reply to Forum Thread 16 comments
Anonymous Poster (3); lyn (3); Phys (4); PWSlack (1); sauravbabu (3); SHOCKHISCAN (1); Tornado (1)
