Previous in Forum: Transformer Busduct   Next in Forum: Directional Protective Relay VS Reverse Power Relay
12 comments
Vacuum Sealing of a Furnace
09/27/2014 8:13 AM
I want to know how to vacuum seal the door of a a furnace of ,of Dimensions : 11ft X 11ft X 6ft (height) at 900;c inside temperature, the door being rise and fall type and being pressd by lock nuts for contact with matched machined part of the body,Generally at low temperature we use rubber gasket inside a groove to prevent leak . At 900;c what elastic material can be used ?
Good Answers: 151
Re: Vacuum sealing of a furnave
09/27/2014 10:09 AM
Water cool the door and mating flange. Use silicone rubber gasket.
Good Answers: 804
09/27/2014 11:45 AM
How does this relate to ELECTRICAL engineering?
09/27/2014 4:14 PM
It's an electric furnace?
Good Answers: 266
09/27/2014 11:46 AM
Most seals at that temperature are metal.
09/27/2014 1:00 PM
Metal tubing might make a suitable O-ring for this. See also FlexitallicTM gaskets.
Re: Vacuum Sealing of a Furnace
09/27/2014 9:18 PM
That is one very thick almost cubic door. Any vacuum chamber with a door this big would be an immense volume. The volumetric flow capability of the roughing, turbo and ion pumps on such a chamber would have to be equally immense to keep up with any nominal leakages a copper gasket could minimize.
I recommend that you place this enormous furnace door on Phobos. You probably won't need any gaskets there.
09/27/2014 9:55 PM
At 900 C, copper might not be the best gasket material. The melting point is not too much higher, and even though the temperature might not ever get to the melting point, there could be problems associated with softening, corrosion, and outgassing.
Good Answers: 52
09/27/2014 10:34 PM
Wills Rings are commonly used in high temperature sealing service. Nuclear reactors, internal combustion engines, vacuum chambers are typical applications. These people quote a top temp of 850C but with tweaking they can go higher:
http://www.tss.trelleborg.com/global/en/products_2/staticseals/datailpages_staticseals/wills-rings-o.html
These are metal o-rings which can behave quite elastically if you choose the variety which is internally pressurized.
I have always enjoyed the pressurizing process for these metal o-rings. The selected tube is formed to the correct o-ring diameter, welded shut and neatly ground - but not before the ring is loaded with a measured weight of sodium azide explosive, depending on the internal o-ring void volume and the desired internal pressure.
Heat the ring, the sodium azide pops and there's your highly elastic, internally pressurized metal seal.
Mark Bingham
Relativity PL
09/28/2014 12:24 AM
copper gasket with the water cooling can be used here.the precisely machined male and female matching ring (cooling on the female side to keep the material in shape,and the same time the male part will expend with the heat to work as a tight seal.
love4everyone
09/28/2014 6:10 AM
Asbestos is still freely available in India, China, etc., why not use that.
I worked with asbestos for many many years at sea in my younger days, (we used to get covered in it, from head to toe......literally), neither I, nor at least two hundred others I worked with and knew reasonably well have suffered or died from any asbestos related diseases. several are no longer with us but have died from other non-related problems. Many of these one who have passed on, served on submarines (Australian "O" Class), and most had stomach or bowel cancer.
Just as a matter of I am still working full time in the maritime industry and I am closing, all too rapidly, onto 75...........and I am still working because I enjoy what I do.
Good Answers: 181
09/28/2014 8:56 PM
Look for Kerlane matting on Google. I've used it at above 900°C for sealing an annealing furnace.
Good Answers: 19
09/29/2014 2:37 AM
We had two vacuum normalizing furnaces where we were making gas turbine engines for power generation, the mating surfaces were water cooled and used silicone O-ring material 20mm cross section, we regularly ran these furnaces to 2400° f and never had a failure.
An addendum: keep these seals clean and lubricated for long life.
Register to Reply 12 comments
gringogreg (1); JRaef (1); lyn (1); MOBI (1); ozzb (1); redfred (1); Relativity PL (1); sohail0110 (1); TonyS (1); Tornado (1); truth is not a compromise (1); Wrench twirler (1)
