Previous in Forum: Processor for Laptop   Next in Forum: DSP Based Audio Modules?
13 comments
Best Toothbrush
10/24/2014 9:42 PM
We have to learn the fact that primary oral concerns about cavity is on the rise. Taking a big step by using the best power toothbrush today will eventually alleviate the problem.
Re: Best Toothbrush
10/24/2014 10:08 PM
Removing you from the forum would remove an even bigger problem.
Good Answers: 97
Re: Best Toothbrush
10/25/2014 12:12 AM
Is that the one with a stationary brush and a paint-shaker type device that shakes your head violently?
CRTL-Z
Good Answers: 70
Re: Best Toothbrush
10/25/2014 12:45 AM
Come back when you can offer an Ebola Vaccine.
Re: Best Toothbrush
10/26/2014 11:17 AM
In Germany, Stiftung warentest have done tests that demontrate that the power toothbrushes are not as good as a good "normal" brush.....
I have a copy, if you can read German, let me send you one....
Re: Best Toothbrush
10/27/2014 8:55 AM
Yes, but that test actually makes the users brush - the big advantage for the power tooth brush, for us lazy Yankees, is it does the work for us. That makes it a better choice on this side of the Atlantic. (I admit to being lazy too - I run the power brush much longer than I would ever manually brush)
Re: Best Toothbrush
10/27/2014 11:22 AM
Then I am lazy too, I have had them for ears, sometime in the 80s - 90s I believe. I bought 4 in the USA as a start, no exact idea when though.....
All I was saying is that according to the test process used, they are apparently not as good as "proper" brushing.....not my personal take though!!
Re: Best Toothbrush
10/27/2014 11:40 AM
http://www.dentalcare.com/media/en-US/research_db/pdf/Page31_2580.pdf
Check this out - opposite results. Of course, a company which sells toothbrushes, both manual and electric was involved, and since the electric are most likely more profitable, one could consider the results a bit prejudiced.
Re: Best Toothbrush
10/27/2014 11:46 AM
You had me wondering why anyone would use a power toothbrush on their ears. I hope that should have been "years".
Re: Best Toothbrush
10/27/2014 11:51 AM
OOPS!!
ead, sorry, DEAD right!!
Good Answers: 97
Re: Best Toothbrush
10/27/2014 11:51 AM
An Idea! Power Q-tip.....
CRTL-Z
Re: Best Toothbrush
10/26/2014 3:35 PM
I'm 63 years young. Several years ago, I had some major dental problems, especially with my gums. My dentist suggest, and I purchased an electric toothbrush. Around 135.00. Now, 10 years later, my gums are the strongest my dentist has ever seen. At my age, he cares little about my teeth and much more about my gums. Proven!!!! Teeth are easy, gums are not. By the way, my teeth are in excellent condition also.
Re: Best Toothbrush
10/27/2014 12:07 PM
Not smoking, and flossing is very healthy as well as brushing. Powered or not, brushing helps.
I been doing a lot of traveling, and I purchased a cheap smaller toothbrush (because it was compact) looked like a kids brush, Brush itself was about 3/8" x 1/2" long. Takes me longer to brush, but I believe I get better results, I have to buy a replacement, but It has no name on it.
Re: Best Toothbrush
10/27/2014 1:54 AM
An ounce of RDX solves many problems.
Good moaning!
Register to Reply 13 comments
Andy Germany (3); Crabtree (1); DeputyDawg (1); dj95401 (1); lyn (1); phoenix911 (1); Phys (2); Unredundant (2); yodelacres (1)
