Previous in Forum: Google Challenge Update   Next in Forum: Why do we still not know what this is?
What Is It?
11/01/2014 8:22 PM
The gear is 1 inch in diameter and the whole thing is just over 1/2 inch high.
In reply to #91
Find in discussion
Re: What Is It?
11/03/2014 10:36 AM
Maybe this is the ribbon driver for a printer. If so, it might not stay delrin white for long in operation.
"When in doubt - check it out!"
In reply to #91
Find in discussion
Re: What Is It?
11/03/2014 12:31 PM
The pawl-and-ratchet do not drive.
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
#145
In reply to #91
Find in discussion
Re: What Is It?
11/04/2014 10:14 AM
I had the correct answer in #88. My wording was not clear enough I suppose. I was thinking of an inhaler I dismantled years ago....
Nothing is fool-proof to a talented fool
Re: What Is It?
11/03/2014 10:29 AM
Is it something with which to confuse one particular CR4 reader?
  • Some say, his armpits taste of seville marmalade
  • And that he doesn't understand human food.
  • All we know, is he is called the PlbMak.
with apologies to Jeremy Clarkson, motoring journalist.
Re: What Is It?
11/03/2014 11:19 AM
Would you tell us, is the fingered part fixed (acting as a pawl), or does it turn and drive the ring gear?
Re: What Is It?
11/03/2014 11:20 AM
A part of a pill dispenser?
In reply to #98
Re: What Is It?
11/03/2014 11:35 AM
I'd've been inclined to go for that if there were 7 vanes.
Re: What Is It?
11/03/2014 11:55 AM
drive used to index a Calendar display
Re: What Is It?
11/03/2014 12:01 PM
It is an upper cam toggle that is connected to the litter cylinder bolt that prevents the spindle spline from oscillating. This in turn will reverse the flux field from the induced energy crystals and hopefully divert quantum energy from inciting complete molecular disorientation.
Good Answers: 15
#102
Re: What Is It?
11/03/2014 12:03 PM
Electric toothbrush guts (the ones that have several motions at once) or a disposable pepper-mill
For every action, there is an equal and opposite criticism.
Good Answers: 27
#103
Re: What Is It?
11/03/2014 12:20 PM
It could be a water agitator in an aquarium. To slow down bacterial growth in the fish tank?
vsar
Good Answers: 27
#105
Re: What Is It?
11/03/2014 12:50 PM
winding spool holder in a correction tape dispenser?
Good Answers: 125
#106
Re: What Is It?
11/03/2014 1:19 PM
Part of a rotary style razor.
In reply to #106
Re: What Is It?
11/03/2014 1:32 PM
No close shaves here.
Re: What Is It?
11/03/2014 3:21 PM
From a coffee maker (Keurig?) to move water from the main water reservoir to the heating reservoir?
Good Answers: 88
#110
Re: What Is It?
11/03/2014 3:22 PM
Part of a one way (ratcheting) clutch assembly, possibly used on auto paper-feeding of printer/copier, a VCR or something less hi tek. Anyway it should work inside another, intrnally toothed cylindrical part. S.M.
In reply to #110
Re: What Is It?
11/03/2014 3:50 PM
More likely from the mechanism dispensing paper hand towels.
But, lyn says used once a day...
#113
Re: What Is It?
11/03/2014 4:18 PM
Ok since it doesn't measure, suck, or blow, I'm asuming it holds something, perhaps a toilet paper roll holder. But then that doesn't explain why you woul have power feed TP. It was never mentioned what drives the gear. It's the motor or manually powered?
In reply to #113
Re: What Is It?
11/03/2014 6:08 PM
"perhaps a toilet paper roll holder. But then that doesn't explain why you would have power feed TP"
It's for the day after curry night.
Floss or die!
Re: What Is It?
11/03/2014 5:21 PM
Stuart21 (82) Guts, but no glory.
Jerrell Conway (83) Not automotive
vsar (84) Nope.
lonster (86) No indexing
lonster (88) Untouched by humans.
Rockyscience (89) No gov.
Unredundant (90) Everything's for sale here. The size has more to do with rotational speed than torque.
TLC Designer (91) Some truth here, but not enough
Stuart21 (92) Nope.
PWSlack (93) Good to have you back.
TLC Designer (94) Stick with your other guess.
TommyTech (95) Full speed ahead.
Doorman (96) All turns together in normal service
HiTekRedNek (97) No JohnDG (98) number immaterial
jdsighter (99) no
That's enough for now.
In reply to #114
Re: What Is It?
11/03/2014 6:28 PM
Confused me for a mo - mine was 99.
In reply to #117
Re: What Is It?
11/03/2014 6:35 PM
You're confused?
I'm jumping between 3 screens to do group replies.
Re: What Is It?
11/03/2014 6:30 PM
101-115, No.
spades, yes, there are two. I think the designers just like symmetry.
In reply to #118
Re: What Is It?
11/03/2014 6:37 PM
TIGER, tiger, burning bright
In the forests of the night,
What immortal hand or eye
Could frame thy fearful symmetry?
You're welcome. Thank the beer.
#121
Re: What Is It?
11/03/2014 7:30 PM
part of the mechanism that changes the date on a clock or appliance
LakeGrl
In reply to #121
Re: What Is It?
11/03/2014 7:48 PM
Sorry. Its function is passive in the sense of changing or causing any change of state of another object.
It is typically powered by the human thumb.
r&ddoc, No money here.
In reply to #123
Re: What Is It?
11/03/2014 8:08 PM
"It is typically powered by the human thumb". Through a lever actuated gear train.
In reply to #124
Re: What Is It?
11/03/2014 8:16 PM
Some kind of medicine dispenser? (e.g. Ventolin etc.)
In reply to #125
Re: What Is It?
11/03/2014 8:18 PM
Well I don't know what you guys use that side of the pond!
In reply to #125
Re: What Is It?
11/03/2014 8:44 PM
Drum roll please.
Yes, it is the cover lay take-up mechanism of an inhalation medication dispenser that packages the powder in small pockets in a continuous reel.
Each actuation of the thumb lever advances the reel to the dispensing cavity and the cover lay is stripped away by the take up reel. Note the peg at the one o'clock position that captures the end of the cover lay roll. The pawls allow for slippage, which I have never knowingly experienced.
Here are two pictures. Anyone care to speculate how it all goes together?
Hats off to the Englishman. I'm having one in your honor JohnDG.
Cheers!
Good Answers: 15
#128
In reply to #127
Re: What Is It?
11/03/2014 9:27 PM
Shame on me for believing that your hints were true.
Earlier it was said that we use it once a day and that it was not used to dispense anything.
I have never used one and it clearly dispenses, that's two lies in my book and would terminate any further business relationship unless you worked for Obama, therefore deny any knowledge of what you are doing and change the rest of the story to suite your own need.
I will suggest that you day job work ethic matches this crap.
In reply to #128
Re: What Is It?
11/03/2014 9:56 PM
It, this device,
is used once a day.
It" does not dispense anything.
It" is a take-up reel.
Irrationality and hysteria can be controlled, with intense psychological therapy.
PM me with your location and I can recommend some local help for you.
I hope you enjoyed the thread, otherwise.
Good Answers: 225
#130
In reply to #128
Re: What Is It?
11/03/2014 9:59 PM
Go easy on him, it was good fun after all.
At least now I may be able to get a good night's sleep.
As for Lyn's question "Anyone care to speculate how it all goes together?" might I suggest one piece at a time, and very carefully.
May be easier to buy a new one, although if, as I suspect, like me, many on here would rather fix than replace, even if it takes way too much time and effort, this will be re-assembled, and may even work again.
In reply to #130
Re: What Is It?
11/03/2014 10:15 PM
He must have discovered that the grand prize was a 6-pack of Billy Beer. I've put on my tin foil hat in case he comes back.
Anyway, you get a new dispenser each time, whether you want it or not. They (contents) last for 30-60 days. What a waste.
It snaps together and is easy to disassemble if you understand injected molded parts and assemblies.
I did not photograph a step-by-step disassembly.
Thanks, but really, X-rays?
Good Answers: 225
#132
In reply to #131
Re: What Is It?
11/03/2014 10:22 PM
"Thanks, but really, X-rays? "
And here I was thinking that I got away with that
Good Answers: 123
#133
In reply to #131
Re: What Is It?
11/03/2014 11:55 PM
Thanks for a GOOD version of "What is it". I will try to come up with something as diabolical.
Bob
In reply to #131
Re: What Is It?
11/04/2014 12:15 PM
If you have not heard, Mr. Lyn, tin foil hats have been superceded by pumpkin hats. They look like crap, smell like crap, fit like crap. Any further guesses?
In reply to #127
Re: What Is It?
11/04/2014 3:32 AM
The thumb actuation was the biggest clue IMHO. We do indeed have this type of dispenser over here (in fact I was prescribed one several years ago), but the vertical cylinder propellant-driven metered-dose inhaler is much more common. I have one, but it's more a psychological prop than a necessary medication. (I only use it about 3 times a year).
Good Answers: 225
#135
In reply to #134
Re: What Is It?
11/04/2014 3:57 AM
I guess that you need to be old or infirm to know about those things, the rest of us had no hope.
In reply to #135
Re: What Is It?
11/04/2014 4:45 AM
True I'm getting on a bit (62), and not in the best of health (but I would go as far as "infirm"!), but increasing numbers of children and young adults need to use inhalers these days.
In reply to #136
Re: What Is It?
11/04/2014 6:05 AM
^would not go ...
In reply to #134
Re: What Is It?
11/04/2014 8:59 AM
I should have known that there would be other old geezers out there with bad lungs.
The drug dispensed by this contraption (salmeterol xinafoate inhalation powder) was formerly packaged in containers like the albuterol with propellant that you have. I have one of those too. And another one that you suck to get the dose.
I think that they designed the device now used so that they could sell more of the drug.
Good Answers: 114
#153
In reply to #141
Re: What Is It?
11/04/2014 12:00 PM
I use Advair Diskus two times per day, that has been in that form since I started it about twenty years ago. I couldn't swear that it does or does not do good work, it is slow acting. It includes a steroid which reduces inflammation but leaves one more open to pneumonia. My main lung medication is used with a nebulizer every four hours unless I'm away from home when I use an inhaler with the same stuff.
The inhaler changed recently, it used to use a hydroflourocarbon to power it, now, the user "pumps it up" to power it. I'll try to remember to take one of those apart when it runs out. How to use it.
Good Answers: 67
#154
In reply to #127
Re: What Is It?
11/04/2014 12:10 PM
So much for my paper-roll-holder theory. It comes from being fashionably late (hats off to JohnDG).
On a related topic: Where's the flame war? It's freezing here and my furnace quit yesterday.
Good Answers: 67
#152
In reply to #125
Re: What Is It?
11/04/2014 11:49 AM
At one inch by one half it's way too big for a Ventolin-style medicine dispenser.
Re: What Is It?
11/03/2014 7:37 PM
May be one of the two impellers money counting machines have? Or perhaps the paper feeder of a desktop printer?
Re: What Is It?
11/04/2014 5:42 AM
So now!
If we was just to solve this riddle we was fine!
Righto?
I'll post a new thread!
Good Answers: 114
#140
Re: What Is It?
11/04/2014 8:48 AM
I use mine twice a day. I'm surprised that I haven't taken one apart myself.
Re: What Is It?
11/04/2014 10:08 AM
I sense a few disgruntled people here.
It's a clever bit of engineering design, Lyn clearly seen it a such, prompting him to post it.
Now trying to think if I seen this application used elsewhere.
Good Answers: 27
#146
Re: What Is It?
11/04/2014 10:21 AM
(i accidentaly posted as reply to #91...)
Re: What Is It?
11/04/2014 11:01 AM
To all who feel hurt.
Get over it! Next time, don't play my silly game.
I started to make some more individual comments, but, what's the use?
Both TLC Designer and Brian Falconer came close to describing the device's function.
Thanks to all, I enjoyed it anyway.
Good Answers: 27
#148
In reply to #147
Re: What Is It?
11/04/2014 11:22 AM
not hurt here, I enjoyed the excercise... I gave it 5 stars!
Good Answers: 67
#149
Re: What Is It?
11/04/2014 11:29 AM
My best guess is that it's one end of a paper-roll holder from a lever- or motor-actuated restroom paper hand-towel dispenser mechanism? The vanes look to be radial springs that might also tend to resist the roll's counter-rotation (if that's what the piece is for).
In reply to #149
Re: What Is It?
11/04/2014 11:33 AM
Fashionably late to the party, eh?
Good Answers: 67
#151
In reply to #150
Re: What Is It?
11/04/2014 11:46 AM
I'm in the middle of moving so I haven't had much time to visit.
In reply to #150
Re: What Is It?
11/04/2014 5:43 PM
" Fashionably late to the party, eh?"
I love this comment, it's sort of taking the piss without taking the piss.
In reply to #156
Re: What Is It?
11/04/2014 6:03 PM
Taking the piss? Moi?
Good Answers: 73
#158
Re: What Is It?
11/05/2014 9:00 AM
It reminds me of a squirrel cage fan. If we knew the speed (rpm) it was driven, it would be more obvious. It is too small to move large volume of air, but if it was just once a day, it would also be nice to know how long it was being used. Once a day could be 12 hours or more.
In reply to #158
Re: What Is It?
11/05/2014 9:04 AM
Once a day for twelve hours would be more like an iron lung or hyperbaric chamber instead of a powder inhaler dispenser.
In reply to #158
Re: What Is It?
11/05/2014 9:21 AM
It has reminded many people of fans and pump impellers and toilet paper roll holders.
Although I have never measured the speed, I estimate that it turns at about 1/2 RPM
for about 1/4 second each day.
I'll be revealing the answer next week, for those late to the party.
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
#163
In reply to #158
Re: What Is It?
11/06/2014 8:17 AM
We refused to fit a fan to Kris's cage on the basis he'd dismantle it and escape. Additionally, the inherent fumes keep him sedated.
Not quite sure when lateness loses its fashionability, but "Hi, everyone!! I brought more beers...."
Chaos always wins because it's better organised.
In reply to #163
Re: What Is It?
11/06/2014 8:45 AM
Hi. You're never too late to join the party.
Re: What Is It?
11/05/2014 9:41 PM
A vital component in printer to move paper or currency counting machine to slide bills...
In reply to #161
Re: What Is It?
11/05/2014 11:33 PM
Yes, I noticed the exact same represented as I reduced a FAX machine for recycle.
Anonymous Poster (1); AverageJoe (1); az native (1); Beenaround (4); bob c (2); Brian Falconer (4); Doorman (2); English Rose (1); europium mkII (4); Graycav (1); Grochy (1); Hendrik (4); HiTekRedNek (1); IdeaSmith (3); James Stewart (2); jdretired (2); jdsighter (6); Jerrell Conway (1); JohnDG (13); LakeGrl (1); lonster (7); lyn (38); merc600sec (1); nick name (2); North of 60 (1); NotUrOrdinaryJoe (1); Noudge79 (1); oak51 (1); passingtongreen (6); PWSlack (1); r&ddoc (1); Randall (3); redfred (10); Rockyscience (1); roy hammy (2); SimpleMind (1); sohail0110 (1); SolarEagle (3); Some guy (1); spades (6); Steve of the North (1); Stuart21 (5); texasron (1); TLC Designer (2); TommyTech (2); Tornado (2); Unredundant (3); vsar (2); WJMFIRE (2); yesyen (1)
