Previous in Forum: Petroleum Company Imaging Data   Next in Forum: Prius Suffers Software Glitch
Ordering of coordinates
10/12/2005 10:05 AM
Carlos Castro M writes:
I have series of coordinates from Hole Table of Solidworks, but can only order in X, Y or Label values, to insert them in a Punching Machine program I need order by nearest for be efficient. I tried with the Vectorial Distance between a coordinate and others, but is that the only way?
Good Answers: 97
Re: Ordering of coordinates
05/12/2007 6:08 PM
With a lot of points vectorial distance can produce quite a large quantity of number crunching.
I do the following to improve the speed of the optimizing program:
Sort the points into strips (the shortest side) (say Y)
Then sort the strips according to the other coordinate. Note that alternative strips must be sorted in ascending and descending sequence. (zig zag across the board)
Points with equal X values should also be sorted for Y.
The number of vectorial calculations are then greatly reduced.
You can stop at the width of the strip or the length to the next point.
It is true that this method sometimes leave almost adjacent points because they are in the next strip, This can be rectified by adjusting the strip.
Reply to Forum Thread
