Previous in Forum: Velocity head in part-full pipe   Next in Forum: German Translation
9 comments
Orifice Plate Design Formula Needed
07/06/2007 4:44 AM
Hi friends,
Is there any simple formula , easily understandable - to design an orifice plate ?Given me an idea about pressure / velocity of the media passing thro' the orifice.
Thanks in anticipation,
Voltamps
Re: Orifice design
07/06/2007 4:50 AM
Are we talking human breath measurement or oil delivery pipeline?
The two are rather different...!
Re: Orifice design
07/06/2007 5:03 AM
Hi ,
It is gas flow line , for measurement of Natural gas flow.
Regards ,
Voltamps
Re: Orifice design
07/06/2007 5:39 AM
Right...you will see from that Wiki reference that the relationship between flow and pressure drop isn't simple and certainly not linear.
If you want a simple linear pressure flow relationship you need to look at a variable orifice. e.g Imagine a circular disc with a slits in it forming a cross this will give 4 'flaps' which will open up progressively with flow giving a more linear relationship.
There is also the fleisch tube which gives a more linear relationship by inducing laminar flow, these are used extensively in pulmonary function measurement.
Dunno if they make 'em in the size/flows you would need.....not hard to make.
Basically you have a choice..Simple orifice complex maths. or complex orifice simple maths.
Making your own variable orifice is fun (if you are getting paid for it!)
Have fun...
Re: Orifice design
07/06/2007 4:53 AM
Good Answers: 97
Re: Orifice design
07/06/2007 5:45 AM
Wikipedia spoils all the fun of having accumulated reference material over years(books, notes etc).
Technology deprived persons like myself usually forget about the wonders of wikipedia as a source of information.
In this case it would have been a big task to retype the formula in an correct and understandable format - the √ is a bit limited.
Re: Orifice Plate Design Formula Needed
07/09/2007 8:43 AM
There are a few parameters for orifice plates that need to be defined first.
The following link will work for an orifice inside a pipe.
http://www.efunda.com/formulae/fluids/calc_orifice_flowmeter.cfm
If the orifice is a hole in a tank then the coefficients are different.
If the fluid is compressible then there's a whole new set.
You will need a text book or handbook to look up the coefficients for your case.
Good Answers: 19
07/22/2007 6:56 AM
Thanks alot.
The software site given is excellent and will help me alot with selecting orifices for flow measurements for steam/gas/water.
Thanks again.
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
07/09/2007 9:06 AM
I would recommend the Crane formula (pg. 3-24) from Tech. paper 410. It usually takes a few iterations to get the diameter correct. Remember that the turndown of an orifice isn't that great (I have seen that greater than 4:1 will start to read inaccurately). Also, to convert into mass or molar flows, you will need an accurate flowing density that you can either calculate or measure with a densitometer. Since you probably know the general composition of the fluid (natural gas), the density is a function of pressure and temperature that you can probably get close enough to with an ideal gas ratio. Unless this is a billing quality meter, that should get you pretty close to accurate.
Money doesn't talk, it screams in your face.
07/09/2007 11:05 AM
"Flow measurement" by Spink. Go to this book. It is a very good source for the subject. There is not an easy formula, as I know.
SaC.
Register to Reply 9 comments
Anonymous Poster (1); betomachine (1); ducon (1); Hendrik (1); Jolsac (1); jrpeck (1); user-deleted-1105 (2); Voltamps (1)
