Previous in Forum: Medium Voltage GIS   Next in Forum: DC Current Applied to the Temple Increases IQ
66 comments
Good Answers: 73
Can an Inductor Be Spherical?
12/02/2014 8:47 AM
It sounds a bit silly to ask but I'm going to throw it out there anyway. Without spending a lot of time on this, I believe there will be two answers that depend on the type of excitation that was applied. I haven't been able to find a suitable answer with the internet search engines which tells me that it is either pointless or withheld for some reason.
There are two cases I would like to understand. First, what happens when DC is applied? And secondly, what happens when AC is applied?
Perhaps I missed that discussion in engineering class. I'm just curious.
Pathfinder Tags: spherical inductor
Re: Can an inductor be spherical?
12/02/2014 8:54 AM
Think you need to explain a bit more. Do you mean "wound on a spherical core/former" (just as a toroidal inductor is wound on a toroidal core), or some other arrangement?
Good Answers: 444
12/02/2014 9:13 AM
Joe, John is right, much more information is required as to form factor, direction of winding, how it's wound, etc. The waveform (excitation) doesn't matter since inductance is a physical property of the inductor (time is not part of the equation) while impedance (which does have time in its units) will vary.
Good Answers: 11
12/02/2014 9:17 AM
It's either have converging or diverging effect, just a free guess not much effort.It all depends where the terminals are wired.
Good Answers: 444
12/02/2014 9:23 AM
Please explain "converging or diverging effect" in the context of an inductor. Even a straight piece of wire has inductance.
Good Answers: 11
12/02/2014 9:39 AM
Just imagine if a current will pass through a sphere (either a solid or one in which has interior cavity-which have different effect than that of a solid) from then on, you have your implications already.
I throw a wild guess. Would it be a must to explain?
12/02/2014 11:48 AM
It would be helpful, as I don't have a clue as to what you're on about. Not for the first time, either.
Good moaning!
Good Answers: 444
12/02/2014 1:15 PM
Yes, especially since your premise is wrong, the interior-fill places no part in calculating the inductance.
Good Answers: 11
12/03/2014 11:45 AM
Do you know the electromagnetic characteristic trace for that geometry(both solid and shell sphere). You may use it for the analogy of the inductance. Like what's the reason inductors in a pcb is made of just coiled conductor?
Good Answers: 73
12/02/2014 9:58 AM
I meant to describe a sphere with wire wrapped around it (if possible) in such a way as to be both random and evenly distributed. But that also brings up some other special considerations to think about.
I'm guessing that cancellation will be one of the answers. But I was curious as to how a magnetic bottle would be created. Perhaps a temporary mono-pole? I simply struggle to think in 3D.
Good Answers: 444
12/02/2014 11:51 AM
Hollow or solid doesn't make a difference to the inductance, it will affect the DC resistance, not much difference to AC resistance because of the skin effect.
12/02/2014 3:52 PM
Hollow or solid spherical core material will only effect how easily the core saturates.
Getting back to the initial question, an inductor can be made with spherical core material but it is a geometry that makes it harder instead of easier to fabricate. The geometry also makes it easier to misalign the coil winding to cancel instead of increase the magnetic field produced outside of the wires. This will have the effect of lowering the inductance while the added wire series resistance still gets added.
To sum it up, yes it can be done but you will just be making things hard on yourself.
12/03/2014 10:05 AM
"I meant to describe a sphere with wire wrapped around it (if possible) in such a way as to be both random and evenly distributed."
Inductors work because the wire is wound in an ORDERLY and evenly distributed manner.
Let us look at the classic cylindrical air-core inductor for example, since it 'makes the maths easier.' If you start at the source side(1) and wrap the wire ten times around the core clockwise, you will get an inductor of x farads. If you wrap the wire ten times counter-clockwise, you will get the same x farads. If you wrap the wire five times clockwise, then the wire is bent backwards and wrapped five times counterclockwise, you will get something less than x farads. If you wrap the wire once clockwise, once counterclockwise, once clockwise, etc(2), you will get something close to zero farads. Random, even distribution will cancel out most of the inductance due to wires running in contrary directions.
Notes:
1) Starting point chosen completely arbitrarily. All that matters is that all examples use the same starting point.
2) The effect would look much like a part in a hairstyle, you could draw a straightedge along the line where the wires double-back on themselves.
Good Answers: 73
12/03/2014 12:41 PM
Good answer! Precisely what I was looking for. Now that those brain cells of mine have been stimulated, I suddenly feel hungry!
12/03/2014 12:46 PM
YIG (yttruim-iron-garnet) spheres have been used in HP/Agilent/Keysight spectrum analyzers since the 1970s in gigahertz oscillators as the local oscillator. See here
12/03/2014 2:11 PM
gigahertz?
Isn't that leaving the part of the EM spectrum we call 'electricity' or 'radio waves' and moving into the area we call 'light'?
--edit--
Okay' it's just below what we call 'light.' Still, at that high of a frequency, you can use solid balls as inductors since the power is'nt traveling THROUGH the ball, it's jogging (sprinting?) on the SKIN.
12/03/2014 2:53 PM
Give me break, I'm talking 3-4 GHz (microwaves). Visible light is around 500 Terrahertz. On the other hand, I have an LED that produces light.
12/03/2014 3:07 PM
You didn't specify LOW gigahertz, and Tera- is the next 'level' up from Giga-, so it doesn't seem like such a big leap from one to the other.
12/03/2014 2:58 PM
You meant Henrys, not Farads, right?
12/03/2014 3:04 PM
Correct, I turned left when I should have turned right, or is it the other way around? Been a while since I've done analog electronics at the component level, I forget what leads or lags what by 90 degrees with caps and coils.
12/03/2014 3:14 PM
Since one of the inverse units of resistance is the mho, should the unit of inductance be the daraf. Maybe the unit of capacitance should be the yrneh. Nome of these units should ever be confused with a henweigh.
12/03/2014 4:27 PM
Since the universal constant for a henweigh is 2.0 gge,then the reciprocal of a henweigh is 1.50 egg.
12/03/2014 4:35 PM
I think you are confusing units again. 1 egg is the unit for a henleigh, not a henweigh.
12/03/2014 5:49 PM
You're right.I got my units scrambled.
12/03/2014 2:30 PM
You might have better luck tying the wire in a "monkey fist" and nesting the {hollow} sphere within that, unfortunately, there will be wires going every direction, so I have no idea what the field will look like. OR you might try making a phoney "monkey fist" knot with three separate conductors, and choose (carefully) the direction of current to be necessary in each. What you end up with is a sphere approximately covered in coils in each direction, x, y, and z such that field could be switch reasonably quickly in any axis or linear combination thereof.
Surely you know how to tie a "monkey fist"!
Re: Can an Inductor Be Spherical?
12/02/2014 10:05 AM
It can be any shape, but some shapes are smarter/stupider than others.
For instance, a small stellated dodecahedron would be a poor inductor, albeit a good cocklebur.
Good Answers: 73
12/02/2014 11:33 AM
I'm not sure that I understand what you mean by "star shaped" or stellated. I suppose that it is possible to wind wire around a sphere in a variety of geometries. And I realize that some methods may produce a useless device. Then again, it may be useless for AC but something completely different for DC or the other way around. I know it is probably way above my pay grade or worse, but I am just curious.
If it's classified, I'll just let it go. I'm just trying to climb back in the box.
12/03/2014 10:13 AM
Well, DC sees inductors as just very low-ohm resistors, unless your trying to shove a step function into them, where they will resist the sudden change, appearing as an immediate high resistance that drops as the coils saturate.
Remember, capacitors resist a change in VOLTAGE, inductors resist a change in CURRENT. That is why you never yank an inductor out of a live circuit, if it's got one milliamp running though it, and it suddenly 'sees' infinite resistance between its leads, it will 'try to maintain the current.' Ohms Law: V=IR. 1 mA * Infinite resistance = Infinite voltage. Or in other words, a nasty shock that will have you shouting the words your mother never wanted to hear out of your mouth.
12/02/2014 11:41 AM
Just *visualize* the magnetic lines eminating from/into our *spherical* earth in both dimensions, E and H fields.
Good Answers: 73
12/02/2014 11:55 AM
No, that is a rotating sphere and it mimics a bar magnet. That is not the same thing.
Although this is unrelated, consider the drawings, or vitalizations of a "black hole". Every time I have seen that, it has been illustrated as the event horizon with stuff in orbit in roughly a plane around the black hole. But that is not the reality. Actual observations reveal that several suns orbit our galactic black hole in orbits that vary in size, speed, angle of the plane (relative to the plane of the galaxy).
Speaking only for myself, I don't like mis-direction for the sake of simplicity.
Good Answers: 67
12/02/2014 1:47 PM
You're living on one.
Good Answers: 73
12/02/2014 3:09 PM
Not what I described!
Good Answers: 67
12/02/2014 4:58 PM
How not, in reply to your original post? The electrical currents flowing in Earth's interior act just like the turns in an inductor. That the interior is molten is irrelevant. All that matters is that it can - and does -carry a current, and an AC one at that; one whose period is measured in tens of millennia.
12/02/2014 7:06 PM
I don't know about inductance, but I've got a fair idea what would happen if you shot it from a length of rubber tubing stretched 50% of its length with 50 pounds of force.
12/02/2014 7:46 PM
You mean with a steel ball where the steel is conducting and the ball is a sphere?
Good Answers: 73
12/03/2014 8:21 AM
Yes! As I said, I realize that it sounds a bit like nonsense. And I expect there is more than one answer highly dependent on how it is wound. I only ask because I could not find any information as to what characteristics it might have. If it were to cancel out all reactance, for instance, then it could only be a resistive device.
As to whether or not it would be useful, I suppose that would require knowing how it acts when connected to an external power source.
Some people say that everything has already been invented. A few people also said that in the 1930's but they were proven wrong. I am just resisting the urge to brush up on my rather dusty knowledge of electromagnetics. You might say that I am trying to conserve energy, uh... my energy! Those particular brain cells have not been disturbed in quite some time now, and I figured that as usual, I'm not the first person to ask such a question.
12/03/2014 9:08 AM
HEY! Why drag me into this?
But since you did,consider the effect on a spherical steel ball if you shot it(with the
aforementioned propulsion system) between the poles of of a strong magnet?Aside
from a temporary deflection from it's intended direction,what will happen to the
induced voltage and magnetic field within the sphere?Will it retain some magnetic
orientation related to it's position when it exited the magnetic field?
If so,what will be the orientation of the field?
How about if you shot it from East to West,with wind blowing from the northeast at 1
m/sec and barometric pressure steady at 29.9",at 220 ft below sea level, using a
magnetic compass for direction, and allowing for a 6 degree westward
declination from true north,during an eclipse of the sun,in a coal mine,while wearing
sunglasses and whistling Dixie with a mouthful of saltine crackers?
Will the Anthracite formation have an effect on the residual magnetic field in the
sphere,and would the results vary if it was a Bituminous formation?
Georgia moon wants to know!
12/03/2014 2:43 PM
You did not specify the type of steel, whether it is ferromagnetic, paramagnetic, or diamagnetic steel. Or was that austentacious steel? IF this ball is sufficiently conducting, a very large current could be induced, but I have no idea if this oscillates, just heats up the ball, or what, as you did not specify if the ball was spinning, or what the spin orientation to the applied M-field is.
And the answers to all your questions are YES!
12/03/2014 2:35 PM
Priceless!
Good Answers: 73
12/04/2014 11:17 AM
Lyn rocks!
12/02/2014 8:07 PM
No, if what you mean is the flux radiating outward from the center. Magnetic flux must flow in loops (which is why it's called flux ). It has to get back from the outside to the center. There's no way it can do that unless it can get through the 4th dimension. AC or DC, it's still got to be continuous loops.
A spherical capacitor, on the other hand, is no problem. The earth is one, with the ionosphere charged up by electrical storms.
12/02/2014 9:47 PM
Wouldn't an isotropic antenna, if we could make one, be considered a spherical inductor?
Good Answers: 67
12/02/2014 10:34 PM
I guess if it met the criteria for its being an inductor. Storing energy in a magnetic field, presumably one that sticks around instead of radiating away with its companion electric field, is one criterion that would be very hard for an antenna to meet for a DC magnetic field. I suspect antennas make better capacitors in this respect, but not very good inductors once everything settles down.
Good Answers: 52
12/02/2014 11:45 PM
"Wouldn't an isotropic antenna, if we could make one, be considered a spherical inductor? "
Arguably, YES. See Figure 6.5 of this antenna treatise:
http://arlassociates.net/validationwheelerformulas.pdf
Mark Bingham
Relativity PL
12/03/2014 6:34 AM
You can't make an isotropic antenna either. Electromagnetic radiation is transverse, meaning that the oscillating electric and magnetic fields are perpendicular to the direction of propagation. It is for the same reason that somewhere on earth, the wind is not blowing, also known as the hairy ball theorem.
http://en.wikipedia.org/wiki/Hairy_ball_theorem
A longitudinal wave such as sound is a different story. There is no reason why a pulsating ball cannot emit sound isotropically.
Good Answers: 52
12/03/2014 5:20 PM
"You can't make an isotropic antenna either."
Chu (the classic paper of 1948) and later McLean
http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber=496253&url=http%3A%2F%2Fieeexplore.ieee.org%2Fiel4%2F8%2F10599%2F00496253.pdf%3Farnumber%3D496253
argue that an infinitesimally small dipole qualifies.Yes, I understand that one cannot build something that is infinitesimally small, but obviously the smaller the dipole the less the anisotropy.
Good Answers: 67
12/03/2014 8:50 PM
Antennas are fine for the purpose, but not as an inductor as they do not storage energy in magnetic fields at zero Hz. Inductors do. At zero Hz an antenna acts as a capacitor.
12/03/2014 9:29 PM
I'm now sorry I brought at all the idea of the isotropic antenna to this discussion. When I started this now sorry tangent I announced that the isotropic antenna cannot be made. Then every Tom, Dick and Solomon jump all over it saying that it cannot be made. Now there is this silly comment that an antenna acts only like a capacitor. The blinders and gibberish shouting down the rational thoughts is too much for me.
Good Answers: 67
In reply to #59
12/03/2014 9:39 PM
I'm sorry you feel that way, but the scope of the question includes DC. If an antenna does not act like a capacitor at DC then what does it act like? Certainly not an inductor - unless it's a loop antenna
Blinders and gibberish shouting down the rational thoughts? Well, it's certainly heartwarming to know that your comments here are the only ones worth considering, yes? Doesn't make for much of a discussion but, hey, when you got it, flaunt it.
Bring on the OTs. I really couldn't care less.
In reply to #60
12/03/2014 10:37 PM
I apologize for making my rant on your comment. However you contradict your own rant by now identifying a loop as an antenna, too. If you're going to consider the theoretical value of a zero frequency as a criteria to define an inductive antenna then an infinitely long wire with a finite non zero current running through it should also count. This will not be at all close to the mythical isotropic antenna, so don't take that path, but another mythical antenna none the less.
I was just getting upset that people were emoting more lately on this forum than thinking. Even the AI has been making gibberish lately. It displeases me to have drama forced on me. If I wanted foolish drama I would get a Facebook account.
I know, I know. The irony here is that I'm piling on more drama here with this rant. An added irony is some of the ways to prove that a true isotropic H field is impossible were intriguing to me. [Cowlicks]
I try to take my time to be thoughtful on this forum. Part of that thought process is keeping things ON topic instead of OFF topic. My isotropic antenna comment instead of being a simple observation turned into an OFF topic mild feud.
12/04/2014 10:52 AM
Wow, now that is some "hairy" math! I can see that having some useful applications, such as charge transport on a spherical carbon spherule, although since I am having problems with the maths, and a spherule is not a perfect n-sphere (for that matter neither is a coconut), I still suspect there will be a zero point on that carbon spherule somewhere, and this could apparently present as a charge imbalance, possibly helping that sphere to rotate as it translates in an E-field. (this is only of local interest to me).
12/03/2014 2:38 PM
No idea, but a friend on mine who is a ham radio operator was telling me the other day about a new antenna design he is working on that relies on M-field projection rather than E-field projection. That is all I know about it, and I should have said less.
Good Answers: 67
12/03/2014 8:38 PM
I'm assuming he meant something other than a kind of loop antenna? Loops are H-field beasties.
12/04/2014 10:38 AM
Sorry, but I actually have forgotten the exact layout of his antenna design, I think it may have actually been a spiral looped planar arrangement, not sure if evenly spaced or more of a logarithmic spiral.
12/03/2014 2:45 PM
What about coronal mass ejection from the sun, does the plasma not follow the magnetic field lines, and loop back to the sun's surface in places all over the surface?
Good Answers: 67
12/03/2014 8:42 PM
CMEs and other large plasmas both follow and entrain magnetic fields, dragging the fields along with them as they move, and it is the outskirts of the entrained field that is doing much of the interacting with the ambient one.
12/02/2014 10:48 PM
Being at the other side of the world I have only just seen all the replies/comments.
What is it that you are trying to make/do? Or, what is the application? If any.
We can wind an inductor which has an external spherical shape but there would be one magnetic axis. That has some difficulties but is possible. And it would probably have an exterrnal field that follows the outer spherical shape pretty closely.
The main question appears to be what type/shape of magnetic field are you able to accept. A spherical field needs to have a return path.
Or do you want "The inductance of a point" source - which is probably an oximoron because if it is a point there can be no current flowing?
Or are you looking to have an inductance which has no external magnetic field outside - or inside - of a nominated spherical shape?
fsmit@dyne.com.au
Good Answers: 67
12/03/2014 12:07 AM
Electrons have no size as far as we know but yet they have angular momentum and a net magnetic moment, so it is possible, yes, even whilst being extremely counterintuitive.
Good Answers: 73
12/03/2014 8:33 AM
At this point, I'm not trying to do anything. How could I? I simply want to know what the characteristics would be. Is it useful? Well, that depends on answers to questions like, "Can it store and return energy similar to a normal inductor?". I have my doubts.
If I had the mind of Nickola Tesla I might be able to visualize what would happen. Unfortunately, I was not blessed with that ability and I simply did not want to go through an effort if that had already been proven as theoretically worthless.
This question is mostly about the influence of a specific geometry on a man made object. It has nothing to do with the earth or any other cosmic body. I don't know how that got started but it is well outside the scope of this question.
Good Answers: 67
12/03/2014 8:56 PM
Perhaps then you might consider formulating and posting a script for others to follow when responding to your queries, and just boot the ones that don't conform to the Divine Script. Nice and controlled, like a blinkered donkey. Would that make you happy?
We wouldn't want to cause any discomfort by introducing variants on ideas about which you've already made up your mind.
Later, mate.
<unsubscibe>
12/03/2014 12:08 AM
At the risk of being a total hypocrite, I would suggest you look at this link, http://www.electronics-tutorials.ws/inductor/inductor.html - the which I have not, - but i am a designer, not an engineer, so i only have to intuit the direction to look for solving problem, not actually solve it, - giving credit where it is due, that is where engineers have an important place. I had a situation where I was a bit out of my depth, designing into a job, (I designed, supplied and supervised the whole job) with a 75kW wind turbine, (induction motor re-done as a generator) on a sea girt island, running a school with all sorts of big air-conditioners and welders, etc, and community night time, so needed power outside of the trade wind time, (app. 10 AM to 11 PM every day) - relatively small battery bank, just under .5MW/hrs, using a 100kW inverter AC DC / DC AC back to back converter, IGBT, etc .you know, and lo and behold it had to have it's output conditioned, - 3 phase supply to the load, - sometimes winging it has it's serious down side, - so, big capacitors, big inductor, bought some very heavy (two of us to carry) traditionally wound, - 200 micro henries? 300? I only know of Henry the 8th I am I am, but, testing it, the bloody thing got very hot, - tried to melt it's way through the cardboard box it was too heavy to lift it out of and we measured over 5000 watts, - not only the inductor obviously failing but far too much drag on a stand-alone system with 24 hour operation. Obviously i am trying to be brief, but a birdie whispered to me "Hollow Cored Inductor" Whacko, a third the price and used (I think) 4 watts, - although at the time I was trying to stop the enthusiastic volunteers from making a 12 metre Pyramid rather than disc as foundation for the tower, - alas failed and they used horrendously more concrete with I suspect little advantage, (perhaps the subject of another post?) so don't remember exactly, - but let it stand so folk can get exercised, it was not bloody much. Sure, 'hollow cored' is not 'spherical', but possibly in the direction you are asking, - contact me directly if you want me to see if I can drag up details. Cheers, Geoff.
Let's try and think clearly when looking at information and only allow emotions when weighing up options.
12/03/2014 6:26 AM
Why do you want to know?
Good Answers: 52
12/03/2014 6:37 AM
"Why do you want to know?"
He said: "But I was curious as to how a magnetic bottle would be created."
Whence the assumption has come that such a bottle would need to be spherical, is another question.
12/03/2014 10:20 AM
I don't think a magnetic bottle is made from a single inductor, but from a collection of electromagnets, all with their North(1) ends pointed at the 'contained volume' from every direction so their magnetic fields overlap and keep a charged particle 'trapped' inside.
Notes:
1) or South, depending on the charge of the particle you're trying to contain, but they all have to be the same. You're making a 'fake monopole' shell to be the 'lining' of the bottle.
Good Answers: 67
12/03/2014 4:52 PM
Magnetic mirrors ('bottles') are not built that way. Rather, they are made up of a large region of homogenous (zero-gradient) magnetic field that tapers at the ends. The combination of the charged-particle's helical motion and the field gradient at the ends produces an opposing Lorentz force which drives the particle back into the homogenous zone, hence the name 'magnetic mirror.'
The rings in the central section are a kind of 'Helmholtz coil' whose inter-coil spacing is equal to the coil radius (pic not to scale).
12/09/2014 9:47 AM
I stand corrected, thank you.
The only 'real' exposure to magnetic bottles I have has is through Sci-Fi, where they are treated as a way to 'store' dangerous particles, not shape particle beams.
12/17/2014 8:31 AM
Nothing new here.
Register to Reply 66 comments
70AARCuda (1); adreasler (7); Anonymous Poster (1); BigBirdAustralia (1); Crabtree (1); europium mkII (10); HiTekRedNek (3); IdeaSmith (1); James Stewart (7); JohnDG (1); Lookfar (1); lyn (1); NotUrOrdinaryJoe (8); Noudge79 (3); RAMConsult (4); Randall (1); redfred (6); Relativity PL (3); Rixter (3); StandardsGuy (2); Tornado (1)
