Previous in Forum: Bolts   Next in Forum: Effect of Hot Condensate on a Steam Line
20 comments
Difference Between Tube and Pipe
01/16/2015 1:50 PM
I want to know the diff. b/wa tube and a pipe.
Re: wana know about the diff. b/w tube n a pipe.
01/16/2015 1:56 PM
Google it.
01/16/2015 2:07 PM
Tnx alot dear i had already done it. I just wana contact ppl around d world .
Reply Score 1 for Off Topic
Good Answers: 70
01/16/2015 2:10 PM
Get A Life! Your shorthand really sucks!
Good Answers: 151
01/17/2015 12:16 PM
Would you reply to your teacher like that?
Good Answers: 70
01/17/2015 1:20 PM
Oh boy were those the days! I was introduced to that ruler at a young innocent age And the only thing it measured was the amount of pain it inflicted!
Good Answers: 151
01/18/2015 8:53 AM
I'll bet that you learned to use correct English though.
01/17/2015 1:42 AM
the guy wanted to see your pipe and tube.
"When I thought I exceeded to be wise but wisdom was far from me" -King Solomon
01/17/2015 4:02 AM
The inner diameter is a millimeter or two, with considerably greater wall thickness.
Good Answers: 151
01/16/2015 2:09 PM
Try writing using proper English
Tube is specified by its outside diameter for example , 3/8 tube has an outside diameter of 3/8 inch (.375). Pipe is specified by its nominal inside diameter and wall thickness (schedule) for example 1/2" schedule 40 pipe.
In addition tube is usually flexible or bendable, whereas pipe is usually rigid.
Reply Good Answer (Score 5)
01/16/2015 2:17 PM
Thanks sir. Useful information.
Good Answers: 151
01/16/2015 2:33 PM
That's better
You are dealing with professional people here, not your drinking buddies. Even though English may not be your native language, you will find that if you take the time to express your question clearly using proper spelling and grammar, we will take the time to give you a meaningful answer.
01/17/2015 12:21 PM
To Gringogreg #3
I have not heard of this definition before but it makes sense and worth a GA from me.
I was involved on a CEN committee some time ago on a standard where the use of things like tube, pipe, duct, conduit, hose and associated accessories were discussed.
We ran into problems on occasions when the meaning and application of the above words acceptable in one language translated literally into something unintentionally in conflict with common use in another language.
eg, '...rigid hose pipe...' '...permanent quick-release connector...'
Good Answers: 151
01/17/2015 12:44 PM
I was not trying to give a formal definition, but rather a practical distinction between the two terms as commonly used in the US.
Good Answers: 21
01/19/2015 1:26 AM
We have also experienced this problem, where the 'ridgid hose' described by the manufacturer is in fact a pre-formed 40mm steel pipe.
04/12/2015 12:59 AM
George Carlin would have helped you.
01/16/2015 2:39 PM
A TUBE is thermionic "valve" in europe.
A PIPE is a mechanical device for "smoking" tobacco, etc..
Anonymous Poster #2
01/17/2015 12:49 AM
Tube is tubular; pipe is pipular. Vive la difference!
Re: Difference Between Tube and Pipe
01/19/2015 10:17 AM
Tube has more accurate dimensions. You ask for a tube with a certain OD dimension and also get a specific wall thickness with it. Pipe has a wider variance in wall thickness. 1-1/2" SCH40 Pipe, the 1-1/2" is the inside dimension but the actual inside dimension might be 1-5/8" instead.
01/19/2015 5:14 PM
Tube is specify because its outside diameter size and wall thicknes. They are used like boiler tubes or heat exchangers, etc. The outside diameter tolerance is around 0,001 in. Instead the pipes, their outside diameter tolerance is around 12% of the wall thickness and they are specify because their nominal size and schedule.
Reply to Forum Thread 20 comments
70AARCuda (1); Anonymous Poster (1); Casper71 (1); dhayanandhan (1); dj95401 (2); FCORDOVA (1); gringogreg (5); Hilton (1); horace40 (1); Janissaries (1); Kulas (1); lyn (1); mangalraj s hada (2); Tornado (1)
