Solutions for Industrial Computing Blog
The Solutions for Industrial Computing Blog is the place for conversation and discussion about industrial computers, systems and controllers; communications and connectivity; software and control; and power strategies. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Confessions of a Photoshopaholic: Part 3   Next in Blog: How Does Windows 7 Compare to Vista? (Part 2)
34 comments
How Does Windows 7 Compare to Vista? (Part 1)
Posted August 27, 2009 12:00 AM by ETOB
Microsoft's newest operating system, Windows 7, isn't due for release until October 22, 2009, but you don't have to wait until then to try it out. The Seattle-based software company has already released a test version of the OS that you can download and use for free. During testing of some common tasks, I found Windows 7 to be 32.4% faster then Vista, which I will explain in part 2 of this series.
If this sounds interesting, then why not try it out? If you're worried about losing your current files, then try a dual boot setup. This will allow you to install Windows 7 while leaving your current operating system unchanged. It's a very simple install if you just follow the steps below:
  1. Download a copy of Windows 7 RC. You can get a product key from Microsoft here.
  2. Burn this ISO to a DVD. (The downloaded file is an ISO file, which is basically a virtual image of a disk.) There are many free programs on the Internet that will allow you to burn this. Just search Google for "free ISO burner", or (as I prefer) use ImgBurn. You can download ImgBurn for free by clicking here.
    1. Open ImgBurn and select "Write image file to disk".
    2. Browse for the Windows 7 file and select it.
    3. Now select "Write". This will burn your file to the DVD.
  3. Create a new partition for Windows 7 in Windows Vista.
    1. Under the Start menu, right-click the My Computer icon and select "Manage", and then double-click "Storage". Finally, double-click "Disk Management".
    2. Right-click your drive and select "Shrink". The amount you shrink the drive will be the size of the new partition. Make sure it is at least 15 GB for the 32-bit version and 20 GB for the 64-bit version.
  4. Format this new partition.
    1. Select the new unallocated space that was just created and then right-click and select "New Simple Volume".
    2. A "Volume Wizard" displays that will guide you through this process.
  5. Install Windows 7 onto the new partition.
    1. Insert your Windows 7 DVD into drive and run setup.
    2. Select "Install now", then check for updates.
    3. IMPORTANT!!! When asked what type of installation you want, check Custom (advanced). This will allow you to select your new formatted partition, and will not delete your current data.
    4. Wait for Windows 7 to install.
Once your computer has both Windows 7 and your previous operating system, you'll be able to boot into either. When your turn on your computer, just select the OS you'd like to use. All of your files from the other system will still be accessible. If, at any time, you want to delete Windows 7, just erase the partition you installed it on.
Re: How Does Windows 7 Compare to Vista? (Part 1)
08/27/2009 4:36 AM
If at last Microsnot produces a decent OS, then Mrs Cat will buy a new laptop..(I should be curled up on her lap)
I think Microsoft has contributed to the recession by releasing VISTA, it must have hugely reduced sales of PCs.
08/27/2009 9:32 AM
Vista was a very poor release of an OS, even by Microsoft standards. Windows 7's prebeta was even more stable then Vista.
08/27/2009 11:11 AM
Okay, so perhaps this isn't the place, but I didn't think Vista was that much of a failure. Let me explain...
I had Windows XP on my laptop for the longest time and it was okay (3 re-images later, an hour long process apiece). I decided to switch to vista because I was having a problem with XP. It worked well. I had seemingly no issues and once you get used to the differences between XP and Vista, I liked it.
Yes, Vista had a rocky start (compatibility issues, bugs, etc.) which fueled much opposition from computer junkies. But that is why you wait to download so that all the bugs can be fixed. First impressions may mean a lot, but since I waited a couple of months, my first impression was favorable.
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
08/28/2009 8:17 AM
I am in agreement with you on this Jaxy. I have had vista for a year now and I have had no issues with it at all.
Like you I waited till the bugs were out of it and I bought a computer that was made for Vista. It did take a bit of getting used to but for themost part seems to be very stable on my system.
I am however looking forward to windows7 because it is built on the Vista engine but has been revamped to cut back on a lot of the things that run in the background with Vista.
So the way I see it 7 will be a win win for me.
Hobbies - DIY Welding - pipewelder
08/28/2009 4:22 PM
I Agree with you as well and I have not had any bad problems with Vista personally. I am not what I would call (or want to be called one for that matter0)a computer person but I do own several and use a computer every day. I can surf the web, do my work, play World of Warcraft well enough to be productive, have fun and not get fired at work for being a total idiot. When I got my first computer with Vista the changes seemed to be more than usual and it was a little confusing to change over to. Once I got used to Vista it has not been a problem and seems to run faster and has many more features than my old one. I only learn a new system when my old computer dies and I am forced to use a new OS because it is the only one available. I am sure some people that understand the backbone of an OS and computers would say I don't know what the hell I am talking about. They probably have many legitimate reasons why they think Vista is not up to par. Most of these problems are not noticeable to me on the level I use the computer. I actually like Vista better than the one I had before but to tell the truth I would still be satisfied with the old one if I still had it and had never tried Vista.
pipewelder
Good Answers: 16
08/27/2009 1:32 PM
Only thing is Microsoft stopped giving out the Windows 7 Release Candidate (RC) last week.
Also for those running the RC, Microsoft does not make it easy to upgrade to the final version. You will either need a fresh install or use this hack to upgrade.
At this point the final release is widely available online so there's no reason to install the RC.
Kaplin
08/27/2009 3:20 PM
I wouldn't suggest running the RC as your everyday computer, but dual booting makes it easy to evaluate. If you like it and plan to buy it, you would delete the RC partition and upgrade from Vista.
The final release is only available to MSDN and TechNet subscribers, and to volume license customers, unless there is another legal way to get this that i do not know about. Although you cant download the RC from Microsoft anymore, it is still floating around the internet, free to try out before the general public release on October 22. Microsoft is still giving out product keys for it. RC and RTM versions usually have negligible differences, so it is a cheap way evaluate an operating system.
08/27/2009 3:54 PM
Look to see if you can attend one of the Launch Events for Windows 7 and get a free copy!
  • Atlanta - Sep. 28
  • Baltimore - Nov. 9
  • Boston - Oct. 5
  • Chicago - Oct. 20
  • Cleveland - Oct. 12
  • Dallas - Nov. 4
  • Denver - Sep. 24
  • Detroit - Oct. 28
  • Houston - Nov. 9
  • Kansas City - Nov. 4
  • Los Angeles - Oct. 28
  • Miami - Sep. 24
  • Minneapolis - Sep. 24
  • New York City - Oct. 20
  • Orange County - Oct. 26
  • Philadelphia - Sep. 28
  • Phoenix - Sep. 28
  • Pittsburgh - Sep. 30
  • Portland - Oct. 14
  • San Diego - Oct. 26
  • San Francisco - Oct. 20
  • San Jose - Oct. 5
  • Seattle - Oct. 12
  • St. Louis - Nov. 9
  • Washington - Nov. 4
08/27/2009 5:18 PM
Nah, can't see Harlow there
08/27/2009 10:31 PM
Hi All,
I've had the Windows 7 RC running for several months now.
Since XP, I've been using many different linux systems on home PC (most success with Ubuntu, loved it's ease of use and Open source philosophy). I didn't bother with Vista, wifes computer had it and many many issues. I have to admit I haven't been a fan of M$ for many years, found many of thier products poor in many ways.
But I am very impressed with Windows 7, I've found it well designed, and a vast improvement to previous efforts. Logical, easy, makes the computer pleasant to use (as opposed to difficult - VISTA).
To be honest I've moved away from ubuntu, back to using M$, even though I don't like to admit it (IMO it's simply better).
If I could remove the LOGO and Windows / M$ references from the OS - it would be even better.
Just my thoughts, for what they're worth.
Kind Regards,
Anthony
Good Answers: 213
08/27/2009 10:44 PM
How Windows 7 compares to Vista is insignificant. How does Windows 7 compare to a good operating system? How fast is Windows 7 when compared to, say Windows 98 SE or even Windows XP? How does Windows 7 compare to Linux, in whatever flavor you favor? How does Windows 7 compare to Apple's latest version of UNIX? Get real, Microsoft. Your last two attempts have been pretty flakey. You should be thinking more about where you stand in the real world, rather than your imaginary play land...
08/27/2009 10:58 PM
Doesn't Microsoft have something like 90% of the market share for operating systems, they must have a REALLY BIG "imaginary play land..."
Reply Good Answer (Score 4)
08/28/2009 3:02 AM
So far.. faster, less errors, less annoying pop windows (I disabled UAC on Vista), and better organization.
Vista was a new prototype and style. I never buy anything when it first comes out. The second one is better most of the time IMHO.
08/28/2009 3:09 AM
I may not be a completly clued up techie but i don't think that Windows XP was "pretty flakey" i use it on all my home and work computers and find it a pretty good operating system. It does everything I want it to and i haven't had an reall issues with it.
I do agreed about Vista tho!
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
08/30/2009 2:42 AM
"How does Windows 7 compare to Linux, in whatever flavor you favor?"
true. I'm a newbie with Ubuntu 9.04, but have been using Windows since the DOS ages, so I can tell the difference if I see one.
when comparing speed and stability, Linux leaves XP & Vista behind, biting the dust.
booting, responding to mouse clicks, opening & closing applications, running processes, shutting down from Linux is amazingly FAST.
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
08/28/2009 5:13 AM
For the past years I had XP on my computers. I bought recently the HP 8730W mobile workstation and installed Vista64 in combination with a load of HP software.
I run Solid Edge, Algor, gear calculation and simulation software and Adobe photo software. I didn't experience any problems with Vista, all my software runs faster if compared to XP32. I will get free of charge Windows 7 but I'm absolutely not in a hurry to install Windows 7, first I will see what happens with the first service pack.
Willem van Beers
The Netherlands
Willem van Beers The Netherlands
09/02/2009 10:03 PM
I am not a big fan of Microsoft, but it is inevitable that at sometime you will need to use Windows. Vista has improved a lot since its release, but 7 is much better. It was very easy to set up, ALL of my drivers downloaded automatically, unlike Vista, where i had to download my network driver from another computer so i could dl the rest of the drivers i needed. I usually wait a while to buy things from Microsoft, but i am buying this asap, its faster and nicer then Vista, and even has features i wish my macbook had (like the "superbar").
Hobbies - Musician - New Member Technical Fields - Education - New Member
08/28/2009 7:20 AM
I'll probably avoid it until I need to use it. Let's let the bugs run out of the first few versions. I'm actually trying to stray away from Windows now since I installed Ubuntu on an old laptop yesterday. While a different OS provides a learning curve, you have to love that fact that it comes with GIMP and Firefox already installed.
TechoutReach
Good Answers: 58
08/30/2009 2:12 AM
I'm trying to do that, too, but I'm faced with a major snag. No sound is coming out from my laptop's speakers. I can hear it using earphones, though. have you faced any problems? I've installed Ubuntu 9.04 on a dual-boot with Vista Home Premium on an HP Pavilion dv5 laptop.
I've posted my problem already in the Ubuntu forums, but no one has come up with a solution, so far. :(
After solving this, I've yet to enable the built-in devices such as the camera, the DVD-RW, the lightscribe, the fingerprint scanner.
I really want to learn using Linux, but because of this, I'm thinking of giving up on Linux already, or just buying a new laptop with Linux pre-installed.
Good Answers: 119
08/28/2009 8:26 AM
I'm running (on my home computers) Win 7 RC 32 bit on a desktop, dual boot with XP that got hung on an upgrade to SP3. I can't be bothered to fix XP because 7 is much nicer on that older machine.
I also have Win 7 RC 64 bit dual boot on a Vista laptop. I really appreciate not having to turn off all the overbearing security features that I had to on Vista to perform common tasks.
So far my impressions of 7 are very good as compared to XP and Vista. But, caveat emptor, my pc based cad system and related software and not supported on 7 yet, so time will tell.
I would love to move completely to linux but, unfortunately, a lot of the stuff I need to use is not supported.
Hooker
PS - From what I'm hearing, and from past experience, I would not even consider the Win 7 upgrade from Vista. Spend the money and do a completely fresh install.
08/28/2009 11:21 AM
Not unless I absolutely have to.
08/28/2009 11:58 AM
This situation reminds me of the Detroit cars in the late 60's and early 70's. Those vehicles were absolutely abominable. Compared to other vehicles of that era, some were "not as bad" as others. But in light of the decades of automotive engineering available at that time they were very bad. This was when the imports began offering quality and value and took over a large market share from Detroit. (And now of course we are bailing them out.)
08/28/2009 12:34 PM
I would like microsoft make a just as bare ass basic OS Like win 95 or slightly better than 3.1 But have it like a browser is, Basic, streamlined, FAST!!!!!!!!!! and capable of adding plug-ins where needed to be able to do something it can not do bare boned. Instead of this huge bloateware they make now, Let us all decide what we want our machine be able to do. talk about speeding it up!
08/28/2009 2:01 PM
Windows Seven:
BIG BROTHER IS WATCHING MORE CLOSELY THAN EVER.
Here are some highlights from the so-called "privacy" statement:
The information we collect from you will be used by Microsoft and its controlled subsidiaries and affiliates ...
... information collected through one Microsoft service may be combined with information obtained through other Microsoft services. We may also supplement the information we collect with information obtained from other companies ...
We occasionally hire other companies to provide limited services on our behalf ... We will only provide those companies the personal information they need to deliver the service ...
Microsoft may access or disclose information about you, including the content of your communications in order to: (a) comply with the law or respond to lawful requests or legal process; (b) protect the rights or property of Microsoft or our customers, including the enforcement of our agreements or policies governing your use of the services; or (c) act on a good faith belief that such access or disclosure is necessary to protect the personal safety of Microsoft employees, customers, or the public.
Information that is collected by or sent to Microsoft by Windows 7 (M3) may be stored and processed in the United States or any other country ...
THIS IS EVEN MORE INVASIVE THAN VISTA.
So who cares if it is faster or more stable?
If you value your freedom and privacy, avoid this OS like the plague!
_
08/28/2009 2:42 PM
...come with us Sir...mind your head...slip this jacket on please, and the gag.
Mmmmmlllfppphwwrrr...
Sorry Sir I can't hear you....you wish to be locked up? Certainly Sir.
08/30/2009 2:32 AM
Before insinuating someone as insane, or imagining things, you might be interested in reading the full document directly from the source: MICROSOFT --> here.
08/30/2009 3:59 AM
You missunderstood my (British) humour.
The implication is that Microsoft are listening and it is they who are coming to get you.
I was actually backing you up...
<slaps furry head repeatedly with paw>
I prescribe a quick course of Monty Python to sensitize your funny bone.
(BTW there is a clue in my signature)
09/03/2009 1:57 AM
Del:
Thanks for backing me up, but I am not the "Guest" who thought you were insinuating uncomplimentary things about me.
But, of course, you couldn't have known that.
The nerve of these people, impersonating me by posting as "Guest" ...
08/31/2009 8:23 AM
What does it mean, how does W7 compare (i.e., in what ways is it like?) Vista? The question (or one regarding contrasts) as yet doesn't seem to make much sense.
08/31/2009 8:43 AM
What?
What part of 'compare' don't you understand?
They are both operating systems...and thus have similar functions which can be compared.
We are not asking you to compare Ice Cream to Beethoven's 5th Syphony!!!.
Although If pressed I'd say the Icecream offered a more Immediate pleasure, whereas the Symphony was more spiritually uplifting...
09/01/2009 5:44 AM
My dear Puss, the point of the question has been missed. Absent even the fact that W7 has yet to go to market where it can have gained a body of experienced users (who are also experience Vista users), it would have been my hope (and will remain my hope) to learn from discussions such as this:
  1. The ways/instances in which the two systems compare (i.e., are similar if not alike), and
  2. The ways/instances in which the two systems contrast (i.e., are not alike...are strongly dissimilar).
After all that was the original question. As to answers (other than very broad [as well as MS Corp.] generalizations, visceral responses and guesswork), it might have been gleaned from my mention of "as yet" that answers are likely to be less that well informed until the W7 programs is use on a large scale...or even among many CR4 cats.
Ice cream and the Fifth might be said to compare in that each can produce pleasure; to contrast by doing so via different senses.
Thanks for your willingness to assist.
Bell...
09/01/2009 5:52 AM
My dear Puss,
<Prrrr prrrr wubs monitor>
09/01/2009 10:56 PM
steady on there, big fellow!
This "guest" could be from Microsoft!
09/03/2009 8:12 AM
Beg your pardon?
Reply to Blog Entry 34 comments
Anonymous Poster (10); cwarner7_11 (1); double_j_b (1); ETOB (3); Hooker (1); Jaxy (1); Kaplin (1); langyaw (2); LG_Dave (2); NSS (1); pipewelder (1); plancette (1); TechoutReach (1); user-deleted-1105 (6); Willem46 (1); yamdankee (1)
You might be interested in: Waveguide Pressure Windows, Windows, Infrared Windows
