Previous in Blog: The Mysterious Bell Knot Challenge   Next in Blog: Longitude: Newsletter Challenge (06/27/06)
18 comments
Stain: Newsletter Challenge (06/20/06)
Posted June 20, 2006 7:00 AM
The question as it appears in the 06/20 edition of Specs & Techs from GlobalSpec:
Why is it that when a drop of wine or soda dries out on your kitchen countertop, you find a ring-like stain?
wine stain
06/20/2006 2:03 PM
as the outer edge dries, capilary action draws more liquid outward, depositing the solids in a ring.
Ireland - Member - Aging Gracefully Member
Re:wine stain
06/20/2006 4:25 PM
I don't know what happens really...Jeeves cleans up after us.
waidesworld
Definition?
06/20/2006 3:55 PM
What is a "ring-link?"
Friend of CR4
Re:Definition?
06/20/2006 4:02 PM
That should read "ring-like". I've corrected it.
Re:Definition?
06/20/2006 6:51 PM
It could be ring link because it links the unevaporated deposits together. Ok, I might be wrong. This is my take on it. Right or wrong I'll spout it out. The material is suspended in the fluid,and is quite happy to stay there. Essentially, the material is trapped in the fluid and will flow in the direction the fluid is traveling. In this case liquid on a flat surface is will continue to travel to its edges as it eveporates because nothing is holding it like in a cup. what I don't know is why this occurs. Gravity?
"Praise no day until evening, no sword until tested, no ice until crossed, no ale until drunk."
Stain Ring
06/21/2006 12:01 AM
When a drop of wine or soda on the kitchen countertop, the drop is not in a flat surface. Observe carefuly and you can see a convex shape.
The other ring of the drop will be the tinner towards the surface of your kitchen countertop and it dry easy as copmpare to the inner or center of the drop. The fluid will flow in the direction the fluid is traveling. In this case liquid on a flat surface is will continue to travel to its edges as it eveporates as we know that the gravity will pull all partical down.
As the outer ring dry up, fuild will continue to flow towards the ring. That why you get a stain ring on your kitchen countertop
ring
06/21/2006 5:23 AM
It's a fairy ring and thay leave the ring to show thanks for the donation to the Gods
Re:ring
06/21/2006 9:05 AM
Oh yeah, I'm with this guy!
Dried up drops
06/21/2006 9:33 AM
I really don't have that problem, 'cause I don't drink wine or soda, but if I did, I'd bet any spilled drops would spread out because of the detergent and grease mixture that coats my counter tops.
Re:Dried up drops
06/21/2006 9:56 AM
I wouldnt know. I'm Canadian and drink beer.
Re:Dried up drops
06/21/2006 11:02 AM
I give you an "Aye" for that answer.
No Spots Here
06/21/2006 11:18 AM
My dog licks up eveything, so the house is spotless. However, I have spots that seem to magically appear all over my lawn!!!
Re:No Spots Here
06/21/2006 12:02 PM
That is a crop circle in your yard, or did I mis spell crop? Miss
Re:No Spots Here
06/21/2006 12:13 PM
That's too funny!
Re:No Spots Here
06/21/2006 2:08 PM
Of course! Wut else does a dogdo?
Re:No Spots Here
06/22/2006 10:32 PM
Yeah, dog eat, sleep and do the thing they usually do.
Wine stain
06/21/2006 7:00 PM
The ring appears because evaporation at the edge is faster than even a short distance in from the edge, where the surface is flat. This causes flow towards the edge. The higher evaporation at the edge is described by Thomson's law, which says basically that equilibrium vapour pressure increases as the radius of curvature of the liquid surface decreases (as viewed horizontally in this case). It's also a function of surface tension.
Popular Science - Weaponology - New Member Popular Science - Cosmology - New Member
Re:Wine stain
06/23/2006 4:49 PM
Good, but only part of the answer. As the evaporation proceeds from the edge, salt
(or sugar),is deposited.
The higher concentration of solute draws more solution to the outer 'ring` thus the depost is
thicker at the edge of the drop.
Anonymous Hero (2); Anonymous Poster (6); archeryguru2000 (1); Biff Dink Doink (1); Bill (1); Chris Leonard (1); misplayed (1); Pragmatist (1); Simon (2); uniquenickname (1); Waidesworld (1)
