Previous in Blog: Peak Electric Field: Newsletter Challenge (08/03/10)   Next in Blog: Rectangular Floor: Newsletter Challenge (10/05/10)
76 comments
Baseball Force: Newsletter Challenge (09/07/10)
Posted September 05, 2010 5:01 PM
A pitcher throws a 150 g baseball at a speed of 40 m/s. When hit by a bat, the ball travels in the opposite direction at a speed of 35 m/s. The ball and the bat have an impact time of only 1.25 ms. What is the force applied by the bat to the baseball?
And the Answer is:
To calculate the force we must calculate the impulse of the ball at the moment when the ball hits the bat. If we know the impulse, I, we can calculate the force by dividing the impulse by the collision time. The impulse is calculate as the difference of the moments after (final) and before (initial) the collision. In equation form, we have
I = Pf-Pi = m*vf-m*vi
If our frame of reference is such that the direction of the initial velocity (before hitting the bat) is to the left of a standard coordinate system, the impulse value is given as follows
I = (0.150 kg)(40 m/s)-(0.150 kg)(-40 ms) = 12 kg∙m⁄s
The force acting on the ball is, then, given by
F = I/t = (12 kg∙m⁄s)/(0.00125 s) = 9,600 N
Good Answers: 114
Re: Baseball Force: Newsletter Challenge (09/07/10)
09/05/2010 5:14 PM
Baseballs are weighed in ounces not grams!
Reply Off Topic (Score 4)
6
09/05/2010 8:35 PM
F = ma = 0.150 × 75/0.00125 = 9000 N.
Reply Good Answer (Score 6)
Good Answers: 114
09/05/2010 10:57 PM
I avoided that answer since it is an average, but I didn't want to throw another challenge into the mix by saying so.
Yours is clearly the expected answer. GA.
09/06/2010 10:47 PM
I agree with you.
Elasticity doesn't come into it because that is energy absorbed and returned.
Noise, heat and non-elastic deformation would relate to energy absorbed and not returned, and no information relating to those is supplied/available, therefore I believe your answer is the best possible with the given information.
09/07/2010 3:26 AM
Q.E,D,
09/21/2010 8:16 PM
WHERE DID THIS 75 COME FROM? ACCELERATION IS CHANGE IN VELOCITY NOT TOTAL VELOCITY.
09/21/2010 9:31 PM
From 40 in one direction to 35 the opposite direction is a change of 75. Some of the posts actually did the whole arithmetic: 40 - (-35) = 75. Also please ditch the all-caps.
Good Answers: 130
09/21/2010 9:58 PM
Why? - I think all-caps is quite a handy indicator.
Besides - all those uppercase numbers, can make it hard to be heard.
Good Answers: 11
09/28/2010 11:31 PM
Velocity and acceleration are both vector quantities, meaning they have both a magnitude and direction. "The opposite direction" implies that the direction of the ball after the bat hits it is precisely reversed from the incoming direction, so if we define the incoming vector as 40 m/s i, where i is the direction vector, then the outgoing velocity is -35 m/s i. 40 - (-35) = 75.
09/06/2010 6:29 PM
To address the instantaneous forces, we would need to know about the elasticity of the baseball and the bat. Somehow I don't think that's in the cards. Hence the simple approach.
09/06/2010 10:33 PM
Man, y'all can't answer that; ever'body knows baseball is measured in foots and measurin' sizes like that.
09/07/2010 12:06 PM
If you do the conversion it comes out to almost exactly 1 ton (imperial).
Good Answers: 266
09/07/2010 8:05 AM
Home Run
Good Answers: 11
09/07/2010 8:14 AM
C'mon. No one used the Impact-Momentum equation?
09/07/2010 10:15 AM
No ... that would be too impulsive.
Good Answers: 11
09/07/2010 10:17 AM
Shh...no one caught my mistake (including me). Don't say anything about it.
09/17/2010 3:55 PM
F=ma
a= dv/dt
F=m(dv/dt)
F=m(v1-v2)/(t1-t2)
assuming a very small dt (impact time of only 1.25 ms), then 1.25ms may be used to get a fair estimate.
Using Impulse-Momentum theorem
I=dP=F(dt)=m(dv), if you consider the force and mass constant.
F=m(dv/dt)
tom eight toes or tomatoes your choice...
09/07/2010 8:34 PM
I did, only I called it impulse = change in momentum. Got the same answer--9000 Newtons. Takes longer!
With the data given we cannot determine the instantaneous maximum force, because we don't know how the force varies during the contact time. Thus we have to accept an average force assuming it is constant during contact.
Lehman57
09/07/2010 10:13 AM
150 grams!? It must have been a dirty spitball ... or a government ball.
09/07/2010 10:31 AM
Making an assumption of constant force through contact it would simply be delta V over the time. =75 m/1.25ms squared=60 kN
But you really need elasticities, weight of bat, location bat is hit and a few other facts to get closer tho the real forces. I think a bell graph could approximate it where when integrated it would be equal to energy change.
Reply Score 2 for Off Topic
09/07/2010 10:35 AM
ooops forgat the mass .150
F=9 kN
09/07/2010 11:34 AM
so says the first answer
Good Answers: 114
09/07/2010 12:24 PM
I just knew that somebody, probably somebody hiding from the daylight, would get into the technicalities that are not in the original question, that's why I hedged my bets.
09/07/2010 11:52 AM
600n
09/07/2010 12:23 PM
Force is change in momentum over time, so the average is 10kN or 1 mt.
It won't be uniform. If the shock wave is a half-sine wave, the peak is more like 1.6 mt
09/07/2010 12:49 PM
Newton's law of motion applied to system of constant mass:
m = 150gr = 0.15kg
dv = 45+30=75m/s
dt=1.25ms
F=0.15 x 75 / 0.00125 = 9000N
09/07/2010 12:55 PM
If we assume that this is an elastic collision:
F=ma => F=m(delta)v/t = [(0.150kg*(40-35)m/s)/1.25E-3 s]=600 N
09/07/2010 8:43 PM
However, delta v is 40 -(-35) = 75 as others have used.
Lehman57
09/07/2010 1:10 PM
Answer: 9000 N. Explanation: Momentum is conserved in any collision, whether elastic or inelastic. In other words, the sum of bat and ball momenta will be the same before and after impact. Momentum is mass times velocity. Let x = bat mass, a = bat velocity before and b = bat velocity after. We are told that the ball mass is 150 g and the before and after velocities of the ball are 40 and -35 respectively. Note that the ball velocity after the collision is negative because it is going in the opposite direction to the pitch. So we can set up an equation to solve for the impulse (change in momentum) of the bat: (x*a) + (150*40) = (x*b) + (150*-35) ==> x(a-b) = 150(40-(-35)) ==> x(a-b) = 11250 momentum units when masses are in grams. For masses in kilograms, in order to convert readily to force units (newtons, kg*m/s^2) which are in kilograms, divide by 1000, so x(a-b) = 11.250 kg*m/s. The impulse becomes a force (measured in units of newtons, kg*m/s^2) when divided by a time interval, which we are told is 0.00125 s. Force is mass times acceleration, and the change in bat speed (a-b) per 0.00125 seconds is the acceleration (deceleration). Dividing 11.250 by 0.00125 we get 9000 newtons of force for the bat. The short time interval accounts for the elasticity.
09/21/2010 9:48 AM
Momentum is conserved, but that is assuming there are no other inputs acting on the bodies of interest. In this case, there is the force and torque being applied to the bat by the player swinging the bat, so a pure conservation of momentum analysis is invalid due to extra unknown forces being applied.
The F=ma approach applied only to the ball is still valid since the only outside force acting on the ball is the bat, which we are already considering as the force (neglecting air friction and gravity and only looking at the force in the direction of interest.)
09/07/2010 1:32 PM
This is a totally uninteresting question. Of more interest would be, How far does the ball travel?
And of greater interest still, one which is actually pondered amongst baseball folks is, How should the player choose the optimum weight (mass) of the bat to use which will generate the greatest force when hitting the ball.
I cannot look at the leaf of a tree without being crushed by the universe. --Jules Renard
09/07/2010 3:13 PM
For such questions, more information is needed. For the optimum mass, balance, and rotational inertia of the bat for minimum work in hitting a home run, see the analysis at this site: http://www.racquetresearch.com/
Good Answers: 143
09/07/2010 7:57 PM
Not very far. Maybe most the way to second. Real hits run more like 20 kN - 40 kN. This one's a blooper or bunt.
09/07/2010 8:21 PM
Concur,
The ball is leaving with less energy than it arrived.
Good Answers: 114
09/08/2010 9:20 AM
I'll stir the pot a little more.
Is the bat continuing on path or rebounding?
09/07/2010 8:48 PM
He also has to hit the ball at the center of percussion of the bat to get the maximum energy transfer.
Lehman57
09/07/2010 11:52 PM
This is going to vary from one batman to the next, and then also over time for a particular batsman and I venture suggest one possible way to determine this.
The objective is to impart the maximum energy to the ball, and the available energy is a function of the speed of the head of the bat at the point of impact and the mass of the head of the bat.
A high speed camera should be able to record the speed of the bat's head at the point of impact, and if the batsman can swing a number of bats of different masses while their speed is being recorded, then the energy can be calculated for each bat and plotted on a graph. This should be predictive of the optimum bat mass for that player at that time.
09/07/2010 1:42 PM
To do the problem you need a simple physics formula, force (f=ma) or force= mass x acceleration .150 (mass) x 75(acceleration)/ .00125 = 9000 Newtons (N)
09/08/2010 6:14 AM
600N
ie
this much force would be absorbed by the bat
force = mass*acceleration
=mass*(change in velocity / time )
=150*((40-35)/1.25)
09/08/2010 6:40 PM
Wrong!
The change in velocity is 75m/s! - the direction is reversed.
Direction is important, your answer would mean the ball continued in the same direction at a reduced velocity ....
09/14/2010 9:43 AM
I was going to say something about a foul tip but the question clearly states the ball travels in the opposite direction after the impact.
Since the answer showed up so quickly and so many agree it's the right one, who wants to do the calculations for various foul tip angles?
I hope the pitcher is a good fielder, too.
09/08/2010 1:07 PM
I think first we need to know who's on first.
09/08/2010 4:13 PM
Who's on first.
What's on second.
I don't know's on third.
Why's left field.
Because is center field.
I don't give a darn is shortstop.
Tommow is pitching.
Today is catching.
Right field????????
09/11/2010 9:57 AM
I don't know what I'm talking about either!
Is that anything like cricket?
Ken
09/14/2010 12:09 PM
Today we have naming of parts.
09/14/2010 12:39 PM
The right fielder never gets mentioned in any of the known performances/recordings of the famous A&C routine.
09/09/2010 8:35 AM
shoudn't the speed of the bat be included in the equation?
09/09/2010 11:47 AM
If you look at my analysis at #22 you will see that bat speed is taken into account, but it is not necessary to know the exact before and after bat speeds, nor even their difference, in order to solve for the bat force. You also don't need to know how heavy the bat is. Conservation of momentum supplies the answer if you know the ball mass, ball before and after speeds, and the dwell time, as we do here. For more fun with classical mechanics, see Racquet Research.
"Education is lighting a fire, not filling a bottle." -- Plutarch
09/14/2010 11:37 AM
Tornado and JRW got the answer right - he hit the ball a ton
09/14/2010 3:30 PM
F = (mvf – mvi)/∆t m = 150 g = .15 kg vf = 35 m/s vi = -40 m/s ∆t = 1.25 m/s F = [(.15 kg)*(35 m/s) – (.15 kg)*(-40 m/s)] / 1.25 m/s F = 9 kg*m/s or 9,000 g*m/s
09/14/2010 4:29 PM
Forces are measured in newtons, kg*m/s^2. Your answer is in momentum units, and is therefore wrong. Your calculations are opaque, and with no explanation of what you are doing and why. I believe that in an exercise such as this one, which is intended to teach principles of analysis, it does not help to see even a correct dazzling display of math gibberish with no motivation. Jumping right in to the calculations, without pausing to set up the solution analytically, may be what caused the BP blowout and other engineering disasters.
Good Answers: 130
09/14/2010 10:52 PM
Now, there is, a bunt
09/15/2010 8:52 AM
Rule 1.09 The ball shall weigh not less than five or more than 5 1/4 ounces. The average weight would be 5 1/8 ounces.
148.83 grams (5.25 ounces) max.
No one caught that? Must have been a bunt at PETCO park!
Good Answers: 130
09/15/2010 10:11 AM
Balls damp, so it was too slippery to catch.
Ar 'rules' - I love 'rules'
150 g = 5.291 oz umm 0.041 oz or 1.17 g - did the rule specify the resolution of the scales? and or accuracy, like sub 1%.
What are the provisions if the ball gets wet?
What happens to the game outcome if the ball gains or looses 'weight' during a game?
When is the weighing done?
I.e. could one weigh-in a damp underweight ball and have time to 'lighten it' in the microwave?
Just curious
OT obviously
09/15/2010 5:29 PM
The ball is supposed to be 5 1/8 oz ... and 5 1/4 max in play ... the UMP carries 3 balls all the time ... when it rains the ump is supposed to check the ball and put a new one in play, when it is barely drizzling ... they don't play at all when the rain comes down in any substantial amount. They used to play in more rain then they do now ... but too many millionaires were getting sick ... .
If you watch the games the ump will change out a dirty ball also. I don't think there is a scale once the ball is in play ... it is at the discretion of the ump. Just gives us something else to harass the umps about .
On average, they use about 10 balls a gain in the Nationals ... the American league 8 according to my baseball freak friend (yet I suspect more) and those are mostly dry days ... on a drizzling day they must go through them like crazy.
09/17/2010 12:21 AM
this punch has an total impuls of 11.25 kg*m/s, with the duration of 1.25 ms results this in an average acceleration-force of 9000N!
And
DON'T FORGET TO CHANGE YOUR BOOTS!
09/21/2010 2:40 PM
Force = change in momentum
= .150 kg *(40 m/s -(-35 m/s))/0.00125 s
= 90 Newtons
09/21/2010 6:47 PM
Recalculate, you lost two orders of magnitude!
09/22/2010 9:35 AM
We cannot calculate the force on the ball because the contact with the bat is not instantaneous. The best we can do is get the average force over the 1.25 ms. And even then, we cannot calculate the actual average force because we must assume that there are losses such as hysteresis, therefore not all of the work is applied to the change in momentum. We can only calculate the net work applied to the change in momentum.
To sum up, the best we can do is calculate the average force by the impact of the bat on the ball based on the change in momentum due to the net work done.
10/04/2010 7:58 AM
The force doesn't just vary with time; it also varies over the volume of the ball, causing it to flatten out and spring back. We don't have enough information to analyse this complex interplay of force, time and position, so I agree that calculating the net force is the best we can do.
09/22/2010 11:44 AM
IS THE BAT WOOD OR ALUM,
Good Answers: 114
09/28/2010 11:23 AM
Where's this definitive answer then?
probably wouldn't be correct as op seems to have some difficulty with math
the tuesday following september 7th being september 14th
not october 5th...
09/28/2010 1:25 PM
If you assume a half sine shock with a pulse width of 1.25ms and a velocity change of 75m/s, I get a peak force of 14 KN (9611 g's). This is opposed to the F=MA approach which is the equivalent of assuming a rectangular pulse.
09/29/2010 1:03 AM
Why would one assume a half sine shock? As the bat and ball spring back from their respective compressions, they will exert mutual pressure after the maximum pressure occurs.
In reply to #63
09/29/2010 2:33 PM
I guess the question I will ask is why you would assume the force was a constant. In an elastic collision, the force time history would be much more represented by a half sine wave.
Thanks,
Jim
In reply to #64
09/29/2010 2:54 PM
The OP asks for "the force," without distinguishing whether peak or average. Without making further assumptions, which might be complicated, it seemed reasonable to go for the average force. Apparently everyone else also did so until just recently.
MNIce is right that the peak force will be more, but this depends on what further assumptions one makes, such as half-sine, full sine, or other force/time profile.
09/29/2010 3:18 PM
The answer should be 9000 Newtons. The impulse equals the average force times the time of contact. This, in turn results in the change of momentum of the ball. The momentum change is mass*change in velocity = 11.25 kg*m/s or N*s. When divided by the time of contact, the resulting average force is 9000 N.
Prof. R.
10/01/2010 1:37 PM
I think the batter misses the ball pretty good at an angle less than full contact.
Force=kg*m/s^2
120 J coming at the bat
93 J projected by the bat
213 J absorbed by bat
J=N*m
A bunt would give you conservation of energy, with a perfecrly elastic ball the 120 J coming into the bat would be transferred to the ball, so the ball would leave the bat at 40 m/s. However it is possible to add energy to the ball with a really good swing and perfect transfer of the energy by making good contact with the ball. Therefore conservation of energy will also still hold. Simply add the energy of the swing of the bat to the equation.
27=9000*x = 0.003 meter 3 cm = 7.62 in.
The bat is in contact with the ball for 7.62 in OR the ball absorbs the energy difference between the incomming and outgoing Energies. Is this problem a bunt?
Impulse= mv1-mv2= F*s
mv1-mv2=(75m*0.150)/s= F*s
0.150*(-40)-0.150(35)=-6-5.25=-11.25
11.25/0.00125=9000 N
I had fun trying to solve this anyways so I win even if it's the wrong answer
In reply to #67
10/03/2010 2:10 AM
? 0.003 meter 3 cm = 7.62 in.?
0.003m = 3mm = 0.3cm
In reply to #68
10/04/2010 3:22 AM
Your right, my error. 3mm = 1/8 inch. Makes more sense now! Thanks
10/05/2010 11:53 AM
Your answer is off because you used the wrong velocity for the ball after impact: -40 instead of -35. So this line of your solution
gives the wrong impulse. It should be 11.25 and not 12. So the right answer is 9000 N.
10/05/2010 5:43 PM
The Answer given is wrong! - the speed leaving the bat is 35m/s not 40!!!!
10/12/2010 11:34 AM
I think your answer had a typo...the -40 ms should be -35 m/s making the impulse 11.25 kg*m/s and the force 9,000 N.
11/14/2010 4:45 AM
Ref Newton's 2nd law ie.rate of change of momentum (per second) = the impressed force.
Which is 40-(-35)m/sec x 0.15kgs =11.25 mkg/sec has to be divided by the impulse time which is only 1.25 millisecs. which gives 11.25 x 1000/1.25 =9000 Newtons
since 1N = 9.8 kgf. This is equivalent to being hit by a force equivalent to 900 kgs!
11/14/2010 11:38 PM
The initial speed of the ball is 40m/s, the speed after the impact is 35m/s; the difference speed is 75m/s, this is an overall impuls of 11.25kg*m/s equivalent to an average force of 9kN. (just a typing error?)
12/07/2010 1:00 PM
The given solution is calculated wrong. The answerer used 40m/s for both parts of the answer but the directions give 35m/s for the second half of the calculation. the answerer did not use the correct numbers to calculate the answer.
-just the numbers (.150*40)-(.150*-35) = 11.25 not the 12 the OP used because they used 40 in the second half of the equation even thought they specified 35 in the original question.
Using the OP's formula and the original numbers used in the question the answer is not 9600 but instead is 9000 newtons.
Reply to Blog Entry 76 comments
34point5 (3); Anonymous Poster (22); Chris33 (2); cingold (2); corelite (1); dellowitz (1); dswiech (1); English Rose (1); Garthh (1); jim35848 (2); JRW (2); Kenneth Leigh (1); Lehman57 (3); MakeItFly (1); MNIce (1); one2playwitt (5); ozzb (1); passingtongreen (4); Shades78 (1); silvCrow (1); susmithcs (1); tgold (1); Tornado (5); TVP45 (1); WAWAUS (6); WilhelmHKoen (2); wilmot (3); Zadok (1)
