Semiconductor & MEMS Fabrication Blog
The Semiconductor Fabrication Blog is the place for conversation and discussion about manufacturing processing equipment, semiconductor test and measurement, products & services, and semiconductor materials. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Another Technological Paradigm Shift?   Next in Blog: Do SLEDs Have a Bright Future?
6 comments
Much More Than 0? How Much Less Than 1?
Posted October 02, 2010 8:25 AM
The latest development in digital logic will likely take us beyond circuit elements that can only exist as either 1 or 0. A probability engine will prove much more flexible for a wide variety of applications, such as driving search engines that require relatively subtle decision-making algorithms. What advantages do you see in such a capability? What other tasks would an architecture not confined to 1 and 0 make faster? More efficient? What applications that you address at work or in your daily life will be most profoundly affected? How and why?
The preceding article is a "sneak peek" from Semiconductor & MEMS Fabrication, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Semiconductor & MEMS Fabrication today.
Re: Much More Than 0? How Much Less Than 1?
10/02/2010 8:54 AM
Isn't this is what was fuzzy logic that was toted to become more similar to human type thinking pattern?
Good Answers: 213
10/03/2010 12:57 AM
What I would really like to see is 4-state logic:
1- On
2- Transitioning from On to Off
3- Off
4- Transitioning from Off to on
HAT would be a lot more useful than fuzzy logic...
10/03/2010 4:23 AM
Boolean input is fine where a yes/no decision can be made - for setting flags, interrupts, etc. For the rest, there are bytes, words, integers. All of which take only a few microseconds longer to send. The most important decisions can be made fastest, then the rate required can be sent in the next instruction. eg; what to do:stop, how fast:gradual/instant. By the time the brake is activated, the rest of the information is there - emergency stop can be boolean, too.
Madness is all in the mind
10/03/2010 8:20 AM
Problem with discreet programing by using flags, the conditionals required can get quite involved where the program can get rather lengthy. which cuts into the scan time.
p911
Good Answers: 213
10/03/2010 1:17 PM
Which is why I would like a quad set- when scanning a couple of hundred sensors, just knowing the "instantaneous" value may limits the information you can glean from the system. I have set up a two-bit schema that gives me what I want, but, for high-speed changes, it takes too long to catch the critical glitches because of the processing required. Of course, one always has the option of adding more computers...computers are cheap these days.
Of course, "speed" is a relative concept. For instance, if all I am doing is controlling an air conditioner, I generally have all the time in the world, since the "comfort zone" is quite broad. If, however, I am trying to, say, steer a boat in rough seas, the quad system would be most helpful...
10/07/2010 1:24 PM
Guys,
We are talking about multi level systems which have been implemented in communication sytems.
This work has been going on for nearly 30 years, I used to lecture on it but I could not do that today- it is too long ago and much water has passed under the bridge since then!
I am sure that I have a book or two on the topic, if only I can find one of them!
I will rack my brains for references!
Sleepy
Sleepy
cwarner7_11 (2); GM1964 (1); phoenix911 (2); Sleepy (1)
You might be interested in: MEMS Devices, MEMS Processing Equipment, MEMS Foundry
