Previous in Blog: Satellite Mass: Newsletter Challenge (02/01/11)   Next in Blog: A Balancing Act: Newsletter Challenge (04/05/11)
Too Close for Comfort: Newsletter Challenge (03/01/11)
Posted February 27, 2011 5:01 PM
Given a bare planet without an atmosphere - could a satellite be launched (at an appropriate initial speed) that would orbit close to the planet's surface but not touch it?
And the Answer is....
A satellite in this planet can orbit at a speed such that its curved path follows the curvature of the planet. If there is no atmosphere and no obstacles in its path (the planet is bare: no trees, etc.), the satellite with the right orbital speed will continue orbiting the planet following its curvature.
The distance from the planet that the satellite will orbit depends on its initial speed.
The orbiting speed, Vo, is related to the distance R, from the center of the planet by this equation
Vo = sqrt(GM/R)
where G is the gravitational constant and M is the mass of the planet.
We can see that by choosing an appropriate initial speed, we can have a satellite orbiting at any distance from the center of the planet. Therefore, if the planet is bare and with no atmosphere, we can collocate an orbiting satellite very close to the surface of the planet.
Re: Too Close for Comfort: Newsletter Challenge (03/01/11)
02/27/2011 6:45 PM
Yes. If g' is the acceleration of gravity at the planet's surface, a velocity just greater than √(rg') will do the job.
Good Answers: 137
#127
05/03/2011 9:31 AM
That's the answer giving a circular orbit, but any velocity between √(rg') and √(2rg') gives a possible elliptiptical orbit, of increasing eccentricity as velocity increases. Of course it would only be closest to the planet's surface at 2 points of the orbit.
Above √(2rg') (the escape velocity) it doesn't orbit but leaves the planet altogether.
Cheers...........Codey
#130
In reply to #127
05/04/2011 12:19 AM
Good Answers: 137
#132
In reply to #130
05/04/2011 7:21 AM
Not clear what you're saying. Agree or disagree? Please elaborate.
Cheers..........Codey
#133
In reply to #132
05/05/2011 12:07 AM
read error, root sign looks like reziproke ( √(2rg') 1/(2rg) )
Good Answers: 137
#134
In reply to #133
05/05/2011 5:20 AM
OK I think I understand. But you're a man of few words!
Cheers........Codey
02/27/2011 8:44 PM
Ummm... Isn't this Physics 101? Didn't Newton give an example of a (theoretical) canon at the top of a mountain doing exactly this?
And based on the latest definition of a 'planet' the planet would have to be generally spherical (not some oblong shape that might complicate the answer).
02/28/2011 2:47 PM
Yep. Here it is from Wikipedia:
02/27/2011 8:51 PM
The Answer will be posted right here on CR4 on April 5th February 27.
(Gavel drops.)
ξ
Good Answers: 114
02/27/2011 11:15 PM
I suspect that the questioner is thinking more of a shell fired from a barrel, not a maneuverable rocket. If so, the answer is no, it will hit the gun barrel at the end of the first orbit.
02/27/2011 11:42 PM
Nah, you're supposed to duck before the bullet makes its way all around....
(v/2πr for those who wish to calculate.)
02/28/2011 2:35 PM
Not if the planet is rotating. By the time the shell completes one orbit the canon would have rotated eastward (or westward, depending on the planet's rotation direction) and the shell will miss the canon. When a typical LEO satellite launched from the KSC facility in Florida completes one orbit the launch point has moved 22.5 degrees eastward.
There are specific cases where the shell might hit the canon, but there are many possibilities where the shell would not.
02/28/2011 3:26 PM
Correct and it is more complex than that.
KSC is 28.39° N latitude and not on the rotational equator. The result of the orbit, if mapped on a globe and the rotation of the Earth taken into account, produces a ground track that looks more like a sinusoidal wave across the map.
To have the projectile return to the same spot at launch would require that the planet is not rotating or that the launch take place precisely on the equator and launch due east or west of the rotational pole.
Good Answers: 114
02/28/2011 8:36 PM
"To have the projectile return to the same spot at launch would require that the planet is not rotating or that the launch take place precisely on the equator and launch due east or west of the rotational pole."
Exactly what I had in mind, but it is immaterial because in my version of this hypothetical problem, the planet is not rotating. You can do what you wish with yours
02/28/2011 8:58 PM
I really would have like to, but when I went back to check on my version of the hypothetical planet I discovered to my utter dismay that it had been vaporized by a Vogon Constructor Fleet just minutes before.
02/28/2011 9:25 PM
Of course you have your towel!
02/28/2011 9:35 PM
Yup. Haven't thrown that in, yet.
#111
03/29/2011 9:54 AM
Your scaring the "Straights"! Doubt if a lot of readers hitch hike and carry a towel.
In reply to #111
03/29/2011 9:56 AM
You would be surprised!
In reply to #111
03/29/2011 9:58 AM
Better to bring a towel than to listen to some Vogon poetry.
03/01/2011 11:08 AM
Uh.... If the planet is not rotating, are there rotational Poles?
General Note: Design subject to The Laws of Physics....
03/01/2011 11:12 AM
Exactly. That's where the word "or" comes into it.
02/28/2011 5:13 AM
Yes, provided it is launched from the highest point on the great circle that its orbit will follow.
02/28/2011 8:12 AM
I would agree, but that is only true in a perfectly isolated system and the bodies are of perfect spheroid dimensions and homogeneous density. That only exists in theory.
Any irregularity or external influence will, over time, alter the perfect orbit and will end as a crash. This would also include rotation of the bodies, solar winds, etc. Even the launcher represents a mass that is not homogeneous to the rest of the planet.
Remember the laws of thermodynamics?
The way I see it, the original post uses the word planet, which has a common meaning of a rocky or gaseous body. None are of perfect construction.
If the problem was stated as spheroid masses in an isolated universe or system, then it would be a different matter, but the problem was not framed that way.
02/28/2011 8:55 AM
As usual for Challenge questions there's the Information Deficit in operation. A 'stable' orbit is not specified, neither is the number of orbits beore the inevitable.
I agree that in the 'real universe' a very low altitude stable orbit is not on.
02/28/2011 9:16 AM
Nor a high altitude orbit, although, a high altitude orbit will be less impacted by small variations to its environment.
Good Answers: 69
03/01/2011 3:42 AM
Hi AH, you wrote: "Nor a high altitude orbit, although, a high altitude orbit will be less impacted by small variations to its environment."
I suppose one can argue that high altitude circular orbits around planets may last virtually forever, although not at exactly the same shape. Many of the effects on them cancel out over time.
For surface-skimming orbits, I agree that they won't last very long, although pretty low orbits can last for a long time around our moon if they are chosen correctly, at the so-called "frozen orbit" inclinations (Nasa).
-J
03/01/2011 2:59 PM
Here in lies the problem. There are no definitions as to what is meant by "orbit". Is that one revolution, two, ten, or infinite?
I think infinite is a definite impossibility, but to what degree of stability does the challenge demand to be called a success? My guess is that someone did not consider that requirement when crafting the question.
Good Answers: 69
03/01/2011 3:23 PM
"Here in lies the problem. There are no definitions as to what is meant by "orbit". Is that one revolution, two, ten, or infinite?"
I reckon "orbit" must be taken to mean a practical number of orbits, without being boosted in any way. Due to drag, most very low Earth satellites need a boost every few months, otherwise they reenter the atmosphere. But they are still classified as 'orbits'.
This ultra-low orbit with no atmosphere may have some other problems, which need to be overcome, somehow...
-J
02/28/2011 7:37 AM
Define close.
And define the barren planet!
No planet is going to be:
1. Perfectly spheroid in shape.
2. Perfectly homogeneous in density.
Both factors will contribute to orbital perturbation as the gravitational field varies from point to point along the orbital path.
This will produce an imperfect orbit and will not produce a true circular orbit, which will get more eccentric over time. The satellite will eventually contact the planet surface.
This doesn't even take into account any other distant bodies that may have an effect on the orbital status of the satellite.
02/28/2011 9:49 AM
Does this planet have a magnetic field?
What's the composition of the satellite?
I would say no, based on the assumption that the vacuum of space continues right down to the surface of the planet, any satellite launched would continue in a straight line from the launch point...............away from the planet.
02/28/2011 11:13 AM
Only if you exceed the escape velocity for the planet
Ve = √(2GM/r)
It's not the atmosphere that causes things to fall back to Earth.
02/28/2011 2:12 PM
I'm still sticking with no. If it doesn't exceed escape velocity, any gravitational pull is going to crash it.......pretty quick. I would think.
Good Answers: 32
02/28/2011 10:27 PM
Atmosphere doesn't hold things in orbit - gravity does.
johny451
03/01/2011 6:55 AM
I'll just mark myself off topic. Gravity pulls things out of orbit too. I'm thinking that a close orbit wouldn't last very long. I made a couple of guesses, but really, I don't know the answer.
02/28/2011 10:46 AM
This sounds a lot like this discussion.
Engineering Fields - Electrical Engineering - Analog and Digital Circuit Design Engineering Fields - Electromechanical Engineering - Transformers, Motors & Drives, EM Launchers Engineering Fields - Engineering Physics - Applied Electrical, Optical, and Mechanical
Good Answers: 119
03/01/2011 11:49 AM
Correct! This question was asked and answered weeks ago. Search CR4 must not be working again .
02/28/2011 11:09 PM
Based on the little info given, the answer is Not a chance. Even the moon has a gravitational force that will bring down an object after some time. If this planet has no gravitational force acting upon it, Not having an atmosphere = nothing. The satellite will just take off in a straight line and, like the Energizer Bunny, just keep going and going and going until it hits another object. Bounce off and keep on keepin on.
Reply Score 2 for Off Topic
03/01/2011 10:01 AM
??? "If this planet has no gravitational force acting upon it, Not having an atmosphere = nothing"
You do realize that every object has gravity, right?
The planet has gravity, therefore it pulls the object to it, the speed of the object is only slowed by atmosphere (not having any is an important part of the question) so there is no slowing. if launched at exactly the escape velocity you would get a perfect orbit (until some other force acted on it - such as an imperfect surface or magnetic field)
03/01/2011 10:25 AM
The velocity necessary to keep it in orbit doesn't need to be anything like escape velocity. Do this experiment in your head:
  • imagine a satellite in a stable orbit;
  • now give it a boost in the direction it is going (relative to the object it is orbiting);
  • it will move into a slightly higher orbit (may not still be the same shape , and, may cross the original orbit, but on "average" will be higher).
  • You will need to give it a lot of "boosts" before it escapes.
Good Answers: 137
#126
05/03/2011 9:08 AM
That's right, to be more precise, the velocity needed to keep it in orbit just above the surface is escape velocity/√2.
Cheers........Codey
02/28/2011 11:30 PM
Given the dearth of details given in the original question I suspect that the hook here is the Roche Limit.
I'll go with no.
http://en.wikipedia.org/wiki/Roche_limit
02/28/2011 11:55 PM
Yes it could, but if the orbit is never to intersect the surface of the planet there are a few caveats:
1. Release on launch must be perfectly horizontal - angular tolerance is critical for setting up continuous level flight.
2. Launch velocity must be no slower than the orbital radius dictates - slightly faster will create an eccentric orbit, which might be tolerable.
3. Launch velocity must be calculated as an absolute vector, independent of the planet's rotating surface.
4. A small initial (hence permanent) height above ground level is highly desirable for:
a. easing the tolerances of 1. and 2.
b. clearance above the slight equatorial bulge of a rotating planet.
c. allowing an envelope for orbital deflections in the tidal pull of any planetary moons
d. not colliding with tall things that might walk around on the planet's surface
e. a time-dependent allowance for the drag of imperfect vacuum near the planet - even solar wind causes a drag that is measurable.
5. Depending on the velocities involved, Einstein's relativity effects (time dilation in red shift objects) may need to be factored in.
03/01/2011 6:23 AM
Hmmmm
I wonder if there are any planets in the universe which spin at a speed which makes the equator effectively geostationary? For smaller bodies I guess this is inevitable, but, I'm thinking of something with a gravitational pull at the poles comparable with the earth.
03/01/2011 6:45 AM
Interesting! The inhabitants of such a planet would experience no gravity!
To go a little bit further, even the surface material of that planet would have no reason to stay in place, right? Such a planet would soon disintegrate, as layer by layer of its crust would leave to the outer space, while the planet would spin faster and faster (as the angular momentum would have to stay constant.)
I'm too bored (and too busy) to check the maths of it, so I cannot tell if this process will ever stop, though
tkot
Good Answers: 69
03/01/2011 9:55 AM
"Interesting! The inhabitants of such a planet [spinning effectively at surface geostationary rate] would experience no gravity!"
Only at the equator, though...
"Such a planet would soon disintegrate, as layer by layer of its crust would leave to the outer space, while the planet would spin faster and faster (as the angular momentum would have to stay constant.)"
Nope, the constant angular momentum includes the bits that fly off. What remains should not spin faster, I think. It is when stars collapse under gravity and then explode (i.e. super novae) that the core spins faster, not when the outer layers are thrown off due to spinning too fast in the first place.
Me too haven't done the math, so perhaps you are right, after all.
-J
03/01/2011 10:23 AM
I umm'd and arr'd about the spin rate. Started with the same idea as you (the bits coming off each take their chunk of momentum with them), then thought about Iω, then decided the change in moment of inertia was irrelevant.
Imagine a skater spinning with arms outstretched, a brick in each hand. Pull the bricks into the body - it speeds up. But if the arms are kept outstretched and the bricks are released, I think it's clear (if only intuitively) that the skater's spin rate wouldn't change.
Still haven't done the sums, tho'!
03/01/2011 10:51 AM
The case of the odd planet is slightly easier to analyse intuitively. With the skater they are having to hold on to the bricks, which will fly off at a tangent when the skater lets go. On the planet a loose brick on the equator would just stay where it was: incidentally fulfilling the requirements of the challenge; and thereby demonstrating that I wasn't flying off at a tangent when I posted the reply.
Good Answers: 69
03/01/2011 12:16 PM
Hi JohnDG, you wrote: "I umm'd and arr'd about the spin rate. "
We should do more of that, because I think this where the solution lies.
A planet with a reasonably uniform equatorial surface (no high mountains), spinning at just below the 'geostationary surface rate', will have a tiny positive 'g' at its equatorial surface. Hence, no pieces will 'fly off' due to centrifugal forces. A little above that surface, there will be zero 'g'.
If you place a small satellite there, stationary relative to the surface, it will be in a geostationary orbit. If there is no atmosphere, so no winds or changing pressure (buoyancy), the satellite can stay there for a long time. Inhomogeneous density and tidal forces caused by the 'sun' and any moons should not have any significant effect in this particular situation - surface and satellite are affected equally.
I haven't done the calcs, but this seems entirely possible somewhere in the cosmos...
-J
03/01/2011 3:34 PM
Aside - back-of-envelope suggests that for this condition to obtain on Earth, a day would be about 85 minutes long (I think!). Certainly not unimaginable.
Good Answers: 69
03/01/2011 4:23 PM
"Aside - back-of-envelope suggests that for this condition to obtain on Earth, a day would be about 85 minutes long (I think!). Certainly not unimaginable."
I got the same value, but the problem is that Earth's oblateness will increase quite a bit, meaning the radius at the equator will increase significantly, complicating the issue.
Not quite sure how to solve for that - a bit late in my valley (after 11 pm) for starting such math. Will try tomorrow.
-J
03/01/2011 6:56 PM
Must dig out my copy of Fullem and Larf - Tables of the Squishiness of Astronomical Bodies - Uxbridge Scientific Press, 1952 (Hardback edition, poor condition, £0.01 + p&p from Amazon).
Reply Off Topic (Score 4)
Good Answers: 69
03/02/2011 3:19 AM
I wrote: "... the problem is that Earth's oblateness will increase quite a bit, meaning the radius at the equator will increase significantly, complicating the issue. Not quite sure how to solve for that ..."
I've done some calcs now and if correct, one needs an Earth-mass & density planet, spinning about 12 times faster than Earth, with its 'day' ~ 118 minutes long. This will increase the hypothetical planet's equatorial 'bulge' to about 7983 km radius, with a surface speed of about 7.08 km/s. Here the centrifugal force just about cancels the gravitational force (if my sums are right).
So, spin Earth up to about 12 times its present rate, put your satellite on top of an equatorial tower of a height that just makes you weightless at the top (some tens of meters high). Take away the tower and you have a geostationary satellite - or not?
-J
Good Answers: 69
In reply to #64
03/02/2011 11:00 PM
I wrote: "So, spin Earth up to about 12 times its present rate, put your satellite on top of an equatorial tower of a height that just makes you weightless at the top (some tens of meters high). Take away the tower and you have a geostationary satellite - or not?"
The 12 times spin rate will only work if the final 'earth' has the same density as Earth today, which will not be the case. The density of a fast spinning sphere goes down, because the volume of an oblate sphere is V = 4/3 pi a2b, which is larger than the non-spinning sphere, where a is the equatorial radius and b the polar radius.
The difference is not very large, since 11 times spin rate (period ~ 130 minutes) will still do the trick of (almost) balancing the surface gravitational force with the centrifugal force at the bulging equator (radius ~ 8480 km). Like all artificial satellites, this tiny geostationary satellite just above our heads would also need occasional thrusters for station keeping. The moon's tidal effect will likely be the biggest cause for instability of the orbit.
-J
PS: I've used the 'flattening' equation from http://en.wikipedia.org/wiki/Equatorial_bulge, together with standard Newton forces. It is a headache to solve, because both radii (a and b), period T and density ρ are variables. I cheated by employing the 'Goal Seek' tool in MS Excel.
In reply to #69
03/03/2011 9:39 AM
Just as an aside. I'm surprised to see (without taking the squashed shape into consideration) that because Jupiter spins in less than 10 hours the weight at the equator is about 10% less than at the poles. About 2½ times earth weight at the poles and about 2¼ times earth weight at the equator.
In reply to #77
03/03/2011 9:45 AM
Don't forget though that Jupiter is a gas giant planet. So the surface that takes 10 hours to traverse the planet is actually a cloud formation and not solid material. The storms that happen here on Earth travel much faster than anything fixed to our crust.
03/03/2011 4:06 PM
Not quite the same thing, but an interesting side-note I think, in that they are 'geo'-stationary to each other: [From Wikipedia]
Charon and Pluto revolve about each other every 6.387 days. The two objects are gravitationally locked, so each keeps the same face towards the other. The average distance between Charon and Pluto is 19,570 kilometres (12,160 mi). The discovery of Charon allowed astronomers to accurately calculate the mass of the Plutonian system, and mutual occultations revealed their sizes. However, neither indicated the two bodies' individual masses, which could only be estimated, until the discovery of Pluto's outer moons in late 2005. Details in the orbits of the outer moons reveal that Charon has approximately 11.65% of the mass of Pluto.[4] This shows it to have a density of 1.65 ± 0.06 g/cm3, suggesting a composition of 55 ± 5% "rock" to 45% ice, whereas Pluto is somewhat denser and about 70% "rock".
Good Answers: 69
#81
In reply to #80
03/03/2011 10:49 PM
Hi Usbport, very interesting lateral thinking!
Apart from the fact that the 'launch' of such a satellite will be a bit difficult (although I suppose 'launch' can mean many things(a)), this will surely do the same trick as a planet that spins fast enough to keep a very low satellite geostationary.(b)
How low (or "close to the planet's surface", as the challenge states) you can come before tidal gravity breaks up one or both the bodies is also a bit of a question. But again, the question leaves it wide open. Pluto and Charon surely co-exits...
-J
Footnotes:
(a) Charon may have formed by another body colliding with Pluto, with the debris field coalescing into a moon, much like our own moon is thought to have formed. I suppose that's a form of 'launch'.
(b) For those who have joined in late and could not not read the whole lengthy thread, the reason for 'geostationary' is to make the gravitational field that the satellite 'sees' as uniform as possible. This also avoids obstacles most effectively. Neither is the case for satellites moving across a non-homogeneous planet's surface and they may prematurely crash into the planet (or need an excessive amount of station keeping fuel).
03/02/2011 2:24 AM
Exactly. I was wrong...
tkot
03/02/2011 2:47 AM
...but I wonder if the planet would disintegrate anyway, due to the centrifugal forces. For example, let g be the acceleration of gravity at the surface. Then g = ω2r. If now we take a point inside the planet, at r/2 from the centre, then the gravitational acceleration there would be 8 times lower (assuming constant specific weight) but the centrifugal force will be just twice as less. Similarly for other points inside the planet, it seems that gravity always falls short to hold the planet together.
I did some math in a rush; I hope I'm not ridiculously wrong!
tkot
In reply to #63
03/02/2011 4:08 AM
If this argument were to hold, would there not be points inside the Earth where the centrifugal force is greater than the gravitational attraction, so making the Earth fly apart?
Maybe we rely on the Stickiness factor to keep us together (see Appendix IV, Table (c) in the reference I gave in #57 ).
In reply to #65
03/03/2011 2:10 AM
Don't forget that the layers above those points you mention will themselves apply a pressure to the points below. In the case of the super-fast spinning planet though, all points would be loose.
Of course, the assumption that in such a case all points will rotate at same angular velocity ω might be wrong. Sooner or later the various parts of the planet will move in different ways. Maybe we will also see the sphere getting distorted to a number of rings...
tkot
In reply to #70
03/03/2011 3:32 AM
Ok, what I was doing was a bad job of trying to point out was an error in your sums.
You said "... at r/2 from the centre, [then] the gravitational acceleration there would be 8 times lower ... ".
For the whole planet, the acceleration due to gravity at the (equatorial) surface is:
gp = G.Mp / Rp2
where Mp is the mass of the planet, and Rp is the equatorial radius.
With half the radius, the mass (assuming uniform density) and radius are given by:
Mx = Mp/8
Rx = Rp/2
so the surface gravitational acceleration would be:
gx = G.Mx / Rx2 = G.(Mp/8) / (Rp/2)2 = G.Mp/2.Rp2
=> gx = gp/2
In reply to #71
03/03/2011 4:26 AM
OK right, I better return to my chores, otherwise I will make fool of myself again! Indeed, since my university years I remember the gravity being reduced linearly inside a planet as you approach the centre...
Anyway, it seems that if the spin is too fast at the surface, it is too fast for any point inside the planet: Both gravity and centrifugal are inversely proportional to the distance from the centre. So in the one thing I was right (?) is that the planet will disintegrate.
tkot
Good Answers: 69
In reply to #72
03/03/2011 5:49 AM
tkot wrote: "Anyway, it seems that if the spin is too fast at the surface, it is too fast for any point inside the planet: Both gravity and centrifugal are inversely proportional to the distance from the centre."
I think this is only true for uniform density, which is not the case for real planets - they are less dense at the surface than at the center. So a progressively increasing spin will probably throw off the surface layers first...
This same effect probably also further complicates the calculations that I made above on the zero-g equatorial surface.
-J
#84
In reply to #73
03/04/2011 2:27 AM
Of course. The only comment I would make is that I wonder whether a super-fast spinning "planet", as the one described, would ever create a denser core. Let alone that it wouldn't have been a sphere in the first place! It would tend to oblate, slowing down at the same time, as the angular momentum would have to remain constant. The issue is that the various layers will not slow down at the same rate, therefore there will be quite some turmoil due to collisions of the various parts of the planet. I wonder what shape we would eventually get. Of course the initial speed (inflicted by a macaroni monster entity?) is a factor, but the formation of a number of rings is a possibility. What do you thing?
tkot
Good Answers: 69
#85
In reply to #84
03/04/2011 6:33 AM
"I wonder whether a super-fast spinning "planet", as the one described, would ever create a denser core."
All fast spinning planets that exits (i.e. don't disintegrate due to 'over-spin') should have denser cores; even fast-spinning neutron stars have them. Sure, they would be oblate, as I roughly calculated for the critical spin rate of an Earth-like planet: 11 times Earth's spin rate and ~ 8500 km equatorial radius (post #69). The polar rate should be roughly half of that.
This obviously assumes that the planet formed with this spin rate, not the unrealistic case of 'spinning the planet up' after its formation. Further, Earth's slow loss of spin rate is due to the tidal effects of the Sun/Moon combination, not due to internal friction between layers, AFAIK. I think this is generally so for rocky planets, but not necessarily for the gas giant outer-planets.
Over-spin-rate planets would probably not form in the first place. The only possible way I can think of for 'over-spin' is a collision between planets, but then the portion of the mass that does not escape should form a double planet with both spinning at or below the critical rate.
-J
In reply to #85
03/04/2011 10:22 AM
Here's an OT of an OT.
Hal Clement wrote a fascinating series of science fiction books. The starting book of one of his series, "Mission of Gravity", deals with life on a planet that has a collapsed matter core that is spinning so fast that it has a non-collapsed matter crust. At the axial poles of this planet the gravity is so intense that light gets bent enough that the horizon appears to be noticeably above the level plane. To the inhabitants, this region is known as the bowl.
I don't know if the book is still in print. I hope it is, his writing always fascinated me. Hal Clement passed on in 2003.
Good Answers: 69
#87
In reply to #86
03/04/2011 11:20 PM
Hi Fred, interesting!
The 'critical spin rate' for an Earth-like planet, assuming a uniform density (which is not natural) is about 11 times our present spin. The makes one weightless (0 g) at the equator (r_e ~ 8480 km), but at the poles (r_p ~ 4250 km) some 2.2 your weight.
Not quite enough to make a 'bowl' at the poles, just very flat. The planet's surface cannot really spin faster, because it will start to disintegrate at the equator. I'm not sure what would happen when it has a collapsed core, a huge void and then an outer shell. Should be interesting to look at.
-J
PS: When I looked up values in my post #85 above, I noticed a wrong word in there, changing part of the sentence to nonsense: "I roughly calculated for the critical spin rate of an Earth-like planet: 11 times Earth's spin rate and ~ 8500 km equatorial radius (post #69). The polar rate should be roughly half of that". Should be polar radius, not rate. :(
In reply to #87
03/04/2011 11:40 PM
I didn't make my point very clear about the unique Physics of this proposed planet. Near the axial poles the crust is relatively thin because of the lack of a centrifugal force. So the effective gravitational pull at the poles is significantly higher at the poles than near the equator. The gravity at the poles is so high that light noticeably bends. On the surface it only looks like one is in a bowl. From orbit the planet itself looks like a squashed sphere. The equatorial diameter is many times (my vague memory says five times) the axial diameter. An added societal implication for the creatures that live near the poles is that they have no concept of falling. A plummet of anything by a centimeter is instantaneous and always a catastrophic event.
Good Answers: 69
#90
In reply to #88
03/05/2011 1:50 AM
Yes, this sort of scenario is indeed possible with 'exotic' material, e.g. neutron stars. I'm not sure if a 5 times flattening ratio is possible, but if it is, one may have a bearable 'g' at the equator and an extreme 'g' at the poles. Light will then be bent visibly and the 'flattish' polar regions will have an apparent horizon above the horizontal.
-J
Good Answers: 130
#91
In reply to #90
03/05/2011 1:59 AM
Good Answers: 130
#89
In reply to #87
03/04/2011 11:59 PM
Or maybe it just looks like
#95
In reply to #87
03/09/2011 3:45 PM
Hi, what is the reason for some 2.2 your weight at the poles ?
The corpus is flat in your consideration, has an elliptical profile. With less mass under our feet gravity should be significantly less than 1 (normal).
And I'm going to place my guess to main question just here for convenience (and off-topic points perhaps, I'm not so familar with the rules here):
Yes. Because all contributors seam to agree to the anticipation of that fast spinning planet, where the satellite is only to be held up a little bit high to destination height and released there.
If the planet would not be spinning that fast, the satellite would tear the planet in its spin/direction and thereby looses its own velocity and descends. Its Einsteins distorting of time/space by moving masses. Gravity spirals. But don't know about the maths here.
In reply to #95
03/09/2011 5:41 PM
Hi Jo (?), welcome.
Without going into any maths or technical discussion - standing at the equator you'd be like a bob-weight on a long string (equatorial radius of the planet), but near the poles you'd be like the same bob-weight (same mass), going round at the same rate, but on a short string. Spot the difference in string tension?
There are also some differences in the distance from the centre of mass to consider.
(Few rules here - check out the CR4 rules of conduct and anything else goes).
Jeez I've just read 'em - there's hunerts of 'em. Just be careful.
Good Answers: 69
#97
In reply to #95
03/09/2011 11:48 PM
Jo Yardman wrote: "what is the reason for some 2.2 your weight at the poles ?"
An Earth-like planet spinning at 11 times Earth's rate would bulge out to about 8,481 km radius at the equator and 'flatten' at the poles to about 4,254 km radius. The gravitational acceleration is g = -GM/r2, with GM for Earth ~ 3.9866 x 1014 m3/s2. This gives g ~ -22 m/s2 at the poles, which is about 2.2 average Earth gravities (of -9.81 m/s2).
-J
Good Answers: 130
#98
In reply to #97
03/10/2011 12:03 AM
And there I was thinking gravity related to mass - no matter what the shape or velocity.
Good Answers: 69
#99
In reply to #98
03/10/2011 1:31 AM
Hi 34point5, actually, shape has more to do with it than what I gave it credit for above. The value of g = -GM/r2 is only strictly valid for homogeneous, spherical symmetrical masses. Earth is close enough to that for all practical purposes, but my '11-times-spin' planet is probably not.
My intuition is that such a planet's polar gravity will be slightly less than the 2.2g of the equation, but we'll have to research that further.
-J
In reply to #99
03/10/2011 2:08 AM
Many moons [!] ago, I saw a derivation showing that for a homegeneous spherical solid, the integral of gravitation of all particles equals that of a concentrated mass at the center. I don't recall what would happen with a sphere as graded shells of varying density, or a hollow sphere. It seems that an oblate spheroid would spread out the vectors so as to decrease the total gravitation from a pole to the center. I'm too rusty to tackle it now, but I would guess you are right.
This has gotten far afield from the original problem. I took it as a "pure" exercise assuming a non-lumpy spherical planet, and ignoring the perturbations of other bodies. Tidal effects would also degrade a simple circular orbit over a long time, but to me the "spirit" of the problem avoided such complexities; hence my answer in post 1.
Usually these things are "answered" within a week or month, about half of the time incorrectly; but in this case the OP says April 5, so we haven't heard yet....
Good Answers: 130
#101
In reply to #100
03/10/2011 10:22 PM
Well let's hope the 'math answer' doesn't vary too much from what is apparent in that Saturn eclipse shot ...
Good Answers: 130
#102
In reply to #99
03/10/2011 10:42 PM
I look forward to your re-think as my intuition says; 1 or less, due to increased distance of the equatorial mass - like tending to zero g in the center of a doughnut.
Mind you, you would be 'closer' to the 'math resolved' center of gravity ...
I wonder if things get lighter or heavier when lowered down a deep mine?
I don't think rotation has anything to do with it - or a revolving flywheel would be 'heavier at the axle', then again it might be and I just haven't noticed.
Good Answers: 69
#103
In reply to #102
03/11/2011 12:46 AM
Hi 34point5, the effective gravity at the poles are surely always stronger than at the equator. However, when the proper ellipsoidal shape is taken into account, I think we get a value for the poles slightly less than for a spherical shape (as I indicated in #99).
This seems to be confirmed by the WGS 84 Geoid, but I must first find time to study it more deeply...
-J
In reply to #71
03/03/2011 5:56 AM
Forget 'equatorial' - it's irrelevant here .
I was thinking ahead (to the balancing act).
In reply to #65
03/03/2011 8:27 AM
In your hypothetical faster spinning Earth half radius model I do not see the planet flying apart by centrifugal force. I see the square of the velocity varying with the radius, and the gravitation so it requires geometrically more velocity as one goes deeper into the Earth to maintain zero g. As you have noted, gravitation varies directly with the radius of a body. And if the surface velocity is such that an object is weightless on the surface, the velocity must be lower anywhere within the same rigid body.
However, in your model the outer shell surrounding your half radius sphere also has gravitational force, as if you have a two body relationship. Somewhere in between the center and the surface may be a point of lowest "weight?" Possibly a future "Challenge?"
Finally, any body with the gravitation of the Earth must have attracted an atmosphere, perhaps ruling it out as the "planet" in the problem?
I agree with Jorrie that one requirement of the thought exercise is that one must specify that the object must have sufficiently altitude to clear all surface eccentricity.
Accountable
In reply to #75
03/03/2011 9:01 AM
"In your hypothetical faster spinning Earth half radius model I do not see the planet flying apart by centrifugal force ..." - neither do I. Please re-read, checking the context.
In reply to #76
03/03/2011 10:02 AM
My error. I see I was associating your reply.
Accountable
#82
In reply to #75
03/03/2011 11:45 PM
this point is equal the center of the planet/body where all the gravitaitonal forces will be equal from all sides.
Good Answers: 114
03/01/2011 8:42 AM
The Moon, relative to the Earth?
#83
03/03/2011 11:46 PM
or a black hole?
03/01/2011 8:07 AM
I guess that this could be possible in a pure "Newtonian" world. But in real world, every object which is in orbit around a planet, transmits gravitational waves. This leads to a gradual reduction of its speed and the object starts to get closer to the planet. (However, this loss of energy is reeealy small and this procedure will take reeealy long time.) [There are other factors, of course, that could disturb its orbit, like e.g. cosmic radiation.] As a result, its orbital motion can not last forever.
George
03/01/2011 8:15 AM
So how come the Moon's getting further away? .
03/01/2011 8:44 AM
Due to tidal effects, the spin of earth slows down, therefore in order to keep the angular momentum of the system constant, moon has to accelerate, so it moves to a higher orbit.
tkot
03/01/2011 8:55 AM
(Well I know that - 'cos I heard a program about it on the wireless, and Googled it to check. I was questioning the assertion in the post to which I was replying.)
03/01/2011 10:10 AM
Since it is a planet, it revolves around a sun (or star). The effects of such sun's gravitational pull on the planet and the fired shell must be taken into account.
03/01/2011 10:32 AM
Further, if the mass of the satellite, in relation to the planet, is too high, then the revolution of the latter will cause a certain amount of wobble in the system.
03/01/2011 10:13 AM
Of course it could. Since "close" was not given a specific number i.e. feet, yards, km or miles, it obviously can be done.
03/01/2011 10:44 AM
Exactly the critical point IMHO. This challenge has again posted a nebulous set of criteria so that any result could be the intended answer. Too close and the satellite collides with a mountain or tidal forces cause the satellite to morph into a ring. Too far away and and the gravity well of the star is more dominant than the planet.
To be fair to the author of this puzzle, crafting a puzzle that contains all of the critical information to solve the puzzle is a difficult task. This is particularly difficult to craft for an audience of engineers for we solve puzzles as a living.
03/01/2011 10:25 AM
Yes but! Any surface or density irregularities will cause perturbations in the orbit. The orbit will not be self sustaining over time.
03/01/2011 2:47 PM
This seems like a no-brainer. What does the atmosphere, absence or presence, have to do with it? There are rockets right now functioning in places with no atmosphere, some of them designed to, eventually, orbit small and bare planets, like Mercury, "close to the ... surface." The fact that they are not "launched" from the planet is immaterial. So the answer seems to be, simply, "Yes," but it raises another question, namely, "why is this a question?" or, perhaps, "is there any reason it could not?" to which the answer is "No." Jwatersphd
03/01/2011 3:13 PM
You wrote, "What does the atmosphere, absence or presence, have to do with it?"
Everything. Atmospheric drag will force a stable orbit to decay. Even our own low-Earth satellites require small periodic corrections to remain in orbit due to minute drag of air at those altitudes.
2star (1); 34point5 (6); Accountable (3); Albionix (1); Anonymous Hero (10); Anonymous Poster (3); bioramani (1); bkar (1); cerchier (2); Codemaster (4); cold_fusion (1); DaveFuller (1); ddk (1); dheknesn (2); Doorman (1); G.K. (1); Gene Hayes (3); integrator (1); Jimh77 (1); Jo Yardman (1); JohnDG (18); Johny451 (1); Jorrie (17); jwatersphd (2); kramarat (3); Kreitoc (1); mikejm224 (2); mjb1962853 (1); notohp2002 (1); passingtongreen (3); pminch (1); Randall (7); redfred (8); tkot (7); Tornado (4); Usbport (4); Waldo120 (2); WilhelmHKoen (6)
