The Engineer's Notebook Blog
Previous in Blog: Engineering Summer Camp   Next in Blog: Cool Stuff Around the Web
10 comments
Top 9 Lifehacks
Posted July 10, 2013 10:45 AM by HUSH
Pathfinder Tags: advice lifehacks
Bad advice can come in many forms.
It can come from your Mum, who tells you that you are in fact, "quite special." It can come from your Dad, who tells you to stick up for yourself against the bully, despite that fact he's 7 feet tall. Your guidance counselor in school could always tell you to "get into teaching - there are tons of jobs there!" It can come from Miss Cleo, who read your tarot cards and knows your destiny.
But there is a source for advice that's never wrong: the internet! Ok, not true. But yours truly has waded through the tide of rubbish, porn and cat pictures that is, in essence, the information highway. MacGuyver had his own makeshift fixes, so it's time for some of our own. Here are the top 9 life hacks (pro tips, good advice, etc.) as chosen by HUSH (because Top 10s are so overrated).
  1. Validate a credit card in your head: Each credit card is composed of a 16 digit card identification number. Beginning with the first character, and continuing with every other individual number, multiply by 2. Now take these products and add them to the original numbers which you did not double; if one of those products is a two-digit number, sum those digits as if they were individual (i.e., a 12 would become a 1 + 2). If the final sum is not divisible by 10, then the card is likely invalid.
  2. Open that candy: If you're having trouble shearing open a bag of candy or chips with your hands, and you don't have scissors or a knife handy, a less-obvious solution is to place two coins on opposite sides of the bag and pull them towards each other.
  3. Walk like an Egyptian penguin: In the winter, the most common reason for falling on ice is due to weight being shifted between each foot, resulting in an acute contact angle between the feet and ice. Instead, walk with your weight concentrated on the lead foot, which is how penguins stay upright in the Antarctic.
  4. Clean the microwave: Cook a bowl of water for 2-3 minutes on high power. The steam will loosen and moisten any stains for easy cleaning. Adding a little bit of lemon juice will remove lingering odors.
  5. Make a log stove: Take a tree log a foot in diameter or more and at least two feet long and stand it up. Now, make 4 or 5 lengthwise cuts in through the log, but do not complete the cut. Instead, leave about 25% of the length untouched. Stuff the cuts you made with newspaper and light them aflame.
  6. Household handy: Use a rubber band strung across a paint can to wipe off your brush; place a folded Post-it note below the hole when drilling drywall to collect any debris; put a rubber band between a stripped screw and the driver to remove that stubborn hardware.
  7. Beer me: Make a floating cooler by cutting a pool noodle in to sections and then looping them with a rope around a plastic container, and putting some salt in the ice water will cool the beer much faster; put a clean cup full of ice into the middle of a beer pitcher to keep it cold; putting a coaster on top of your pint glass is universal sign that indicates "I'm coming back."
  8. Express elevator: In a hurry but have a crowd in the elevator? Press the door close button and press your desired floor's button at the same time and hold for at least 5 seconds. Many elevators will take you directly to that floor first. In a similar vein, if you're stuck at a street corner waiting for the walk signal, press the crosswalk button in patterns. For those buttons that do still work (many are non-functioning), there is a code which will change the traffic lights in your favor.
  9. Grocery getter: Use a carabineer (which you may already have on your keychain or in your auto) to loop many grocery bags onto a single handle. If you need to carry several large bottles, use a hockey stick and thread it through the handles.
Well folks, that's all I got. Any you think that should be added to this list?
Resources
/r/protips;
/r/lifehacks
Re: Top 9 Lifehacks
07/10/2013 12:10 PM
Hogwash!!!! All these tricks but not one of them uses any duct tape?
Re: Top 9 Lifehacks
07/10/2013 11:48 PM
Even duct tape can't cure lame.
Reply Score 2 for Off Topic
Re: Top 9 Lifehacks
07/11/2013 2:26 AM
Sorry, I didn't get past the cat pictures
Re: Top 9 Lifehacks
07/11/2013 8:55 AM
Number 1 makes no sense. When would I ever need to verify if a credit card has a valid number or not? Seems like an idea for a bar bet, though too complicated for most folks once they've had a couple drinks.
Number 9 is hilarious. I bet no one within 5 miles of me owns a hockey stick, plus, around here those would be called jugs, not bottles.
Here's one I've used related to #4: When a dishrag or sponge starts to smell funky, dampen it and put it in the microwave for 30 seconds on high. Afterwards it will be really hot for a few seconds but the funky smell will be gone. The microwaves kill the bacteria that cause the bad smell.
Re: Top 9 Lifehacks
07/11/2013 9:12 AM
can you imagine walking into an crowded elevator, then have a guy come in and hit the express sequence.......
  • I can see the response....wtf, you past my floor,
  • mine too...
  • hey where is this going?.....
and the last guy in, is the first gut out at the top floor.
Good Answers: 15
Re: Top 9 Lifehacks
07/11/2013 12:11 PM
Washing old headlights with toothpaste really clears them up well.
Ignorance is no sin. Willful ignorance is unforgiveable.
Re: Top 9 Lifehacks
07/15/2013 9:10 AM
Number 8 is wrong on both counts.
The elevator trick works for certain brands of elevators, and not for others, and even then only for certain versions of the elevator control software. But it NEVER does what is described. Rather, if you've pushed for an UP elevator (for example) and the first on arriving is headed down, step in, push and hold the UP button, and IF the elevator was not already called to a lower floor, it will reverse directions and go up. The same works both directions. But there is no provision in standard elevator software for skipping all other floors and going directly to yours.
If anyone wants to try it, and can make it work (try it on an empty elevator, select several buttons, THEN try the trick listed to bypass them. Then try it again, but only on an elevator where several buttons were pushed before its arrival on your floor (possibly use an accomplice on the lower/higher floor? I leave it to the tester to work out and report the details.). I'll be MOST surprised if you find it works.
The crosswalk trick might work in some countries, but here in the US, there are not now, and never were, "button pattern controlled" cross-walk lights. Some impatient people will "finger dance" on the button, to be sure. But the actual switching of the lights is controlled by an algorithm involving the time since the last vehicle was sensed crossing the intersection and the time since the FIRST push of the crosswalk light control button. Every push of the control button after the first is ignored. The timer control function that checks when the last vehicle passed is reset by successive vehicles, but at a lower interval value, based both on how long it was since the preceding vehicle, and the frequency of resets, as well as time since the entire cycle was started.
But the finger dance doesn't change a thing, except give watchers uncontrollable fits of the giggles, perhaps.
Re: Top 9 Lifehacks
07/15/2013 9:14 AM
Ref number 8, there IS an interesting trick you can do at many stoplights (but try not to get caught, as it is against the law in most locales). A strobe light flashing at a particular interval, where it is "visible" to a sensor in the intersection, may cause the lights to automatically and immediately shift in your favor. This is used to allow emergency vehicles the right of way. That is also why it is illegal for YOU to use it. And you'd have to acquire or build the strobe with the right color light and flash rate/pattern to make it work. I won't provide the details, but have seen construction projects for the lights in the past.
Good Answers: 114
Re: Top 9 Lifehacks
07/15/2013 7:09 PM
Why are these called "hacks"? There is almost nothing new here, and that which is new is useless, the only new thing is they are called hacks here.
I can see why, using a not-from-the-maker code to change a DVD player to "all regions" is called a hack, it changes something in a way the maker didn't intend.
I have a similar problem with "meme". Every time i think I know what it means someone uses it outside of the definition. It will soon be so broad as to be completely meaningless.
Re: Top 9 Lifehacks
07/15/2013 7:21 PM
I don't think I would ever use #1 and 8, but the rest are good, especially the rubber band for a stripped screw. I plan on trying that one. The log is a nice idea if you have a chain saw. Might take a lot of work if you only have a hand saw. I might try it with an electric hand saw that I have.
LakeGrl
JPool (1); LakeGrl (1); lyn (1); Lynn.Wallace (1); micahd02 (2); passingtongreen (1); phoenix911 (1); Usbport (1); user-deleted-1105 (1)
