Construction Tools & Equipment Blog
The Construction Tools & Equipment Blog is the place for conversation and discussion about Trucks, Cranes & Earth Moving Equipment; Construction Tools; Safety, Maintainence & Repair; and Smart Machines & Management Software. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Drones to Deliver Construction Payload?   Next in Blog: New Mobile Crane Hits the Highway
21 comments
Acoustic Levitation Signals New Wave in Lifting
Posted March 05, 2014 12:01 PM by Engineering360 eNewsletter
The crane of the future might not be made of steel or weigh in at a few dozen tons. It might not even take up any space or be visible to the naked eye. That's because tomorrow's crane could be something taken for granted every second of every day: sound. Experiments in acoustic levitation being conducted by scientists in Japan are proving that it's not only possible to lift fine grains of sand utilizing carefully projected sound waves, but also common commercial construction products like nails, screws, wood, and even liquids. Watch a video demonstration of this weightless wonder crane.
Editor's Note: This news brief was brought to you by the Construction Tools & Equipment eNewsletter. Subscribe today to have content like this delivered to your inbox.
Re: Acoustic Levitation Signals New Wave in Lifting
03/05/2014 9:20 PM
This might work as a tractor beam in space....I still don't have a read on the energy required to levitate matter...ie: watts per gram......but I think they are still tweaking the frequency...
http://arxiv.org/ftp/arxiv/papers/1312/1312.4006.pdf
03/06/2014 4:37 AM
"In space, no one can hear you scream."
03/06/2014 8:59 AM
I think you need to have air.
03/06/2014 10:18 AM
Possibly laser generated ultrasonic waves...? The waves being used are ultrasonic in nature, they cannot be heard....
http://extras.springer.com/2003/978-0-7354-0117-4/cdr_pdfs/indexed/305_1.pdf
03/06/2014 10:25 AM
No air (or other medium), no sound. Not even ultrasound.
03/06/2014 11:13 AM
Well if the laser light is used to vibrate the material at ultrasonic frequencies, it might have the control effect of steering something....no?
" The physical principle is of thermal expansion (also called thermoelastic regime) or ablation. In the thermoelastic regime the ultrasound is generated by the sudden thermal expansion due to the heating of a tiny surface of the material by the laser pulse. If the laser power is sufficient to heat the surface above the material boiling point, some material is evaporated (typically some nanometres) and ultrasound is generated by the recoil effect of the expanding material evaporated. In the ablation regime, a plasma is often formed above the material surface and its expansion can make a substantial contribution to the ultrasonic generation. consequently the emissivity patterns and modal content are different for the two different mechanisms."
http://en.wikipedia.org/wiki/Laser_ultrasonics
03/06/2014 11:24 AM
No medium, no sound. End of. May be able to move a grain of sand in space by radiation pressure, given a sufficiently powerful laser and enough time, or maybe by boiling some of the surface away and using the vapour as a kind of jet, but that's it. No tractor beam. Sorry.
03/06/2014 11:36 AM
Then what are they talking about in the "conclusions" statement at the end of the study....
"Conclusion
In conclusion, we have demonstrated an extended acoustic manipulation by which millimetre-sized
particles can be levitated and moved three-dimensionally by localised ultrasonic standing waves
generated by ultrasonic phased arrays. In addition to the presented examples, we also tested other
small objects such as a feather and droplets of alcohol and a colloidal solution.
In a future work, we will use 25 kHz transducers instead of the 40 kHz type. Then the 4-mm node
intervals by 40 kHz transducers will be extended to 8 mm. This would enable the manipulation of
larger particles.
It has not escaped our notice that our developed method for levitation under gravity suggests the
possibility of developing a technology for handling objects under microgravity."
03/06/2014 11:44 AM
A micro-gravity environment does not have to be a vacuum environment. For this sound based technique to work in micro-gravity there must be an atmosphere to move.
03/06/2014 11:53 AM
Where does a micro-gravity environment exist that has an atmosphere?
03/06/2014 12:12 PM
Really, I have to name the obvious.
The International Space Station has an atmosphere.
03/06/2014 12:48 PM
Well for one thing I thought that was zero gravity...for another I don't see much room for this type of equipment....
For another, it's quite noisy on the space station....
http://gizmodo.com/5971285/in-space-nobody-can-hear-you-scream-because-its-fcking-noisy
What would be the use of such technology in the space station?
03/06/2014 2:20 PM
To again state the obvious, this is not my project and I have never been to the space station. I have no stake or inside knowledge in this research at all. Thus my answer is just a WAG.
I know that one of the problems they've encountered in micro-gravity fabrication experiments is any tweezer or other tool used to manipulate the fabricated widget deforms the widget. This ultra-sound movement technique might allow manipulation without deformation.
03/06/2014 3:30 PM
Your haughty derision is a wasted effort here, however I thank you for your time and effort....
03/06/2014 2:24 PM
Oh, the more accurate term is micro-gravity. "Zero gravity" implies the incorrect idea gravity does not exist. If gravity didn't exist then the station would not be in orbit around the Earth, Sun, etc.
03/06/2014 3:16 PM
In micro-gravity you would not need as much power to move objects. It would need to impart only small amounts of acceleration and not overcoming 1g earth gravity. So I expect it could be made more compact for use in space.
03/06/2014 11:52 AM
What Fred sed.
03/05/2014 10:38 PM
A surprise crash of cymbals could be levitating. Just scale up to 106 decibels....
03/05/2014 11:10 PM
If I crank Up my sound system I can raise the neighbors....
03/06/2014 7:36 AM
Interesting! I wonder if this is how they make a hover board?
03/07/2014 5:02 PM
Can't remember his name, but 15-20 years ago, an acoustic/rf experimenter was doing this with bowling balls in his garage. Had his equipment confiscated several times and was labeled a 'kook'. I'll look up notes when I get home and repost.
geraldpaxton (1); JohnDG (4); redfred (5); Rixter (2); SolarEagle (8); Tornado (1)
