IHS ESDU Blog Blog
IHS ESDU Blog
IHS ESDU provides validated information, insight and tools for engineering design. ESDU analytical methods and tools and rigorously evaluated data collections are used to assist and improve fundamental design and analysis in safety-critical industries such as Aerospace & Defense, Oil & Gas, Chemicals and Nuclear, and in Academia and Research. ESDU provides guidance on more than 1500 specific topics in a variety of aerospace, mechanical, structural and process engineering areas such as aerodynamics, aircraft noise, aerospace structures, composites, fatigue, stress and strength, vibration, heat transfer and fluid mechanics. Click here to watch a video and learn more.
Previous in Blog: The Need for Validated Design Methods to Complement Computer Simulation   Next in Blog: ESDU Challenge: Sound Propagation
4 comments
ESDU Challenge: Fighter Aircraft Wing Design
Posted June 20, 2014 12:00 AM by SavvyExacta
Pathfinder Tags: ESDU
In this new series from IHS ESDU, challenge questions will be posted for the community. Some questions may require calculations and others are general knowledge questions.
Here's the first question:
In the design of a fighter-type aircraft a wing is proposed with quarter-chord sweepback of 50 degrees and an aspect ratio of 4. Will it exhibit pitch-up or pitch-down behaviour at high angle of attack?
And the answer is:
Pitch-up. You can find more information in Sketch 5.1 of ESDU 01005, if you're an ESDU subscriber.
Visit the IHS ESDU website for more information about the validated design methods, or to request a trial subscription.
Re: ESDU Challenge: Fighter Aircraft Wing Design
06/20/2014 6:05 AM
It seem like it should pitch down at high angles of attack.
As the flow detaches at the root of the wing, the resulting vorticity down the sweep of the wing should help flow stay attached further aft. With lift reduced on the forward portion but maintained at the rear, it seems likely to exhibit pitch down behavior.
If it isn't already apparent, this is not a field in which I am well versed, so this isn't much above a WAG on my part. I am interested to see if intuition is helpful or misleading here.
06/20/2014 7:39 AM
Not my field at all. My thinking though, is that at a high angle of attack the wing is at a steep angle to the air and lift is almost all due to ram pressure on the bottom of the wing. With a sweep back, the larger surface area at the rear means the rear of the wing will have more pressure on it than the front, thereby generating a pitch-down force (torque).
[And I have a feeling that aircraft designers will laugh at my explanation!]
06/21/2014 6:00 AM
Pitch down as the lift is greater on the trailing edge of the wing.
06/21/2014 9:09 AM
I would hope pitch down, for stability.
IQ (1); Rixter (1); truth is not a compromise (1); Usbport (1)
