IHS ESDU Blog Blog
IHS ESDU Blog
IHS ESDU provides validated information, insight and tools for engineering design. ESDU analytical methods and tools and rigorously evaluated data collections are used to assist and improve fundamental design and analysis in safety-critical industries such as Aerospace & Defense, Oil & Gas, Chemicals and Nuclear, and in Academia and Research. ESDU provides guidance on more than 1500 specific topics in a variety of aerospace, mechanical, structural and process engineering areas such as aerodynamics, aircraft noise, aerospace structures, composites, fatigue, stress and strength, vibration, heat transfer and fluid mechanics. Click here to watch a video and learn more.
Previous in Blog: ESDU Challenge: Sound Propagation   Next in Blog: ESDU Challenge: Calculating Mach
5 comments
ESDU Challenge: Toothpaste Flow
Posted July 04, 2014 12:00 AM by SavvyExacta
Pathfinder Tags: ESDU
In this new series from IHS ESDU, challenge questions will be posted for the community. Some questions may require calculations and others are general knowledge questions.
Here's this week's question:
How would you characterize the flow of toothpaste at room temperature?
a) Newtonian flow
b) Non-Newtonian, viscoplastic
c) Non-Newtonian, shear-thickening
And the answer is:
b) Non-Newtonian, viscoplastic. An initial shear stress (tube squeeze!) is required to initiate flow, and the more you squeeze, the faster it comes as the substance thins. ESDU 97034 gives guidance on this and other Newtonian and non-Newtonian flows
Visit the IHS ESDU website for more information about the validated design methods, or to request a trial subscription.
Re: ESDU Challenge: Toothpaste Flow
07/04/2014 12:32 AM
More precisely Bingham plastic....
07/04/2014 3:09 AM
I also vote 'b'.
Good Answers: 114
07/04/2014 8:27 AM
"In this new series from IHS ESDU, challenge questions will be posted for the community. Some questions may require calculations and others are general knowledge questions."
No calculations were required so categories of toothpaste flow are general knowledge???
07/04/2014 8:54 AM
That would be b:
http://www.youtube.com/watch?v=xe6UtZgo1Jw
07/04/2014 4:46 PM
Once again, I find myself being contrary.
Depending on the particular toothpaste, thixotropic behavior may be exhibited.
While many properties of the two are similar, the fillers used will impart different physical characteristics on the fluids they are in.
In broadest terms overall, I'll go with b, with some reservations.
lyn (1); passingtongreen (1); Rixter (1); SolarEagle (1); truth is not a compromise (1)
