IHS ESDU Blog Blog
IHS ESDU Blog
IHS ESDU provides validated information, insight and tools for engineering design. ESDU analytical methods and tools and rigorously evaluated data collections are used to assist and improve fundamental design and analysis in safety-critical industries such as Aerospace & Defense, Oil & Gas, Chemicals and Nuclear, and in Academia and Research. ESDU provides guidance on more than 1500 specific topics in a variety of aerospace, mechanical, structural and process engineering areas such as aerodynamics, aircraft noise, aerospace structures, composites, fatigue, stress and strength, vibration, heat transfer and fluid mechanics. Click here to watch a video and learn more.
Previous in Blog: ESDU Challenge: Toothpaste Flow   Next in Blog: ESDU Challenge: Cabin Noise in a Gulfstream III
5 comments
ESDU Challenge: Calculating Mach
Posted July 11, 2014 12:00 AM by SavvyExacta
Pathfinder Tags: ESDU
In this series from IHS ESDU, challenge questions will be posted for the community. Some questions may require calculations and others are general knowledge questions.
Here's this week's question:
An aircraft travels at a true airspeed of 700 kn at a geopotential height of 10000 m in the International Standard Atmosphere.
At what Mach number is the aircraft flying?
a) 1.2025
b) 1.5
c) 0.75
And the answer is:
a) 1.2025. To learn more, subscribe and view ESDU 68046 which provides the relationship and various parameters necessary to determine the relationship between Mach number and true airspeed in the International Standard Atmosphere.
Visit the IHS ESDU website for more information about the validated design methods, or to request a trial subscription.
Re: ESDU Challenge: Calculating Mach
07/11/2014 12:34 AM
a.
Good Answers: 109
07/11/2014 2:47 AM
700 kn = 1296.4 kilometers per hour
Speed of sound at standard conditions ca. 1225 km/h
This will get less at heigth and with lower temperature.
So its not C)
To quote the wiki:
So, an aircraft traveling at Mach 1 at 20°C or 68°F, at sea level, will experience shock waves in much the same manner as when it is traveling at Mach 1 at 11,000 m (36,000 ft) at −50°C or −58F, even though it is traveling at only 86% of its speed at higher temperature like 20°C or 68°F
This means we are not to far off from A)
Speed of sound about 1050 km/h --> about 1.2 Mach
07/11/2014 9:47 AM
Easy enough. Speed of sound at altitude and temperature...
KTAS = 29.06 √(518.7 - 3.57*32.8084kft) = 582.3 kts @ 32,808.4ft
700/582.3 = 1.202 mach
Assumes that temperature at altitude = -3.57°F for every 1,000ft and 59° F as standard temperature at sea level.
32.8084kft = 32,808.4 ft or 10,000 meters altitude
Good Answers: 88
07/11/2014 9:51 AM
Speed of sound on air at 10km height is around 1075 km/h, that is 0.88 times the sea level speed of sound. Now the mach ratio is relative to that local sound speed. Doing the math, the closest value from those given is a). S.M.
07/17/2014 8:41 AM
Forgot where I left my E6B...
Anonymous Hero (1); IdeaSmith (1); Rixter (1); SimpleMind (1); SolarEagle (1)
