IHS ESDU Blog Blog
IHS ESDU Blog
IHS ESDU provides validated information, insight and tools for engineering design. ESDU analytical methods and tools and rigorously evaluated data collections are used to assist and improve fundamental design and analysis in safety-critical industries such as Aerospace & Defense, Oil & Gas, Chemicals and Nuclear, and in Academia and Research. ESDU provides guidance on more than 1500 specific topics in a variety of aerospace, mechanical, structural and process engineering areas such as aerodynamics, aircraft noise, aerospace structures, composites, fatigue, stress and strength, vibration, heat transfer and fluid mechanics. Click here to watch a video and learn more.
Previous in Blog: ESDU Challenge: Calculating Mach   Next in Blog: ESDU Challenge: Spoiler on a Wing
5 comments
ESDU Challenge: Cabin Noise in a Gulfstream III
Posted July 18, 2014 12:00 AM by SavvyExacta
Pathfinder Tags: ESDU
In this series from IHS ESDU, challenge questions will be posted for the community. Some questions may require calculations and others are general knowledge questions.
Here's this week's question:
Sub-boundary-layer counter-rotating vortex generators were selected to reduce cabin noise in the Gulfstream III aircraft. The use of co-rotating generators of a similar size would probably:
a) increase the maximum effectiveness and improve downstream persistence
b) decrease the maximum effectiveness and improve downstream persistence
c) increase the maximum effectiveness and decrease downstream persistence
And the answer is:
b) Decrease the maximum effectiveness and improve downstream persistence.
ESDU 93026 gives examples of the practical application of vortex generators to aircraft. ESDU 93024 and ESDU 93025 give guidance on the aerodynamic principles and design of vortex generators for controlling shock-induced separation.
Visit the IHS ESDU website for more information about the validated design methods, or to request a trial subscription.
Re: ESDU Challenge: Cabin Noise in a Gulfstream III
07/18/2014 11:24 AM
Co-rotating VG should slightly improve the vortex persistence. Even though sub-boundary layer, even 25% of the BL in depth, these can disturb 75% of the BL.
Co-rotating VG should slightly decrease the desired effectiveness. This is a WAG, made because Gulfstream Aerospace selected counter-rotating VG's, and the purpose of the exercise was to decrease cabin noise. This is the trade-off.
So, I'll say the answer is 'B'.
07/18/2014 11:25 AM
a....but I guess it depends on the design...
07/19/2014 12:23 AM
I change to c....
07/18/2014 7:57 PM
'B' is the correct answer.
The 'reveal' of the correct answer to the other challenge question has been very consistent in avoiding elucidation of critical or even counter intuitive phenomena. The correct answer is clearly just an indication of which of the provided choices is the best fit without slipping up suggesting possession of understanding, reason in the correct direction, or any clues along those lines to others.It has taken me a while, but not only have I selected the correct answer, but I also got it right by not attempting discussions about the involved phenomena.
07/19/2014 9:56 PM
Just issue a Telex Airman 850 Lightweight ANR Headset for each seat.
If you want a real challenge, try to cancel the blade passage cabin noise in a Beech Starship.
Doorman (1); lyn (1); SolarEagle (2); truth is not a compromise (1)
