Workbench Creations Blog
Workbench Creations
Previous in Blog: How Would You Fix It? Garage Foundation   Next in Blog: Del's DIY Bow Making Thicknesser
35 comments
Bad Capacitors Make Me Smile
Posted October 17, 2014 8:00 AM by frankd20
I know bad components aren't something a person should usually be happy about, but in my case, they have been a source of joy on a number of occasions. They could be yours, too.
Our company recently had an electronics recycling day, which they do about every 6 months. While I get rid of stuff, I also look for things that I might be able to fix.
In this case I found a 47" Philips LCD TV model 47PFL3603D/27 that had been left for dead in the box of what I can only assume was its 50" replacement. What I look for in a piece of electronics that I might consider fixing is one that does nothing when the device is plugged in. I imagine many folks who deal in electronics know that when a device does absolutely nothing once plugged in, the problem tends to be the power supply. Not that power supply problems are always fun, but they tend to be an easier part to repair or replace.
In the case of this TV, when I plugged it in--lo and behold--it did nothing: no lights, no sound, no clicks, nothing. And that made me happy.
Identifying the problem
Upon opening up the back of the TV, which required a torque driver and the removal of a number of screws, I inspected the power supply board. Power supply boards are usually easy to recognize due to the capacitors and transformers on them and this one was no exception.
One thing that tends to be a very common problem for electronic devices, particularly power supplies, are bad capacitors. Over time they dry out and fail, or the parts used were simply not adequate for the long term. The nice thing about failed electrolytic capacitors is that when they fail, the top bulges due to the internal pressure, and this can be easily identified. In the case of this power supply board, it was obvious that four capacitors had failed--they were bulging as can be seen in the pictures.
The failed capacitors on this board were three 2200uf 25v and one 1000uf 50v. I ran out to the local electronics store and purchased three 2200uf 35v and one 1000uf 50v capacitors as shown in the picture.
When I replace a capacitor I try to put in a part with a higher voltage spec if it is available. I would have done the same for the 1000uf but they didn't have one in stock. The total cost for these parts was about $4. I am sure you can find them even cheaper online but I didn't feel like waiting.
Replacement
Installation of the capacitors is mostly straight forward:
  1. Unplug and remove the power supply board
  2. Unsolder the old ones
  3. Solder in the new ones
If you haven't done this before you need to pay attention to the polarity of the capacitors and also be wary of residual voltages which are stored in other capacitors on the board. I often will use a screwdriver or other tool with a good insulated handle and short the connections of any larger or higher voltage capacitor on the board to drain the voltage before I work on it. I also used a multimeter to check all the fuses on the board, in this case they were still good.
On this particular board I noticed that the connections to a transformer that is used to provide the high voltage for the back lights were a bit burned. While I think these were probably still working, I added some solder and a little copper wire to connections to keep the heat down in the future.
The moment of truth
I reinstalled the power supply board and plugged in the TV, and less than a second later I heard a click of a relay indicating something was working. I pressed the power button and the screen lit up, briefly displayed the manufacturer name, and then said no signal since I didn't have it connected to anything. Success.
This is not the first TV or electronic device I have salvaged that has had this problem. In fact, six months ago at a previous recycling event, I got a Samsung TV with similar issues. Someone made a nice video showing how to fix it. http://www.youtube.com/watch?v=XoQcAThf1Ow. There is even a website dedicated to electronics with bad capacitors: http://www.badcaps.net/
Now if I could only get the people who throw these out to include the cord, stand, and remote, I would be much happier.
Good Answers: 67
Re: Bad Capacitors Make Me Smile
10/17/2014 11:00 AM
Burglars broke into a coworker's apartment a few years ago. They took the usual, easily-fenced items like his stereo and TV, and so forth but, in their haste, left the power cords and connecting cables.
Evidently whomever they tried to fence the goods with wouldn't accept the incomplete kit, and so the burglars returned the next day and relieved my coworker of his cords and cables.
Good Answers: 52
10/17/2014 3:05 PM
That doesn't sound so good for your coworker too bad he didn't catch them. I could understand that used things don't sell well without the accessories. For this TV and I think many the cord is a standard type used on many laptops that I was able to find. I bought a universal remote for it also, and while not perfect does the job. Not that I shop at places that would have stolen goods but if I was to buy a working tv without the cord and remote I would expect to pay a very discounted rate. Hopefully the police recover his stuff and catch the criminals.
Good Answers: 67
10/17/2014 3:22 PM
Never caught 'em. I can't imagine being robbed two days in a row. I think he's since had a security system installed, with cameras and a DVR. All the trappings of Justified Paranoia.
Back to finding things tossed out that are easily and simply repaired, I was riding my bike after work and spotted a very nice, late-model microwave oven sitting out on the curb for trash pick-up. I went back home, returned in my car, put it in the trunk and took it home.
The high-voltage rectifier was bad. That's all. I replaced the rectifier and had myself a brand-new microwave oven for five bucks in parts and a few minutes' effort. Not bad. Not bad at all.
It's amazing what people throw away, isn't it?
10/18/2014 10:27 AM
They make a thing to prevent burglar re-entry (or entry in the first place), called a shotgun. Nothing strikes more fear into the heart of a burglar than the sound of a 12 gauge shell being racked into the chamber of a pump shotgun. Heck even if anti-gun, your coworker could simply record that sound, and put it on a loop connected to a motion sensor, follow it up with a large dog barking. If it were me I would get the gun, and sit in the dark, just waiting, but I am an A type hole.
10/17/2014 6:12 PM
I too have to admit I love the crappy capacitors they put in high end stuff!
I have a pair of 32" NEC HD monitors on my home computer that retailed for around $3200 a piece brand new. I got them for $100 each and they took less than an hour combined to fix because both had a pair of shorted capacitors in their power supplies.
Same capacitors same location on each and about $1 a piece of I had replaced them with new ones.
I also have a 30" HD TV's in my daughters room and our master bedroom that I got for next to nothing as well because they had a bad capacitors in their power supplies.
10/18/2014 12:42 AM
Some time ago my father had picked up an off-brand Lcd television from Radio Shack. It lasted him a couple of months before it started blacking out on him. Since it was mounted to the wall, and he had no warranty coverage, he put up with it for a while until it was finally not worth going through the shut down- power back up process that would keep it running. After giving up on it, it sat somewhere for the longest time until I finally got around to looking at it. It turned out that there were a couple of faulty capacitors soldered into the video drive unit. The way I was able to track this down was that I noticed right before the video would black out, that there was a very high pitched squealing sound. Sure enough when I got in there to pinpoint the sound, I found 3 capacitors that were starting to bloat. In fact I think one of them even had the bottom lid completely popped out. I had to match them up as best I could (even ended up ordering higher farad rating with no consequence), and wait for them through mail order. But to this day that television is hanging on the wall seeing plenty of use.
I thought I'd post this because it might just help somebody else. And avoid having to throw out a rather expensive piece of equipment, all for the cost of a couple of new capacitors.
10/18/2014 4:03 AM
Well done and thanks for posting!!
I try and go up a temperature grade as well as a higher voltage (if the higher voltage ones will fit! as they are often also physically bigger for the same value), especially with Japanese electronic equipment...built for a "life".
I also replace ALL the Electrolytics, more expensive, but makes for better reliability in the end, assuming that replacing the damaged ones fixed the initial problems.
I have even added small (cheap CPU ones) fans to reduce the possibility of overheating in some units as well of all components, including hard disks, quite recently in a HD SAT receiver for example.......
Wiki had this to say about temperature and expected life with Electrolytics:-
High-quality aluminum Electrolytics (computer-grade) have better performance and life than consumer-grade parts. High temperatures and ripple currents shorten life. Typical basic Electrolytics are rated to work at temperatures up to 85 °C, and are rated for a worst-case life of about 2000 hours (a year is about 9000 hours); commonly available higher-temperature units are available for temperatures of 105 °C.
A very old friend of mine does it in quite a big way in spite of a job with a lot of traveling and little spare time....he is far better at deciding what to repair than I ever was!!!
I see you have gone "metric" with your Ohmmeter/Multimeter by the way!!!!
Have a great day.
Good Answers: 67
10/18/2014 3:22 PM
Solid-electrolyte tantalum capacitors are preferable where cost-effective in spite of their higher prices, especially as ripple filters in switch-mode power supplies where electrolytics don't perform as well at the much higher ripple frequencies. In some cases using electrolytics for this job may in fact contribute greatly to their premature failure.
Good Answers: 52
10/20/2014 10:16 AM
I mostly replace with what is easily available because I don't want to wait. Lucky for me we still have an electronics supply house in town so I can usually get the part I need the same day.
I changed it to multimeter, spell check must of changed it and I missed it.
10/20/2014 4:22 PM
Good Answers: 25
10/18/2014 7:07 AM
When I visited my brother in U.S in 1991, he had just thrown away land line phone "Bell" brand as it had stopped working. I brought it to India just opened it and found that volume control cord had come out. I resoldered it and it started working. It is still working without any problem. We Indians are thrifty people and try to use the things to maximum stage. We would rather get any gadgets repaired at repair shops instead of just throwing it off. We have many repair shops here.
Good Answers: 42
10/18/2014 12:10 PM
You need cheap labor for that. When a phone costs $50 new, and the shop time is $100/hr, you cannot afford the time to open the case.
10/18/2014 12:46 PM
I figure my labor is indeed cheap, when I am the one supplying the work. I will work for hours and hours on my home projects, including alternative energy sources, at no charge. That is cheap research.
Good Answers: 67
10/18/2014 12:54 PM
When you could have used that time meanwhile making good money doing something else, is it really as cheap as you say? What's your time worth?
Good Answers: 42
10/18/2014 1:02 PM
If you can't sell your spare time, or that is your recreation time, I guess it makes some sense.
(Golfing for the average person is a total waste of time and money, unless you value the recreation.)
Good Answers: 67
10/18/2014 1:12 PM
Yes, in that context, it does, but the example was the labor rate of a hundred dollars an hour 'repairing a 50-dollar phone' versus repairing it yourself for 'free.' Unless you repair 50-dollar phones for recreation, spending hours repairing one yourself when you could have made several hundred dollars in that time doing something else is not a good use of your time. It is not 'free labor' by any means. Rather, it is lost income to the tune of several hundred dollars minus the 50-dollar cost of simply buying a new phone outright.
Good Answers: 67
10/18/2014 3:35 PM
I agree. Being thrifty is an admirable quality, but only cheap parts and labor make that kind of 'thrifty' possible. When the labor and/or component/subassembly costs approach or surpass the cost of replacing the entire unit outright, then 'thrifty' becomes 'tossing it and buying a new one'.
Good Answers: 25
10/19/2014 7:05 AM
I agree with you all that labor cost is very cheap here so you can get gadget repaired. To-day's labor cost is $1.00/ hr.(approx). Also cost of repair shop is also low in urban areas. Many self employed young persons manage the shop themselves all alone.
Good Answers: 42
10/19/2014 6:54 PM
$1/hr ??
General Minimum wage here in British Columbia, Canada, for unskilled labor is about $10.25/hr CDN.
Now if you are self employed you can pay yourself as much or as little as you want. You are free to go broke, without any safety net.
But the person you hire has unemployment insurance protection - as the small business owner you do not have that privilege -- go figure.
Good Answers: 67
10/19/2014 7:11 PM
I bet their reasoning is that some fraction of unemployed 'small business owners' really aren't and would simply register as a 'small business' in order to sponge-off the benefits.
The 'One bad apple ruins the whole barrel' rationale. That's my guess, anyway. Everybody loses thanks to a few miscreants.
Good Answers: 67
10/19/2014 7:02 PM
What about parts costs at one of these shops? Say, a consumer-grade 4700 uF electrolytic capacitor, 50 WVDC? What would you as a customer expect to pay at one of these shops (I just picked this part 'out of the air,' but a part that you actually paid to have replaced would be a far better example).
Good Answers: 25
10/20/2014 6:56 AM
I would like to clarify further. $1= Rs.60(local currency) which means Rs.600/ day for 10 hrs. daily work. Per month it works our Rs.600x25=Rs.15,000/- which sufficient earning for low middle class worker in India.
Regarding prices of components, they are reasonably priced as most of the parts come from Taiwan or Korea.
Good Answers: 67
10/20/2014 7:16 AM
"reasonably priced" as compared to what? What's 'reasonably priced' there may be considered absolutely rock-bottom dirt cheap here, as with your labor costs. If someone there charged his customers what here would be considerable a reasonable labor rate, for example, they'd run the guy out of town for trying to gouge his customers. He'd never make it. Conversely, if he charged here for his service what he charges there, he'd have plenty of work and to spare, but he'd starve to death.
A lot of our components are made in China. El Cheapo. But that capacitor, even if of Chinese make, costs a couple of dollars here - several hours' worth of labor charges there. Is that what they would charge there for this part, what we pay? I doubt it. What's reasonably priced in one place might well be considered a king's ransom in another. Reasonably priced for whom?
Good Answers: 42
10/20/2014 11:11 AM
That amounts to $10 Canadian per day - that is 1/10th of the minimum wage for someone at the poverty line here. Your full day salary would barely buy a MacDonald's Big Mack meal here.
Good Answers: 67
10/20/2014 5:28 PM
Absolutely. And four and a half hours' wages in Mumbai, India would buy a Coke in Sydney, Australia.
One measley Coke.
What I charged some engineering clients back east (US) *per hour* would have paid one these Mumbai bloke's salaries for *a whole month.* How can people live on one dollar an hour, anywhere? Sweet Jesus, what do they eat? Air?
Good Answers: 42
10/20/2014 7:28 PM
I am often "embarrassed" at the engineering fees - less than 2 weeks work is an entire year for someone on minimum wage. - But then again that pays for Professional Liability, computers, software licenses, vehicles, internet, 'scopes, meters, etc, etc.. (It has been a good life.)
When I see the extremes of income and expense, I start to have "socialist" guilt twinges.
In the northern climates the weather is sufficiently cold that the "average Indian workers class salary" would have them freezing to death and starving. The energy costs alone would be devastating.
Too few very rich people control too much of the worlds wealth. Unless there is more equitable sharing of wealth I fear there will come severe social unrest.
10/19/2014 2:55 PM
I repaired a number of circuit boards (a long) while back (all the same type). Every one turned out to have the same failed electrolytic capacitor. When the circuit card was installed in the device (vertical orientation), the cap was above a large resistor, and the heat from the resistor had shortened its life.
This is something that should be considered in board layout.
Good Answers: 67
10/19/2014 7:05 PM
I think one of the worst layouts I've seen for thermal management are Windows boxes, esp. towers. Make *everything* vertical.
Good Answers: 25
10/21/2014 6:22 AM
To all my friends who have shown little surprise over the earning of worker in Mumbai. Please understand we live in developing country and our cost of living is low when compared with your countries. Here total house expenses for worker per month are $200/-approx. Cost of Coke here is 60 cents. Mack Burgger is priced at $2.00/-. Now please do not get upset if you have to pay higher.
Good Answers: 67
10/23/2014 9:01 PM
The high prices are high, yes, but they don't hold a candle to our national debt: $21,000,000,000,000 as of FY 2014.
That's $66,246 owed for every man, woman and child in the U.S. Every last one
Now there's a reason to get upset. Our own government is doing more damage to this country than any terrorist could ever imagine doing without their help, by bankrupting this country, one pen stroke at a time.
Good Answers: 67
10/24/2014 1:57 PM
I should also mention 20% of that debt was incurred *in the last year alone.* $4,000,000,000,000. Count them: twelve zeros.
No country can sustain this much debt for long, and whilst we're teetering on the brink, Washington is spending money like there's no tomorrow.
Maybe because there isn't?
Good Answers: 42
10/25/2014 1:35 PM
I am no economist, but I believe as long as the US economy and currency remain the de facto currency standard of the world, then the debt is rather academic. The country that sets the currency standard of the world then has the ability to print money, and as long as they do not "flood" the market they remain a strong currency. I perceive it as a rather delicate balancing act.
Good Answers: 25
11/06/2014 5:27 AM
Your country spends hail of money on wars in third country . Like Iraq, afghanistan etc.It is shear waste of money and debt is passed on to people.
Good Answers: 97
10/23/2014 2:10 PM
I have noticed a falloff in the quality of electrolytic capacitors in motor start applications, which may have to do with the environmental requirements for the dielectrics.
CRTL-Z
11/05/2014 1:06 PM
It may be the tendency to get these parts out of China. I stick with American brands like GE (from Mexico), or Japanese.
Reply to Blog Entry 35 comments
Andy Germany (2); badbob (1); europium mkII (13); frankd20 (2); GW (6); James Stewart (2); Rixter (1); snatr (1); suresh sharma (5); tcmtech (1); Unredundant (1)
