Workbench Creations Blog
Workbench Creations
Previous in Blog: Del's DIY Bow Making Thicknesser   Next in Blog: Scrap Metal Wire Stripper
10 comments
Fixing a Thermoelectric Wine Fridge
Posted November 14, 2014 10:00 AM by frankd20
I recently got a small wine fridge that holds about 10 bottles, previously recycled by someone else due to it not working. Many wine fridges today seem to use a thermoelectric (Peltier) cooler, and while I like the technology due to the lack of moving parts, they are inefficient compared to its compressor counterpart. Still, free is free and I set about figuring out what is wrong with it. The obvious test of plugging it in and feeling for cool air told me it wasn't cooling down.
As I mentioned, thermoelectric cooling is quite simple in design: you have what is basically a large chip where one side gets hot and the other side gets cold. If you want to know the details of how they work you can visit our selection guide on thermoelectric coolers.
The diagnosis
I opened up the back of the machine and saw a circuit board and a large heat sink with a fan. My first test was to determine if the problem was in the circuit board, which is really just a power supply and thermostat. Most thermoelectric devices in this size range use about 12 volts DC to power them, so if I was seeing about 12v DC going to the cooler, then the circuit board was likely good. I followed the wires going to the cooling chip and measured the voltage across them with the device powered on. My meter registered 12.45v DC, which told me the board was likely working. This really only leaves one part that could be bad-the thermoelectric cooling chip itself. This is where thermoelectric cooling both shines and fails, because the chips are small and cheap and not too difficult to replace. At the same time, I find the failure rate for them is higher than a traditional compressor system. I would imagine the cost of them is one of the driving factors for using them in these small fridges.
The fix
The thermoelectric cooler is sandwiched between two large heat sinks, with the smaller one that gets cold being inside the fridge and the larger one that gets hot being outside. After removing a fan and some screws that hold the two sides together I could see the cooling chip. As a quick test to confirm my suspicion I held the chip in my hand and briefly powered on the device. Not surprisingly, nothing happened in terms of a temperature change.
The cooler used in this device was marked TEC1-12706 and a search turns these up for sale in many places for around $4 shipped. As luck would have it, I had some thermoelectric coolers on hand that I had purchased from a surplus store for a previous project for cooling a CCD. One of the ones I had matched in size and close enough in wattage.
Installing it is really just the reverse of taking out the old one, except I cut the wires off the old one and soldered the new wires to it. I also used some thermal grease compound on the cooler as it helps with the heat transfer.
The reward
Once everything was wired up I plugged in the fridge and felt the cold and hot side of the heat sinks; within a few seconds it was obviously working. I reassembled everything else and put the back cover on, plugged it in, and let it cool down. Now all that is left to do is fill it with wine, drink it, and repeat.
Good Answers: 7
Re: Fixing a Thermoelectric Wine Fridge
11/15/2014 12:15 AM
Yep - good stuff. I had much the same experience with a near-identical product.The digital display is missing some segments. I was able to upgrade the blown-up 100V (Tokyo) PSU with an off-the-shelf universal one.
Ideal for keeping red wine at 'cellar' temperature. Not for really chilled wines.
11/15/2014 6:39 AM
Good work.
Does it have any temperature control?
I would hope it has as otherwise, it will only chill down so many degrees from the room temperature in most places, which will be variable. Wine experts expect a fixed temperature I believe for specific wines....(I am not an expert, just a drinker!!)
I would guess it would be easy to add a small electronic thermostat to keep it stable....
Good Answers: 52
12/01/2014 10:20 AM
It does have a temperature controller in the form of a knob labeled cooler -- warmer no display, but I have checked it and it seems to regulate decently. I agree without a temperature controller it would be quite variable.
04/03/2023 9:09 AM
Wine expert?Ba! Humbug!If you want the opinion of a real expert,ask a wino.
They have more experience and a broader array of samples to judge from..just sayin'...
Good Answers: 58
11/15/2014 7:44 AM
People tend to think that TE cools are reliable because they are solid state devices and therefore have no moving parts. The truth is that they have solder joints that connect the front elements to the back ones. These low temperature solder joints are prone to fatigue, which is their normal failure mode.
11/15/2014 4:28 PM
Nice one I'm all for recycling especially where it involves beverages
11/17/2014 12:56 PM
I'd rather NOT have your recycled beverages thank you.
11/18/2014 2:43 PM
LOL!!!
11/18/2014 7:33 PM
Yes, that WOULD be taking the piss.
04/03/2023 9:14 AM
A Scottish man was caught by police urinating on a grave.
He explained to the police:
" I promised my friend that I would pour a bottle of Scotch on his grave every year in remembrance,and I figured he would not mind if I filtered it though me kidneys first."
Andy Germany (2); Brave Sir Robin (1); frankd20 (1); HiTekRedNek (2); jack of all trades (1); NeilA (1); user-deleted-1105 (1); welderman (1)
