Engineering Management Blog
The Engineering Management Blog is the place for conversation and discussion about engineering and project management, technology forecasting and planning, productivity tools, and safety and security. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Managing a Project with Difficult Stakeholders   Next in Blog: Balancing Security with BYOD
22 comments
Decision Making in Project Management
Posted June 05, 2015 12:00 AM by CR4 Guest Author
Decisions can be scary to make sometimes. In a project, a decision can make or break your budget, schedule or design. You can either move your project forward or unknowingly send it backwards. So, what can you do to make good decisions?
image credit
1. Define in detail what is known about the situation - Write down the project history and everything relevant to what is leading to a decision point. This will not only be a refresher for you, but will help to focus you and the team when their input is sought.
2. Come up with alternatives - More than likely, you already have alternatives in mind. Write them down and really think about any other way achieving the goal. Make a list of any length with every alternative you can think of.
3. Filter those alternatives based on feasibility - now take a broad filter to that long list and think about what is realistic. Budgets are limited and time is constrained. Just go through and scratch off the easy ones.
4. List pros and cons of each alternative, including foreseeable risks - try to be a psychic now. Think about what is good and bad about the remaining alternatives. Write everything down. Most likely, a favorite will appear.
5. Discuss with your team and get feedback, revise the alternatives accordingly - Now, present weekday you have written to your team either in a meeting or individually. Individually will likely give you better feedback because everyone will come up with their own ideas and interpretations. In a meeting, people are usually swayed and silenced. The goal is to get several perspectives and then to incorporate them into the choices.
6. Make a decision and get buy-in - Take everything in make a good and informed decision. You know as much as you possibly can at this point, make the choice, provide support, and make sure everyone is on board.
In the end, look for the most sensible alternatives, don't just stick to a course because you have been on it for so long. You must be practical and realistic. It may hurt your pride, but do what is right for the project and in the end it will reflect well on you.
Re: Decision Making in Project Management
06/05/2015 12:25 AM
You should add to #4 of not only the known risks, but also the unknown risks.
06/05/2015 7:56 AM
How do you write down the unknown risks? The best you can do is to write "there may be some unknown risks". Doesn't really seem worth the time or the ink.
06/05/2015 10:42 AM
That is always the question.
Being in the OEM (Original Equipment Manufacturer), Unknown unknowns is the most difficult. And is highly depended about experience, (or in project management 'Task experts').
Where you have Contingency budgets for this type of risks built into your plan.
Determining the Dollar and/or Time amount is where your Task Expert helps. And this is basically an educated SWAG
AS far as not being worth the Time and Effort, that depends on the project.
And example, with that attitude, IT projects at one point had 50-70% failure rate. (I can't remember the exact percentage, but it fall in that range)
Canada - Member - New Member
06/08/2015 8:44 AM
Point # 5 should be able to give you some of the unknowns. Unless you have a very detailed scope, the most unknown risk you have is your client. With a "team" in place, there should be lots of "what if's" when it comes to the client. There must be someone on the team that has some kind of insight to the client. With any luck, you may have worked for client before and can anticipate what may be upcoming.
Never stop learning
06/08/2015 8:46 AM
"There must be someone on the team that has some kind of insight to the client...."
aka 'Task Specialist'
06/05/2015 9:44 AM
I was asked to do this the other day. In my case it came down to looking at other systems or departments that could be impacted a few steps up or down the chain.
06/05/2015 10:49 AM
Facilitating is definitely a tool.
With communications be the prime tool.... speaking of which.....
the formula to calculate the number of communication channels on a project is
N(N-1)/2
N=the number of team members/stakeholders on a project.
Good Answers: 102
06/06/2015 8:50 PM
That formula assumes a full duplex channel.
Comms has to be 2 way to work effectively. I would remove the division by 2.
06/06/2015 10:28 PM
Only if your using a radio.
Otherwise, that formula as shown shows the number of paths that is Paths of 2-way communications.
One thing about project management, The Project Management Institute (PMI) created this as a standard (as well as other criteria standards), so it's universally understood.
Good Answers: 102
06/06/2015 10:46 PM
No, with a radio you can have simplex and even half duplex.
One channel for each direction, with handshaking if required.
That formula accurately counts the number of duplex channels, surely you've used a duplex channel when managing that only seemed to work one way?
Cool Hand Luke quote appropriate here.
06/06/2015 10:59 PM
I missed the memo.
Good Answers: 102
06/07/2015 8:02 PM
I'm sure I sent it.
Good Answers: 21
06/08/2015 9:00 AM
How can you know the unknown? Sensible suggestion, but you can only try to be phsychic, after all, as the man says in #4.
06/08/2015 10:34 AM
It's something they can only tell you in school,... because they can't teach it, because it can't be explained.
There are different words for it that may help, intuition and experience are a few that comes to mind.
Again, Task Specialists.....
Good Answers: 26
06/05/2015 10:21 AM
I base it on cost effective. How much do you put in vs how much do you calculate that you will get out and the time for a pay back.
06/05/2015 10:43 AM
ROI
Good Answers: 26
06/05/2015 11:04 AM
Its also time, not just ROI. Management wants to see TIME for the ROI. You can project endlessly but it also comes down to safety, getting installation accomplished, training personnel and working out computer interface problems. I have a project that has taken over one year to implement, Its installing a spectrograph at the entrance to the re-heat ovens. The techs will also do a dimensional,ultrasonic and a radiation check. Safety has nearly halted the process as they keep changing their parameters. Yes, i believe in safety but sometimes common sense has to be factored in.
06/05/2015 10:32 AM
7. $hit or get off the pot - Once the decision has been made IMPLEMENT it. Don't dally about 'second guessing' whether it was the right decision, that's a waste of time. Issue the RFP, RFQ, WCD needed, and get the solution under way.
06/05/2015 10:45 AM
8. You have to pass it first to find out what inside it.
Full Speed Ahead!
Seriously, the wavering on a decision can really impact the project as a whole.
Good Answers: 76
06/05/2015 11:29 AM
The decision-making process also varies based on the order of magnitude, the realm of influence of the decision (Product Scope vs. Project Scope), its impact to previously defined and approved deliverables, the engagement level of your Stakeholders (see Salience Model), and your pre-established RACI breakdown.
I find that a good tool to assist in the decision-making process is to define and document a clear set of Operating Principles at project development. Operating Principles establish the framework for decision-making and serve to assist the team in making decisions when questions arise during the course of a project.
I generally separate them into two groups:
  1. Project Scope: Principles that impact Project Team performance, interaction, and effectiveness.
  2. Product Scope: Principles that impact tangible deliverables.
It's number 2 that, if well documented on the front-end will help answer many questions mid-course. For example:
A principle stating that commonality with existing systems is important may help when a decision between selecting what type of PLC platform will be used... Siemens, AB, GE, etc. arises for a new manufacturing cell. In isolation, maybe Siemens would be the best choice, but if the rest of the facility is AB...
A principle attesting to the importance of proven technology vs. latest technology will impact whether you select the latest/greatest... or if you go tried and true.
A principle attesting the importance of scalability and customization vs. availability of existing inter-organizational tech support would help in the selection of Unix/Linux vs. Windows.
The list of the Operational Principal statements can go on forever, and they will vary for each project. But as you and your team become more experienced Project Managers, you can forecast what a lot of the decision-making needs are going to be, and meet with your Stakeholders in advance to author these Operational Principles that establish the decision-making framework.
Note - The location that these Operating Principles are annotated is within the Project Charter. And remember to keep them high-level and generic. Once you go detailed or specific in an Operating Principle, your 'Scoping' and you don't Scope at the Charter level.
Good Answers: 153
06/06/2015 5:38 AM
Maybe it's just me, but I wouldn't let your guest author within a mile of any of my projects.
My interpretation of a project is that it has a start position, a goal, a route, budget and time frame to get from one to the other. If he were writing about planning a project or running an enterprise then most of the comments are valid, but the idea of brainstorming for fundamental ideas on how to proceed when part way through a project frightens me rigid. There are also two important failures in the article. How this new decision will impact on decisions made at the outset of the project but not yet implemented or future changes? The decision to install a 32 pair cable to serve 25 sensors is cost effective compared to installing a bus system, until the number of sensors grows to 33. The other is how revokable is this new decision? Substituting a four wire strain gauges for the planned six wire strain gauges to pull back budget over-runs has an impact on the precision of the process, but swapping out to the planned sensors later when the budget allows is relatively straightforward. Installing 300m of 4 core wire instead of 6 core to serve those strain gauges has the same initial impact, but reversing that decision later is a major problem.
06/06/2015 9:11 AM
What I've seen of what the guest author post, is taken out of a book. Even though some are misinterpreted. These are only tools, each project is different and you have to adjust without being rigid.
Depending on a project, I agree that the fundamentals need to be defined early, yet one may and have come to an impasse on a project midway to where a brain-storming session occurs, wether formally or informally. And anyone that thinks that this ONE post is all about project management is not realistic.
I myself enjoy these light discussions and interactions, either for refresher or just for venting. When there something I don't agree, I'll point out or post like yourself.
Such as in the previous blog: Managing a Project with Difficult Stakeholders
Scope should be in the head line and quality part of the cost and schedule.
Hilton (1); JavaHead (1); jhhassociates (1); Kevin LaPaire (1); Kilowatt0 (1); Massey (1); phoenix911 (10); SavvyExacta (1); texasron (2); Wal (3)
