By now you've probably heard the truth-is-stranger-than-fiction
story of the prison escape in upstate New York. Presumably like many other
non-jailed citizens, I guessed that Richard Matt and David Sweat would have
been captured within a couple of days of their escape. Or turn themselves in.
Or maybe be eaten alive by the millions
of black flies that descend on the Adirondacks each May and June.
(I can't use a lyric and not link to the song, right?)
Unfortunately none of these things has occurred yet, so
instead two murderers are wandering around po-dunk, backwoods New York (or
Tijuana). However, it's easy to argue that the escape should have never
happened. While Richard Matt has been
described as a "cunning
individual," he never possessed a technical education. Same goes for David Sweat, a "mapper
and a planner" but not a wise wiseguy.
Ignoring the political and bureaucratic climate, as well as
a lot of media speculation about accomplices, locations and motives, let's
focus on what we know. If two street-smart, but book-dumb criminals were able
to hack and chisel their way out of the prison, how long would it take someone
with in-depth materials and mechanical training, say an engineer?
Let's start with the tools. Matt and Sweat were supplied
with hacksaw blades, a chisel, a punch, drill bits and lighted eyeglasses by a
civilian employee. Her motives are under speculation, and though she could have
been the getaway driver, officials now believe she was plan B. No matter, as the
tools she had provided were enough to get Matt and Sweat started. Kept in
adjacent cells, the inmates used
these tools to make holes in the steel vents behind their beds, seemingly
over several days. The ventilation grate was replaced to prevent guards from
noticing, and their beds were repositioned. This granted them access to a
service corridor that descended well below the prison block.
Inside the service corridor they
climbed down six stories then punched and chiseled their way through a
two-foot-thick brick wall as they followed heating pipes. This led to another
service area with steam pipes. Somewhere in these service areas contractors
were keeping tools while they performed renovations on the 170-year-old prison.
Armed with an electric saw, the inmates then cut holes in a large steam pipe
that led outside the prison boundaries. This was also done over a few days, and
each night the inmates would replace the tools. On the other side of the steam pipe,
they emerged in a sewer, and after breaking the lock on a manhole found
themselves 400 feet outside the prison wall and 20 miles from Canada.
What about the prison design? A facility so old has inherent
security flaws. Most new(ish) prisons construct walls and furniture out
of precast concrete. This means things like a bed can't be moved to obscure
holes in the wall, and cutting through a wall is that much more difficult.
While infrastructure such as plumbing and ventilation can't be eliminated,
modern jails install this equipment vertically so it's harder to traverse. Many
prisons also implement a centralized guard towers that provide sightlines into
each cell, another advantage in the prisoners' favor.
It's been 11 days since Matt and Sweat completed their
jailbreak. In all likelihood they are far, far away. But their lifestyle will
catch up with them, one way or another. However this provides a unique
opportunity to examine which engineering practices can stifle the ingenuity of
even the most determined individuals.
