Engineering...Beyond the Classroom Blog
The Engineering...Beyond the Classroom Blog focuses on engineering issues that are important to students and faculty regarding educational. Converse about educational or research technologies, tools of the student or teacher trade, curriculum and coursework, or myriad other topics that turn bright students into brilliant engineers.
Previous in Blog: Online Graduate Programs: Top Three Things Student Forget to Evaluate   Next in Blog: Confessions from a Graduate Program Admissions Team
7 comments
Wireless Implants Offer Hope to Brain Injury Patients
Posted October 25, 2015 7:00 AM by Penn State
During a recent presentation, Dr. Mohammad-Reza Tofighi, Penn State associate professor of electrical engineering and Penn State World Campus instructor, spoke to a room packed with students, faculty, and staff about his research on wireless intracranial pressure devices for the assessment of traumatic brain injuries (TBI). The need for improved monitoring is real. There are 1.7 million traumatic brain injuries (TBI) each year, which account for nearly a third (30.5%) of all injury-related deaths in the United States.
Tofighi, with the help of leading biomedical researchers and surgeons in the Philadelphia area, was presenting research focused on changing the way TBI are monitored. The initial call for this research came from a well-respected surgeon at St. Christopher's Hospital for Children, who had been searching for alternative treatments for hydrocephalus, the excessive accumulation of fluid in the brain. Although hydrocephalus was once known as "water on the brain," the "water" is actually cerebrospinal fluid (CSF) - a clear fluid that surrounds the brain and spinal cord. The excessive accumulation of CSF can cause harmful pressure on brain tissue.
The most current monitoring for hydrocephalus involves surgically inserting a shunt system to divert the CSF so it can be absorbed as part of the normal circulatory process. This process requires prolonged hospitalization and monitoring, and significantly impacts the daily life of the patient. The traditional shunt system has many drawbacks, including a high infection rate.
Tofighi was approached to assist on a research project that allows patients suffering from hydrocephalus more freedom through the use of a wireless implant, providing a monitoring system that medical practitioners can check remotely. A live animal study was conducted, and research remains ongoing to verify the device's longevity compared to the standard procedure.
Tofighi says he's driven by "using communications technology to help make people's lives better." He adds that the most surprising aspect of this research, and research in general, is that it goes in "a different direction than you expect," and that "the impact for the foreseeable future is wide-open as wireless technology is in its infancy."
Tofighi is one of many talented, respected experts in his field, teaching electrical engineering in a traditional classroom setting and online via Penn State World Campus. The World Campus offers you the opportunity to receive an education identical to that received by on-campus students.
Our College of Engineering is consistently ranked among the nation's best engineering schools, according to U.S. News & World Report. And when you graduate, you'll receive a diploma identical to those earned by students at our physical campus.
Editor's Note: This is a sponsored post brought to you by The Pennsylvania State University.
Re: Wireless Implants Offer Hope to Brain Injury Patients
10/28/2015 1:00 AM
Research Aims to Aid Traumatic Brian Injury
I want to know what "Brian" injury is. I've never been injured by a "Brian". Just a Chuck and a Jeffrey.
Reply Off Topic (Score 8)
10/28/2015 8:23 AM
I believe one of the symptoms of a "Brian" injury is dyslexia.
10/29/2015 5:46 AM
In the interests of accuracy, i must point out that the insertion of a shunt is a therapy, not a monitoring process. The purpose of the shunt is to drain the cerebrospinal fluid into the venous system to relieve the build-up of pressure within the skull. It is an effective therapy and does not require prolonged hospitalisation. There is a rather high infection rate, but it remains one of the mainstays of the treatment of raised intracranial pressure.
In contrast, the insertion of a pressure monitoring device, wireless or otherwise, is for monitoring purposes, not for therapy.
Good Answers: 58
11/02/2015 9:32 AM
Your answer is appropriate. However, wouldn't the ideal therapy consist of a pressure regulator? After all, the shunt system only makes a feeble attempt to prevent excess CSF pressure buildup from causing damage.
11/02/2015 11:19 AM
Thanks for the suggestion, we can pass it on to the faculty member. Penn State's new Online Master's of Engineering in Electrical Engineering program values an open dialogue, as it's key to finding new methods which can make a positive difference in peoples' lives.
11/03/2015 4:24 AM
The shunt makes more than a feeble attempt. When first inserted it is extremely effective in relieving the pressure, but it may become blocked. The shunt has a built-in one-way valve, and the patient is taught to relieve the pressure by pressing on the shunt to clear the blockage. This does not always work. The other problem is of infection. However, I do not see that an electromechanical device , which would necessarily be more complex, could perform any better. It would have to be a pump rather than a flow regulator, since both pressures and flows are very low.
10/29/2015 2:36 PM
Thanks for the clarification in terminology. Advanced knowledge and applying engineering principles are driving forces behind Penn State's new Online Masters of Engineering in Electrical Engineering program.
Deefburger (1); Penn State (2); phph001 (2); Poison (1); welderman (1)
