Previous in Blog: Rubik's Riddle: Newsletter Challenge (September 2018)   Next in Blog: Infrasound Inquiry: Newsletter Challenge (November 2018)
13 comments
Obfuscated Orbit: Newsletter Challenge (October 2018)
Posted September 30, 2018 5:01 PM
Pathfinder Tags: challenge question satellite
This month's IEEE GlobalSpec Newsletter Challenge:
An amateur astronomer is certain he has calculated the precise atmospheric re-entry time of a defunct satellite with a decaying orbit, predicting the event will occur exactly two months in the future. In reality, the satellite burns up in the atmosphere over two weeks earlier than predicted. What went wrong in the astronomer’s calculations?
And the answer is:
Predicting the exact timing of satellite re-entry is difficult due to many factors. Several parameters must be known to a high level of accuracy and any uncertainty in these values can create errors in the predicted re-entry time. Yet the most important contributing factor to the orbital decay of a satellite – atmospheric drag – is difficult to model and subject to a number of uncertainties.
Atmospheric drag on a satellite depends on numerous variables, including the shape of the satellite, its size and its spatial orientation (which all have an effect on the effective “drag surface” of the satellite). The density of the atmosphere plays a large role in determining atmospheric drag, and depends on, among other factors: the satellite’s altitude (which is different at the perigee and apogee of an elliptical orbit) and the satellite’s position in any one orbital revolution (the atmosphere is denser on the day-time side of Earth).
Perhaps the most significant source of uncertainty is the changing density of the atmosphere due to solar winds. For instance, during a solar flare, the density of the upper atmosphere increases due to the influx of solar particles. Furthermore, there are periodic variations in the speed of the solar wind as a result of the locations of coronal holes on the sun.
These factors make it challenging to predict exact re-entry times, which is why the astronomer’s forecast turned out to be inaccurate.
Re: Obfuscated Orbit: Newsletter Challenge (October 2018)
09/30/2018 5:25 PM
Show me the calculations, any number of things may have been miscalculated....
"The rate at which a low satellite orbit decays is a function of atmospheric density at each point along the orbit together with a satellite's effective cross sectional area A, mass m, and drag coefficient CD. In many cases, these last three parameters cannot be independently determined and a ballistic coefficient [ B = CD A/m ] is used instead. ."
The turning of the object can not be predicted in many cases therefore the drag of the atmosphere cannot be accurately determined....my guess is our amateur used the straight ballistic coefficient and the satellite presented broadest section that held true into the wind creating more drag than calculated....
09/30/2018 5:48 PM
Solar activity can cause the atmosphere to expand, increasing drag on the satellite.
"The world's eyes are on the Upper Atmosphere Research Satellite (UARS) headed toward re-entry into Earth's atmosphere. The satellite is currently predicted to re-enter sometime on the afternoon of Friday, September 23, 2011, but it hasn't been easy to precisely determine the path and pace of UARS despite the fact that scientists well understand how satellites move through space. The problem lies in the fact that space itself changes over time -- the upper layers of Earth's atmosphere can warm up and, more importantly, puff up in response to incoming energy and particles from the sun."
https://www.nasa.gov/topics/solarsystem/features/solar-effects.html
A good example was SkyLab:
"British mathematician Desmond King-Hele of the Royal Aircraft Establishment predicted in 1973 that Skylab would de-orbit and crash to earth in 1979, sooner than NASA's forecast, because of increased solar activity.[137] Greater-than-expected solar activity[140] heated the outer layers of Earth's atmosphere and increased drag on Skylab. By late 1977, NORAD also forecast a reentry in mid-1979;[136] a National Oceanic and Atmospheric Administration (NOAA) scientist criticized NASA for using an inaccurate model for the second most-intense sunspot cycle in a century, and for ignoring NOAA predictions published in 1976.[141]"
https://en.m.wikipedia.org/wiki/Skylab
09/30/2018 8:33 PM
Well for one he said "exactly two months"
28,30,or 31 day months?
10/01/2018 6:14 AM
Longest 2-month period is 62 days (e.g. Jul & Aug), and shortest is 59 days (e.g. Jan & Feb (non-leap-year)), so worst-case difference of 3 days - but re-entry was more than 14 days early.
10/01/2018 7:54 AM
The Earth's atmosphere experiences a tidal effect just like the oceans. (Two weeks is the difference between successive 'spring' tides', with lower 'neap' tides occurring between 'Spring' tides.) So it's possible he didn't take into account the changing shape of the upper atmosphere and the increased drag the satellite would see as the atmosphere bulged outward under the combined tidal effects of the Sun and Moon.
10/01/2018 11:34 PM
As the decaying orbit enters the exosphere the craft very likely encountered micro-space junk the contact with scrubbed equally micro levels of kinetic energy.
10/02/2018 12:21 AM
The drag produced by the atmosphere isn't a constant. Solar activity changes the amount of stuff the satellite will run into as it orbits.
Two weeks is a big error.
10/02/2018 6:36 AM
The satellite was weighed in kilograms and he calculated the figure as if it were in pounds.
10/02/2018 8:11 AM
"what went wrong in the astronomer's calculation?"
I'm just guessing here with the amount of info that was given...
I think he left something out of his calculation, like a number or something like that...
10/02/2018 8:20 AM
In reality, I would guess that the astronomer didn't have a map of the orbits of all the space junk that is circling the globe. It is quite possible that his calculations were correct but the satellite collided with some space crap which then changed the trajectory.
They did say he was an armature. Professionals at NASA would never let something like this happen (more than once), not here or on the surface of Mars...
Canada - Member - New Member Engineering Fields - Mechanical Engineering - New Member
10/02/2018 11:58 AM
Maybe he used business weekdays instead of including weekends...
SER, P.Eng. Mechanical
10/04/2018 9:43 AM
10/18/2018 9:24 AM
Answer is posted.
Hannes (1); JE in Chicago (1); JohnDG (1); phph001 (1); PWSlack (1); Rixter (1); ser (1); setlock77 (2); SolarEagle (1); somethin (1); Stephen Archer (1); Usbport (1)
