Workbench Creations Blog
Workbench Creations
Previous in Blog: Making a Didgeridoo   Next in Blog: Build your own crane
18 comments
Home-Brewing Hard Cider
Posted October 09, 2007 10:00 AM by frankd20
Pathfinder Tags: DIY blog hard cider home brewing
This is the 3rd year I have been home-brewing hard cider; however, it's only the 2nd year I've done it successfully. It's really not a hard process, but my first attempt failed due to lack of research.
Hard cider is really just apple wine; if you want more of a true cider, just don't make it as strong. The basic idea behind hard cider is the same as any wine, yeast is added to juice and left to ferment. For those of you who may have never made a wine or beer, let me give you the basics. You are going to need a bunch of equipment and assorted additives that can be made or purchased from a brewing shop.
One of the main parts of the setup is the container which your beverage will ferment in, which is called a carboy. The best carboys are made of glass, but for part of the process you can use plastic; however, you will need glass for the second step. The carboy needs to have some sort of air lock to let bubbles out without letting air in. You will also need some equipment to siphon the cider from one container to another and a hydrometer to determine the alcohol content.
In addition to the equipment, you will also need yeast and the juice that you are going to ferment. Depending on the yeast used, your finished product may have a range of different tastes from dry to fruity. Additional additives will also change the taste of your cider. For additive or other recipe tips you should consult a local brewing shop as there are too many recipes for me to discuss here.
Before brewing, you should first clean and sterilize everything you are going to use. There are a number of products which will work for this, including bleach in low-concentrations. I use a product called iodophor which is mixed with water. After your container is sterilized, fill it with juice, add the activated yeast, and put an air lock on it. For the next 3 to 5 days the cider and yeast will do a lot of bubbling and foaming so make sure you leave room in your carboy. When the bubbling of your cider slows to once every few minutes its time to re-rack it. If your cider is still bubbling after 7 days I would re-rack it anyways.
Re-racking is the term given to the process of siphoning off the cider while leaving the sediment behind. In this process you are moving the cider to a different carboy. The siphoning setup consists of a racking cane, which is just a hard plastic tube that reaches down to the bottom, and some tubing. To begin siphoning I have a squeeze- pump similar to the kind used on an outboard boat engine.
Once you have re-racked your cider, let it sit for about 3 weeks before re-racking it again. After that the cider should sit for 7 or more weeks and be re-racked once again. After this your cider is ready to drink, although it improves with additional aging. In reality, after the second re-racking you could drink the cider, but the more subtle tastes don't develop until it has aged properly.
I like to carbonate my cider and there are a number of ways of doing that. The most common method is to add sugar right before bottling. The sugar reactivates the yeast and makes CO2—if you choose this method just make sure that your bottles can handle the pressure. I prefer to carbonate my beverage by pressurizing it with CO2 when I am done brewing. This is quite easy for me because I choose to keg my cider instead of bottling it.
Once you are done making your cider the only thing left to do is drink it…and I don't need to describe how I did that. However, I will warn you that I've learned first hand that drinking too much cider can give you a heck of a hangover.
Re: Home-Brewing Hard Cider
10/09/2007 5:01 PM
Ha...excellent!
There was a good crop of apples this year and I was toying with the idea of making a cider press...
How did you chop/press yours?
I was under the impression that you could just press 'em and let the natural yeast in the liquor do the job?
Good Answers: 52
10/10/2007 9:43 AM
The home brewing store I go to gave me the name of an orchard that would sell me cider right off the press, so I used that instead of pressing my own. You are right that the apples has a natural yeast in it, but its more dangerous to use that. The natural yeast isn't quite as strong so you risk having something else grow as well. Using a brewing yeast ensures that is the only thing growing. The shop I go to also sells a live shot of apple cider yeast in a test tube, which I did use for a batch.
Making a juice press is another project, which I might do one day, as I have apple trees near my house that would supply plenty of juice.
The Architect
Engineering Fields - Software Engineering - S/W Architect Popular Science - Evolution - Fascinating! Fans of Old Computers - TRS-80 - A fine computer United States - US - Statue of Liberty - NY
10/09/2007 5:46 PM
Yes, I can attest that this cider does indeed leave a dent the next day.
Mark Gaulin
10/10/2007 5:22 AM
Good article! I use this cider-making kit.
Aged man is not old man...
APIX Pilot Plant Design Project - Member - New Member
10/10/2007 10:05 AM
Funny, we used to make apple cider by leaving the top off of fresh apple juice for a few days at room temperature. It developed its own CO2 and its own hardy kick. After about a week at room temperature, it did tend to become apple vinegar which is good for cleaning windows and for putting on salads. Of course, that was way back in the 40's and 50's, so we really did not know what we were doing. hehehehehe.
chtank
10/10/2007 10:59 AM
I made my first batch of apple Cider last year, and made a nifty press to go with it.
I took a 5gallon pail and drilled small holes in the bottom and the sides. I then made a wooden plunger that just fit inside the pail, ontop of this plunger I attached a...........CHAIR. I put the apples in a old t-shirt, inserted the plunger, and sat down ontop of it at my computer. Amazingly it worked fairly well, not nearly as efficent I am sure but it did the job.
The funny thing is after making this large batch of cider, I realized I dont much care for cider...lol
10/10/2007 11:09 AM
Cunning press !
10/15/2007 5:15 AM
You can make Cider from Apples or pears by mincing the fruit , adding water, covering the fermenter, & bottling the liquid @ fermentation- however I find the following to be the best; 2 l apple juice, 2 kg white sugar, 1 teaspoon urea, 1 teaspoon citric acid, 1 vitamin B complex tablet, 25 l of water, 1 teaspoon of wine yeast- keep at 25 deg C till bubbling ceases(about 3 weeks)- add to 750ml bottles with A teaspoon of caster sugar as the prime- gives a dry sparkling apple cider equal or better than you can buy( plus, the commercial ciders use artificial flavours added- as do commercial beers).
10/17/2007 12:10 AM
Pasteur Champagne yeast works fast, but requires a long time to mature in the bottle (12 -24 weeks). Premature consumption will result in severe somatic reaction (hangover). The natural yeast in the "bloom" of the fruit can no longer be relied upon for fermentation on commercially available apples. Check your local homebrew shop for specifics
If all else fails, read the directions. That's if, and only if.
Good Answers: 15
10/17/2007 6:32 AM
I've got what may be a dumb question but its bothered me ever since I've been considering making my own wine/mead/cider.
When you re-rack it.
Why Don't you just run it through a large filter?
Wouldn't that take all the sediment out the first time? I'm thinking those really large coffee pot filters. Or maybe make your own out of a fine weave muslin cloth.
scotchdrnkr
10/18/2007 3:23 AM
Hey whusky glugger- you don't need to rack or re-rack- it's utter b---sh--t- notice i don't in my cider recipe- the fact remains that to save r-r-r-racking, don,t use raw fruit, but go for fruit juice- if you all want to make bootiful alky drinks, simply add special yeast to opened fruit juice containers- leave for several days to 2 weeks at 25' C according to your taste(sweet or dry)- when taste is right- tighten top & place in fridge to stop further fermentation- enjoy!!!. The benefit is you simply use yeast at the bottom of the container to christen the next bottle- it lasts for ever- time & again- I haven't used dry yeast in the last 15 years making beer, wine, cider etc- Breweries also use liquid yeast- usually from the dregs, as I do!!!. The yeast is wine or sparkling champagne, experiment- mine is a mix of 10'C- 30'C wine yeast. Now if you will excuse me , I have a raging thirst that can only be satisfied in 1 way- glug, glug, gluggity glug- Burp!!!.
Good Answers: 15
10/18/2007 7:00 AM
I was looking at stills and came across this tiny little thing. Looks like a Mr Coffee appliance. Its at the bottom of the page.
http://www.stilldrinkin.com/Turbo-New.htm
scotchdrnkr
10/18/2007 9:20 AM
Sorry guys and Dolls, but I think I will use the lease expensive and safest way out and make my beer and wine at the store. As for a still, I prefer the vacuum still for making motor fuel grade alcohol. As for drinking hard liquor, again, the store is the safest, if one can call getting drunk safe. I suggest not driving drunk, drunk drivers are domestic terrorists and THE biggest major threat to our security.
chtank
10/19/2007 3:00 AM
Mr P-tank, please define DRUNK- if incapable of doing anything safely, I agree- however, if using police enforcement- using general guidelines(arbitrary ratings of the "average person")- then I disagree vehemently!!. However, don't worry, coppers now have powers to assess the motorists condition by their judgement!!!- and then to require one to undergo all sorts of expensive tests- the easiest test is alcohol- if negative, one may be required to give a blood sample, which will be tested for drugs- any and you are gone!!!. It appears to me now that the only way to have some semblance of freedom is to go right away from civilisation(ie coppers!!!).
10/19/2007 9:50 AM
You have all the freedoms in the world until you infringe upon the freedoms of another.
chtank
Good Answers: 15
10/24/2007 7:02 AM
I have to agree with Neil on this one. Here in the U.S. anything over a .08 level is considered drunk. Depending on your body mass. Have a drink or 2 with your dinner and you could be considered drunk.
And breath analyzers are not as accurate as the police want to believe.
I got pulled over in June for rolling thru a stop sign. And the fact that I have a bad right eye and bad inner ear problems therefore no balance and could not pass the road side test they gave me a breath test. And the breath test said I was .6 according to most standards I was dead. http://www.habitsmart.com/bal.html
Both medical conditions are medically documented. The eye is obvious. I wear a patch. The ear I had to show proof.
According to my blood test I was still over the legal limit of .08. Had a .083. So I still had to go thru all the legal crap. After paying a lawyer $$$. I finally got out of the DWI charge but still had my license suspended for 90 days and had to pay court cost.
And I'm on probation for 2 years. So now i don't even have a drink with dinner unless my wife is driving.
scotchdrnkr
10/15/2008 9:02 PM
Well put. I am about the same place in my cider making learning, 3rd year and I use pepsi kegs to carbonate. Had trouble last year with 3/6 of my carboys. Stuck cider due to lack of "yeast nutrients" I think.....good luck and Cheers!
Popular Science - Cosmology - New Member
Good Answers: 16
04/16/2009 11:39 PM
Way too complicated!!
Mix in sugar to the fresh juice at the rate of 1lb/1gal, or honey at 1/2lb/gal. Add 6 raisins to the carboy, these have the propper 'must' to begin fermentation. Add an airlock which can be bought, or use an S tube and sm. funnel full of water at just above the cider. Loosly pluged with a cork and wet cheese cloth works too. Wait, at 70deg. F untill bubbles stop. Rack into bottles. If you like the fizz, wait a little less and cork when you see only a couple bubbles a minute.
For apple jack, freeze gallon plastic jugs full of finished cider. Run a hot poker into the center and pour off this wonderful elixer. The ice has no alcohol in it.
I use a proprietary blend of white and brown sugar with honey. Aged, it comes out a very refined taste, but beware! You won't know how potzed you are untill you try to get outta the chair.
De gustibus non est dispudandum.
Anonymous Poster (1); chtank (3); frankd20 (1); ktel60 (1); mgaulin (1); Neil Kwyrer (3); Qqberci (1); scotchdrnkr (3); Sirjess (1); Tippycanoe (1); user-deleted-1105 (2)
