Previous in Blog: Water Volume: Newsletter Challenge (11/08/05)   Next in Blog: How to Start a Fire?: Newsletter Challenge (11/22/05)
10 comments
Color TV: Newsletter Challenge (11/15/05)
Posted November 15, 2005 6:00 AM
The question as it appears in the 11/15 edition of Specs & Techs from GlobalSpec:
The kids are with you in your workshop one Saturday morning, with your intent being that they help clean up all the junk scattered around — magnets, wire, tools, etc. However, they're more interested in watching the small color TV you have set up. Soon the bickering begins — it appears your son has distorted the TV picture by dragging a magnet across the screen ("I was just looking at the cool patterns, Dad! I didn't know it would be permanent!"), and your daughter is calling him an idiot for ruining the TV. You point out they should both be helping, not doing dumb things (although you've done this one yourself...) and causing more work. Then you calmly fix the problem. What do you do?
TV Challenge
11/15/2005 10:58 AM
All (CRT) picture tubes have a metal screen called the 'shadow mask' mounted just behind the inside surface of the tube. Besides providing the focus aperture for the three color guns, the mask's job is to nullify the effect of the Earth's magnetic field on the electrons flying through it. If the mask itself becomes magnetized, the color purity and focus of the image get screwed up. With the exception of only the newest plasma sets and LED screens, every computer monitor, TV set and Video Game has a CRT which is susceptible to these localized magnetic fields. The 'shadow mask' needs to be demagnetized using a 'degaussing coil', which is nothing more than a 110 volt 60 cycle AC coil inside a safe plastic shield (i.e: insulating tape). This needs to be passed over the screen in order to repair the disruption to the mask. I wonder if an ordinary transformer could be used to the same effect?
There's no such thing as bad weather....only the wrong clothes!
Re:TV Challenge
11/15/2005 11:01 AM
Stole my thunder!
Re:TV Challenge
11/15/2005 11:31 AM
Sorry :-)
Re:TV Challenge
11/16/2005 3:17 PM
On my CRT I'm able to degauss by going into the monitor (compaq V 1000) menu and selecting "degauss". This is the only reason I know the answer.
not just any transformer
11/15/2005 2:41 PM
a normal transformer wouldn't work because of the laminations that create a magnetic short circuit. I would either use a ferrite bar-core coil, or break apart half of the laminations to force some of the magnetic field through the tv. Look up something called hysteresis if you want to learn more about degaussing.
United Kingdom - Member - New Member Hobbies - Model Rocketry - New Member
Easy
11/15/2005 2:43 PM
Turn off the TV and tell them to get back to work. Seriously, I have no idea.
The yoke a man creates for himself by wrong-doing will breed hate in the kindliest nature . . .
The Architect
Engineering Fields - Software Engineering - S/W Architect Popular Science - Evolution - Fascinating! Fans of Old Computers - TRS-80 - A fine computer United States - US - Statue of Liberty - NY
Been there; done that.
11/15/2005 6:02 PM
Well, all I can say that when I did this as a kid (to our NEW color TV, no less), I was playing with a big magnet from our electric lawn mower (about 3 or 4 inches in diameter, about 1/3 inch thick). I was freaking out trying to get the green color to leave the center of the TV (where I put the magnet). My solution? I broke the magnet in half (I wanted to do that anyway!) and "pulled" the color back to the edges by moving the two pieces in opposite directions. It worked pretty well, but I suspect the TV degaussed itself later (or someone knew to do it), because after a few days you couldn't see any leftover spots of saturation.
Now kids... don't try this at home!
Mark Gaulin
Been there; done that -- Too
11/16/2005 8:38 AM
When this happened to me, I degaussed by holding the magnet in the area where the "mishap" had occured, then, while passing it in a circle in a plane parallel to the TV screen, I moved the magnet away from the screen. I did this while the TV was on, so I could see what happened to the color distortion. The first go, it didn't "fix" it. So, keeping the magnet moving in that little circle, I came back in toward the screen, and backed back out again. This did what a degaussing coil does (move the magnetic domains around, reorienting them, and, by lowering the field strength gradually, leave them in a random order: demagnetizing the metal).
The Architect
Re:Been there; done that -- Too
11/16/2005 9:09 AM
Ah yes, those were fun times! I think my parents knew I was going to end up in science around the time I started making stinky stuff with my brother's chemistry set.
Mark Gaulin
Color T.V. ... Solutions
11/16/2005 12:55 AM
Just throw away the Old TV and buy a new Plasma TV. Everyone will be happy. Problem Solved!. And your daughter will say, "Daddy I Love You"..
Anonymous Poster (1); Gone fishin' (1); halcyon_m (1); mgaulin (2); rvguest (1); Silas Marner (1); Simon (1); Stupott (2)
