Previous in Blog: Of Balls and Flies: CR4 Challenge (06/10/08)   Next in Blog: Car Front End: CR4 Challenge (06/24/08)
49 comments
Airbags: CR4 Challenge (06/17/08)
Posted June 15, 2008 5:01 PM
We know that air bags save lives, and we all have them in our cars. We know that they are fast to open in case of an accident, they are very soft, and they absorb energy. Now, why do they save lives? Explain it in terms of physics.
And the Answer Is...(June 24, 2008: 8:33 AM EST)
To understand the reason air bags save lives, we must look at the concepts of impulse and momentum. In an accident, or when you stop the car softly or abruptly, what you really want to do is to change the speed of an object of mass m from v1 to v0 (where, in the case of an accident v0 = 0). In other words what you want to do is to change the momentum of the object according to the equation, Δp = mv1 - mv0 where p = mv is the equation for momentum. In the case of an accident, where the vehicle stops completely (v0 = 0), the change in momentum is simply, Δp = mv1 where v1 is the velocity of the vehicle at which the accident takes place.
We can derive an equation for the change in momentum by re-arranging Newton's Second Law of motion. The second law can be stated as
Where a is the acceleration of the object, m is its mass, and t is the interval of time during which the force is being applied to the object.
If we multiply t by both sides of the above equation we get
Ft = mΔv = Δp (1)
The quantity Ft is defined as the impulse, I. As we can see from Eq. (1), the impulse is equal to the change in momentum, or
Impulse = change in momentum
I = Ft = Δp
In the equation given above F is the force that is needed to change the momentum of the object an amount Δp. The time t is the time interval that this force should be applied. In the case of an accident, as stated above, this force can be written as
(2)
We can see from Eq. (2) that the force needed to stop the vehicle in an accident is inversely proportional to the time that the force is applied. It is clear that the longer the time interval the force F is applied, the smaller will be this force.
During an accident between two vehicles, each vehicle stops abruptly and each car exerts a force F onto the other vehicle. Because the time it takes to stop the vehicles is very small (almost zero), according to Eq. (2) the force is enormous. This is the reason the vehicles are normally completely destroyed. The person inside the vehicle that moves at speed at the moment of the accident will have a speed equal to zero after the accident. In order to change the momentum of the person inside the car from v1 to zero the same force F must be applied to the person during a time interval t by the dash (or any other surface) of the car.
Now, if the person hits the dash of the vehicle, and because the dash is sturdy, the time it takes to stop the person movement is extremely short. This means that the force exerted by the dash is extremely high. You well know happens in a case like this.
If, on the other hand, an air bag opens at the moment of the accident, the person inside the car will hit the air bag instead of the dash of the car. The air bag will exert a force on the person, but (this is the important part) during a longer interval of time. The bag will deform (unlike the dash) and it will hold the head (or the body) of the person for longer period of time during which a force is being applied to the person to stop the movement. According to Eq. (2) the force will be smaller. By receiving a small force to the head, the person survives.
So, air bags save lives because they extend the time period during which a force changes the momentum of your body.
Re: Airbags: CR4 Challenge (06/17/08)
06/16/2008 12:13 PM
describing the impact in terms of force and momentum is one of the best ways to describe this ... an object in motion has energy ... ie: you head traveling at 60 mph with your car
P=mv
now if you brake slowly the energy is dissipated at a reasonable rate so as not to strain you too much ... in an impact the energy is dissipated much more quickly
Newton's 2nd law:
F=ma=mdv/dt
where the variable here is time
if your head were to impact the windshield or steering wheel (either of which would only deform slightly ) the energy would be dissipated by a point reactionary force opposite to the direction of travel at the point where you head contacts the obstruction very quickly (therefore small dt, making the force required to dissipate the kinetic energy large)
in the case of an airbag, the gas within the airbag compresses with the impact of your head absorbing the energy, while deforming to covering a larger area of your head ... in effect dissipating the energy more slowly, while spreading it over a greater area (lessening the force applied to any one area of your head)
larger dt, means less instantaneous force
Good Answers: 38
06/18/2008 12:35 PM
LP Ultima
This has turned into a great debate on air bags, but it seems you are the only one who has answered the question.
06/16/2008 3:20 PM
LP_Ultima is correct in all respects, but I'd like to add some detail. As there are no formulae or numbers, some may doubt it is a physics explanation; nevertheless...
I'll start with some generalities:
Like any other mechanical system, body parts can only withstand a certain stress; this shares the units of pressure, but direction is important as well - tensile and sheer stress are generally more damaging than compression, and body structures also have directional differences. Damage can be modelled as if caused by localised dissipation of energy after the stress limit has been exceeded, so if we can reduce the peak level of stress by applying the impulse over a longer period, the body's kinetic energy can be dissipated in the supporting structures outside the body rather than in the human body itself. Spreading the force also has clear direct benefits, as the peak stress is reduced.
But the secondary benefits of directly decelerating the relevant parts can be even greater - as an example we can consider the neck-head-brain subsystem when the vehicle stops the body and the head is subsequently stopped by the neck:
consider first how the neck stops the head. The muscles don't have time to respond to the deceleration, so there is little to stop the head rotating due to the effective couple that is applied between the centre of gravity of the head and the base of the neck.
So the head will gather angular momentum until the chin hits the chest, at which point there is massive tension in the back of the neck. Possibly a broken neck; but even if the neck is merely strained, the effects on the brain can be catastrophic. If the head is accelerated without rotation, the brain is largely supported by its buoyancy - the blood vessels and other joining tissues need to supply but little force weak; as buoyancy provides no torque, practically the entire whole force has to be borne by these weak structures, and torn blood-vessels readily lead to brain damage (K.O.)
Returning to the way the airbag reduces the peak forces on the body: it rapidly inflates as soon as the acceleration of the vehicle exceeds some defined "safe" limit. That allows the body to begin decelerating very soon after the vehicle does, rather than continuing at the same velocity while the vehicle decelerates rapidly. The airbag is designed to provide as much force as is practical without causing catastrophic damage - provided that the dimensions of the body being stopped are within certain bounds (not suitable for children, then). The total force can be very large, as the airbag spreads it reasonably well over the body (though nothing like as well as might a buoyancy-based "g-suit").
06/17/2008 9:12 AM
Nicely done!
My girlfriend worked as a paramedic and has seen the gambit.
Without an airbag, head injury is usually the prominent cause in frontal collisions for the passenger (head in windshield), while the thorax is usually the issue for the driver due to the steering column. The thorax basically gets crushed and ribs can become spears. Basil fractures of the skull as you described are another large issue. Many people have their seat adjusted so that they are too close to the steering wheel, even with seat belts and air bags.
The worst impact is the side impact. The shear stress is usually the killer. Aortic shear is the common one. The victim looks unhurt, but ends up rapidly bleeding out at the scene long before a response team gets there.
In a side impact the head will usually strike the side glass, adding to the list of injuries.
The aorta and organs are much more sensitive to side shear forces than frontal forces.
06/17/2008 9:52 AM
Thanks - and I agree with your additional comments. I simply ran out of steam for describing other issues.
Regarding present practice: I'm in no sense an expert, but based purely on a priori grounds I believe frontal airbags to be generally useful in frontal collisions (though they would be much improved for lighter passengers if they were segmented and maybe provided with an adaptive charge based on seat-measured body-mass). On the other hand, side airbags apperar generally incorrectly placed and therefore of limited (maybe even negative) benefit (probably too low and too far back - and what about the side of the body nearer the centre of the vehicle).
06/18/2008 11:16 AM
Side impacts are the big killers. There simply isn't enough crumple zone to absorb the impact.
Worse yet are the trucks and SUVs that are based on a frame rather than a unibody type of build. The frame acts as a battering ram and generally, these vehicles are sitting higher off the ground, so the frame impacts a standard car right about where the thorax of the occupant is.
The frames are not designed to absorb impact like a unibody car, instead they transfer the force into the vehicle they impact.
Maybe reactive armor on the car doors would help!
06/18/2008 11:43 AM
Agreed, that too is relevant. Perhaps that is another excuse for driving mid-engined cars with the air-intakes just behind the sides of the doors and necessitating significant wall thickness. Mid-engined construction also allows large unobstructed crumple zones front and rear, and coupling the engine tightly to the cockpit helps ensure that the centre of the vehicle continues moving with you without having to excessively reduce the stiffness of the car body. (Oh, and the crumple design should also lower me so I go under the frame of the worst offenders).
Nevertheless, I try to drive defensively.
06/18/2008 11:58 AM
I would just like to see the killer vehicles reduced in numbers so that the likelihood of such a crash is vastly reduced. Given the rise in gas prices it appears I may get my wish.
Yes, a good mid-engine coupe would be a fine ride. A Cayman comes to mind. Now, pull that wonderful engine out and replace it with an electric propulsion and it would be even more intersting.
06/18/2008 5:34 PM
Yes, a Cayman would be very suitable. Shame you can't combine the lightness and rigidity with a soft-top though. I imagine (no direct knowledge) that electric engines might work even better without much transmission - so maybe mid-batterried rather than mid-engined?
06/18/2008 8:01 PM
It really depends on how you want to distribute the mass in the chassis. A suitable electric motor is probably 150 lbs. I would want that mounted to the transmission, so that would be just behind the seats.
The batteries could be distributed where they fit and in manner that provides even weight distribution. There would be 350-400 lbs in the batteries.
In the end you would have a car that has a weight of about 2,900 lbs max, maybe less.
If you want to get fancy you could ditch the transmission and use two motors to direct drive each rear wheel. The drawback is that you need two motor controllers and software with all the sensors to determine how to split the power between the two motors given the current dynamics of the car.
I would love to see Porsche build such a car. The Cayman chassis might be ideal. Weissach would be the perfect entity to do it, too, and I would think it would be the pinnacle of technology if they signed up for it.
06/19/2008 5:50 AM
That should become a natural thing for Porsche to do whenever battery technology allows the car's mass to come below petrol-head levels. BTW, if removing the differential gear can reduce total mass, I'd be happy to pay for the extra electronics to allow separate motors per wheel.
Regarding mass distribution: as I see it, there are two aspects to this (post-crash protection, and handling), which result in three constraints:
For optimum driver/passenger protection, the mass needs to be rigidly coupled to the cabin.
To allow the suspension to be designed to give similar handling under all conditions, the centre of gravity of the loaded vehicle should coincide (front-to-back) with a suitably weighted average centre of lateral wind forces. CofG should also be as low as practical.
Moment of inertia (with driver and passenger in place) should be minimised.
Mid-batteried arrangements would ususally appear to be optimum on all 3.5 counts
06/19/2008 8:23 AM
Separate motors for each driven wheel would be the cat's meow (sorry Del). However, a motor controller might run as much as $5,000 for each motor and then there is the software, which is not likely to be available off the shelf. The motor controller is a COTS device you can buy today. You could also roll your own if you have the engineering knowledge.
The problem with mid mounting the batteries, is space. To keep center of gravity low you need to mount the seats as low as possible. That leaves the transmission tunnel and the tunnel between the seats. That tunnel on the 911 and the Cayman is less than 6" in width because the seats are close together (actually the whole car is narrow and small).
The Chevy Volt does use the center tunnel on their car for batteries. The pack actually makes a T (it's called the T Pack) and the drive motor is in the back, I believe, with a 3 cylinder turbo generator in the front. This is a 4-passenger car, so they have a lot more volume than a Cayman.
06/19/2008 5:23 PM
Based on the Boxster (I haven't yet had the opportunity to deconstruct a Cayman), there is a great deal of space behind the seats, including of course the location of the existing engine (assuming that you mount the pair of electric motors just outboard of the batteries). That is good for the wiring resistance and electrical interference as well.
If we divide the controller between power devices and the sensors plus low power (systems) control, I can't imagine the latter part coming to more than tens of dollars. That would place most of the cost in the power devices - and splitting these between two motors won't appreciably increase the cost (assuming that we want to close-couple the power devices to the motors to minimise electrical interference, it might even make the heat-dissipation issues more tractable). Automotive manufacturers have already had to address critical software issues for engine and stability control, so it would be surprising if Porsche didn't have the capability.
However, $5k buys an automotive manufacturer a great deal of electronics (currently about 0.4-square feet of silicon and including any additional cost of packaging, I believe) - or were you referring to the price on the forecourt in one of the high-taxed countries, where a fully-featured Cayman costs about $100k
06/20/2008 7:56 AM
That $5K is the price you or I pay from some reseller. Porsche would roll their own and the Wiessach side of Porsche has a long history of diversity in engineering, so no doubt that the talent lies there or can easily be hired.
06/17/2008 1:55 PM
In the last para, line 2, (as) soon as the acceleration of the vehicle exceeds some defined "safe" limit. Did you mean to say: Deceleration?
06/17/2008 3:05 PM
Yes and no (and if I have to choose, more 'no' than 'yes').
Acceleration is the generic term for rate-of-change-of-velocity, so acceleration is still a correct description for a frontal impact slowing the vehicle down.
So why more no than yes? Because front air-bags should also protect against a vehicle running into your front when you are stationary, and the final paragraph also covers side air-bags.
While acceleration covers all three cases, deceleration rather implies that it only covers the first.
06/16/2008 8:28 PM
During an accident, the vehicle's interaction with the "outside world" will be with another vehicle or a stationary object such as a tree. This results in potentially very high accelerations/decelerations of the vehicle. Deformation of the vehicle and the other object dissipates some of the energy and lessens the "rigid body" accelerations of the vehicle. However, the people inside the vehicles must undergo the same accelerations/decelerations as the vehicle or they will impact some part of the vehicle. If the people are unrestrained inside a vehicle undergoing high accelerations/decelerations, they impact things like the steering wheel, dashboard, and doors. These impacts result in very large, localized applications of force to the people. With seat belts, the forces applied to the people are mostly at the lap and shoulder belts. While this is better than impacting the inside of the vehicle, these are still more localized forces. In addition, side impacts are not as well resisted by the seat belts. Air bags do an even better job of reducing the accelerations of the people. The bags quickly inflate and provide a much larger surface area over which the forces on the body can be applied. In effect, the average surface pressure is less. Also, since the pressure is over most of the body's frontal or lateral area, all part of the body see very similar accelerations which results in less differential stress on the body. Air bags also provide much better protection from the sides than seat belts. One downside of airbags is that in minor collisions, they can deploy and cause injuries just due to the process of inflating.
06/17/2008 12:29 AM
I think the complete explanation has been given in the previous posts. I thought I would play around with some numbers to see what type of forces a person might be subjected to in a crash.
Take the scenario where a car travelling at 20m/s (approx 72km/hr) has a front on collision with a solid wall with the result that its front crumples and the driver compartment stops after travelling a further 1m towards the wall.
In this scenario the drivers compartment changes from 20m/s to 0m/s over 1m distance. So the acceleration it experiences (assuming constant acceleration during impact) is 200m/s2 which it experiences for 0.1 seconds.
In the worst case the driver is unrestrained in the driver's compartment which means that there is a space between him and the inside of the drivers compartment. If we take that space as 0.5m then it will take him approx 0.07 seconds to cross that (given that the drivers compartment is accelerating towards him due to collision at 200m/s2) so he has only 0.03 seconds left to decelerate from 20m/s to 0. This results in an acceleration of 667m/s2. Assuming an 80kg driver he will experience a force from the inside front of the drivers compartment of 53,333kg.m/s2. This is equivalent to the driver having a 5,400 kg weight being placed on him in the shape of the front of the driver's compartment. In addition there will be sheer forces due to differential movement between the parts of the body that hit areas/protrusions of the compartment at different times.
In the best case if we assume that the driver is attached to the drivers compartment by safety devices (seatbelts, airbag, etc) he will then be accelerating at the same rate as the drivers compartment (200m/s2) and the force that he experiences from the restraining devices during the impact is 16,000kg.m/s2. This is equivalent to the driver having a 1,600 kg weight being placed on him in the shape of the restraining devices. In addition there will be sheer forces due to differential movement between the parts of the body that are restrained and those that are not. Clearly in this case the areas that the restraining devices are applying the pressure to is very important. In the case of the airbag it is spreading this force over his head and torso relatively evenly and the parts of the body unrestrained (arms and legs) can take damaged without (immediately) killing the person. A seatbelt just spreads the force over the area of his torso covered by the strap of the belt which results in greater pressure on those areas than from an airbag. It also does not restrain the head leaving it to experience sheer forces at the neck (as well as potential collision with the front of the drivers compartment).
Good Answers: 15
06/17/2008 2:45 AM
As a former airbag engineer with four patents who did the first passenger side bags for Ford, Porsche, Mercedes, along with sensors for all of Europe, I think airbags are greatly overrated and still are NOT designed correctly. I spoke just last month with a guy who works in "advanced development" at the major usa airbag manufacturer where I use to work. To be frank, they still don't know what they are doing. Still after 12 years they still don't build them correctly.
Ask the question: If putting kids in the back seat is ok, and back seats don't have them (except for side bags), then why not make the front seat like the back seat?
Fact: A GM report stated that the benefit of driver bags was $3.9 billion and the cost was about $4 billion during a given year (I am going from memory). Passenger side bags cost 4 billion and only have 0.9 billion in benefit, which is a violation of federal law. The benefit MUST be larger than the cost.
Why are driver bags on par with cost and passenger side less than 1/4? Did you know that this major manufacturer (1990) firmly believed that passenger bags were not needed and did not build them, until a rogue engineer sent Chrysler a "passenger" (pipe style) inflator he made up in secret in the lab? Chrysler called up and ask for more, and the stuff hit the fan...and a multi-billion dollar business was born...the engineer got in trouble...what a joke...
The reason driver bags work is because the steering wheel knocks out teeth and punctures the liver during a crash. If you remove the steering wheel (side stick?) the benefit is very low, and in many cases airbags INCREASES risk. In fact, a 105 lb women is 8 times more at risk (according to the GM report) than without bags. Remember a common sense rule...don't explode things in people's face... Mercedes showed BETTER HIC (head injury criteria numbers) WITHOUT passenger airbags than with on their 1994 SUV.
In short, the company that makes airbags does not have a clue how to make them so that they don't kill children. This is a classic Monopoly effect. One of my patents states "will not kill a child" (they have the rights to it) and I explained it to them in May 1995 (after I no longer worked there) and what needs to be added to complete the package and was arrogantly told that people should put the kid in the back seat. They still have not figured it out in 12 years!
Why? Leadership...I can name names, and if you are a lawyer who wants to sue, write me a letter. I got the facts and there is data...
This is classic do-gooder regulation that slows progress. The reality of airbags is not what it appears. There are MUCH better ways to save lives and the reality is that airbags cloud what needs to happen to get to light weight cars that can take the large velocity reversals caused by large weight differentials (semi truck vs eco-car). The end result is lives lost and progress stopped by the regulation...
In fact, I think it cost us around 40,000 lives each year due to the "freezing" effect airbag regulations have on looking for real solutions that airbags cannot meet. If the regulation were NOT technology specific, which is required by law, then auto manufacturers would be free to look for other options that would actually save lives. Going against the airbag "standard" is the kiss of death for a career minded engineer. In my case, trying just to make the bags actually do what they claim cost me my job...
The only way to solve this problem is to have new car companies emerge. When was the last time that was tried? Welcome to our brave new world...
06/17/2008 8:16 AM
Interesting post!
-Abe
Good Answers: 19
06/17/2008 8:42 AM
I don't exceed 80mph much anymore (I'm too old and boring) but I do agree that air bags are an oversold technology that must be a nice profit center for someone in the line. Quite frankly, if given a choice (which currently I am not) I would take a four point seat harness and roll cage instead of an airbag for protection. When I was taking glider lessons, the four point belt was simple to use, lightweight, yet seemed able to keep a passenger secure in his seat.
Unfortunately, our friends in congress (the opposite of progress!) and the federal bureaucracy think they know what is good for us and have mandated these unsafe "safety" devices.
end of rant!
Good Answers: 15
06/17/2008 11:24 AM
A child's seat harness with the center belt is similar.
The key is to not apply loads to critical areas.
The unintended consequences of the regulations was to stop innovation that would lead to near zero deaths and little damage to the car.
Now we have kids in the back seat where a Dad can't talk to easily on one of those rides to get a "treat" which is actually one-on-one time. My young daughters are "at risk" of death just for sitting in the front seat. In fact my wife, who is a very trim and 5'8", is at risk. What a joke!
06/18/2008 4:49 PM
Well, safety equipment for racing versus safety equipment for street use is complex and not what it seams.
You would intrinsically think that a roll bar and a 4-point harness would trump an airbag with a standard seatbelt, but it may not.
The reason is that racing safety equipment is designed to work as a system. So, only using a portion of that equipment (i.e., roll bar and harness) may actually be less safe than what you are trying to replace. You really need the seat and a helmet (and a Hans device) to get the correct benefit. Even then, that system has some disadvantages on the street. You will also need to deactivate the airbag if you go the racing route.
Food for thought, how interested are you in wearing a helmet in your car anyway? Few people would want to be bothered with that burden.
There are some factors that reduce the effectiveness of airbags.
1) Improper use of equipment. I.e., not wearing seat belts in low speed crashes significantly increases fatalities when the airbag deploys.
2) Improper seat adjustment and position relative to the steering wheel.
3) The Offset Hypothesis where drivers believe that the safety features will protect them and they push the limits further by aggressive driving.
06/17/2008 11:13 AM
I may be a bit cynical: but SFIK car occupants in the US suffer a total of about 33k accident-related deaths per year. So the 40k figure cannot relate to the USA. Perhaps spg refers to prosperous countries (that enforce airbags). These seem to have total occupant deaths in the region of 100k per year. Are you saying that 40% of these could be avoided through improved airbag design and deployment?
Reply Off Topic (Score 4)
Fans of Old Computers - Commodore 64 - New Member United States - US - Statue of Liberty - New Member Engineering Fields - Control Engineering - Process Control Engineer
06/18/2008 3:43 PM
I had a professor in college that worked for GM previously. He worked directly with airbag development among other things. He mentioned a weakness with air bags that very few ever talk about. If you drive your car with the window rolled down and your arm resting on the opening, you will get a nasty surprise when the air bag deploys. There is a very high chance your skull will slam into the metal post that supports the roof. The air bag directs your head straight to the post as you slide off the side. He was rather impressed with the forces a crash test dummy recieved to the ol' noggin, even at lower speeds. This may explain why more modern cars are built in ways that make it uncomfortable to drive in this manner. If you are in an accident, try to square up in the middle of your seat before impact with your head against the headrest.
It is impossible to defeat a fool in an argument, he wil bring you down to his level and beat you with experience.
06/18/2008 5:27 PM
Part of the reason for the changes is indeed to provide enough distance between the side airbag and the occupant for it actually to provide any protection at all.
Good Answers: 94
06/19/2008 4:22 AM
"There is a very high chance your skull will slam into the metal post that supports the roof."
This would tend to remove from the driving pool all those people who insist on driving with a cell phone clamped between ear & shoulder.
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
06/17/2008 4:54 AM
My sister-in-law is a surgeon in the USA who does some trauma work. She has been involved in several cases where the front seat passengers survived a crash and the back seat passengers died. The main difference appearing to be the protection afforded by the airbags in front. I don't know what the accident statistics show.
I also wonder what impact (literally) seat back LCD screens will have. I would rather embed my face in a seatback than a glass screen in the event of an accident, of course I rather not embed my face in anything at all!
Good Answers: 94
06/17/2008 5:27 AM
I think that last statement says it all, if you know your face is going to smash into something would you prefer a brick wall or a cushion?
The earlier comments about airbags give a fascinating insight into the 'safety' business.
Good Answers: 15
06/17/2008 11:34 AM
There are MANY ways to "cushion" an occupant. One of the worst ways is an airbag because of the time response and decision criteria, along with the package opening debris issue. Having a "temperpedic" substructure instead of what is now there and removing any hard points is a start. Airbags are a fix to a bad instrument panel and window design. If you were to start from new, I sit down for an hour with me, I think you would see that the entire car needs a ground up remake, including where the engine goes and a host of other things needed to get to 1000 lb cars.
Your statement of a brick implies that someone is advocating such, therefore the regulation is needed. That is not a fair comment in any context. Sorry...
Good Answers: 94
06/17/2008 11:42 AM
I don't think anyone is suggesting making cars out of brick, I was only highlighting the difference between a hard & soft surface which is pretty much agreeing with everything else in your post however, you do a much better job than me in explaining the problem.
06/18/2008 8:20 AM
Welcome to the wild wonderful world of commercialism. Don't you folks know that they have to create a market where one did not exist previously. The whole system is designed to separate you from your money. Now I am not against everything, but the LCD screens are a bit much when you consider that most trips in a car are of a duration of 15 minutes or less for rear passengers. They will never have time to watch those things.
The jist I get is that the air bags have some value, but I do agree research needs to continue on better ways. Smart cars that can help avoid acidents are a good start. Traveling proximity/collision alarms sound good as does station keeping systems that match your speed to the car in front. This is all existing technology which is very cheap to implement with todays level of technology.
And cell phones need to be banned for the driver too. I can't count on how many times I see a car do something extremely stupid and come within inches of a major accident only to realize the idiot has a cell phone stuck to their ear. Police should be ticketing the bad drivers and leave the speeders alone, too. They would rack up far more tickets that way..
Good Answers: 94
06/18/2008 8:44 AM
I don't know what it's like in your part of the world but some of the things you mention like tailgating & use of cell phones are already illegal over here, what we don't have is enough people to enforce the laws that already exist.
It's pointless creating more & more offences if the existing ones are simply ignored.
Good Answers: 19
06/18/2008 9:18 AM
Regardlys of seat belts, air bags, ABS breaking, etc, it still boils down to the nut holding the wheel. (Speaking from personal experience )
06/19/2008 8:08 AM
Yes, I have heard that the U.K. is a bit ahead of the States on this and some other things. But even if the police are not on top of every violator, at least if there is an accident involving a cell phone, the police can pull the call records of those in the accident and if they were on the phone at the time, their goose is cooked.
06/17/2008 3:54 PM
Yes, the response rate is a problem, as is the momentum of the bag.
However, for a fixed (passive) system to do better than the present arrangements should you would need to place it 1/3rd of the distance from the occupants (compared with the present surfaces), and that would have to include surfaces close to the face. That carries some basic psychological issues that seem pretty intractable. Even the simpler, more effective and less constraining system of backwards-facing passenger seats has (so far) proved unsaleable - at least for small road vehicles and for aeroplanes (though rear-facing seats seem to be accepted in trains).
Agreed, the present generation of frontal air-bags are imperfect, and I remain to be convinced about the benefits of current side air-bags.
So what could be done better? Obviously, reduced risk of mis-firing. Then, the bag could be segmented so that the initial impact (and the subsequent resistance) depends on body area. Not ideal, but it would at least allow people above about 30-kilos to travel in the front seat. For side impacts, a combination of improved passive restraint in the seat design and better-placed bags would be beneficial. Even these measures might be costly, and therefore could not be obligatory - but my family's safety is worth more to me than the standard actuarial values, so I'd be happy to pay the difference.
Beyond that, I fear we would be looking at more complex (and possibly heavier) arrangements*. In principle, there can always be advance warning of an impending collision; that would allow restraining surfaces to be brought forward much more gently, possibly using an air-bag with much reduced charge that was finally triggered by the actual collision.
A final note: supposing that I believed that better practical systems than air-bags were commercially viable and politically saleable, and I found myself working for a company whose main business was selling air-bags made to an agreed standard, I would not suggest change within the company until I had established (at least to my own satisfaction) that initiating such change could be of overall benefit to the company**. Failing that, your only viable options would be to change your field of endeavour or to find a company that could benefit from your suggestions.
*or, better yet, limiting automotive speeds to safer levels - possibly even to the extent that 'mass transport' becomes a more attractive alternative
**though that might merely be a case of limiting the damage in case some other group moved first
Good Answers: 38
06/17/2008 8:20 AM
Seaplaneguy
Very interesting information. One of my co-workers recently lost control of his car during a rainstorm. He wasn't moving very fast but slid sideways and hit the front quarter panel on his vehicle into a divider. The front airbags barely touched him but the side airbags inflated and caused his liver and spleen to rupture. Dude was in the hospital for quite a while and they did not know if he was going to make it. Fortunately he did. I question also the validity of some of the devices and statistics presented by those in authority. Statistics and percentages all can be manipulated to give whatever results you desire.
Good Answers: 94
06/17/2008 8:38 AM
My cynical side also wonders if car manufacturers consider the value of spare parts sales. Even in a minor crash, if the air bags deploy, you might need a complete new dashboard moulding.
Popular Science - Weaponology - Greets to all who travel this road! Safety - ESD - Ground Strapped and Unafraid
06/17/2008 9:49 AM
In truth many vehicles are "totalled " by insurance companies after airbag deployment. This action is often done with no other mechanical issues but the actual deployment.
In the very least, I should have a decision point at which I can choose to employ or not employ an airbag feature dependent on my driving situation. As a 4x4 enthusiast I have a recurring nightmare of bumping a tree coming down a slope and getting punched in the face by an airbag followed by an uncontrolled descent in which I wreck my truck and perhaps myself.
In a real life accident between a Tractor Trailer and a Hyundai at speed 60MPH U.S. on the freeway the tractor trailer t-boned the car, they were traveling in the same direction and converging at which time the car came over too soon and ended up being plowed forward sideways while the driver of the truck attempted to stop over the course of 150Yards what saved the driver was not her airbag that deployed bloodying her nose - but rather the reinforced door panels - two distinct bars running horizontally across the otherwise crushed door.
I was very impressed. As was the little girl in the back seat.
/endrant
If there was smoke it may be broke!
Good Answers: 15
06/17/2008 11:47 AM
Like I said in my previous post, I know the people who design them. They have been given the answers and they "have knowledge." Under the law, this industry is libel for hundred of Billions...yes Billion. The Congressmen/women who forced the regulations onto us are all bankrupt in my opinion. The lack of new entrants into the auto industry, which is for the most part government (read Keiretsu) monopoly (Oligopoly) in nature is the problem. Just try to enter the airbag market now. The entire system stops innovation. Small companies will buy from small companies, but large ones will not because of the risk of stopping a production line. It is just that simple. No conspiracy, just raw economics. There are three players in airbags, two don't have any clue, and one is run by a guy I would never hire. This is NOT capitalism. We have NO choice in the matter as consumers.
06/17/2008 10:37 AM
The 'dogmatic' postulation of what we all 'know' to be true is an interesting challenge.
Some writers in the automotive press have speculated that the "automatic deployment" trumps any voluntary restraint technology (regardless of actual cost/ benefit merits) due to political considerations. A dogma is born!
Thus far no one has mentioned the 'faulty deployment' problems that have plagued some airbag installations -presumably due to electrical system glitches that are not directly related to the airbag. Exactly why it happens has been the subject of speculation among service techs - but some vehicle types are commonly known to suffer from the problem.
Imagine having a deployment without any collision - and while moving at speed! It does happen. And it causes injuries as a result of both direct deployment - and contact with extra-vehicular objects resulting from control loss during deployment.
Some safety enhancement!
Out in a Bowt
06/17/2008 8:15 PM
There has been much writing above of a very relevant, logical, and illuminating nature, and I am glad it has been contributed herein. But there is one issue that has not been addressed as yet. As somebody who has been in several automobile accidents (since age twelve as a rider, not a driver...), it would seem appropriate to point out one additional issue. If a car is struck hard enough from behind, say, for any reason, to cause the impacted vehicles' airbag(s) to (deploy), the driver can be incapacitated from seeing where to go, and even steering the vehicle at all. As such, said impacted vehicle then becomes, essentially, an unguidable missile, careening further down the roadway. Other vehicles nearby may be forced to (share the experience?) in subsequent collisions. If such a driver cannot control such a vehicle, then who is accountable for such consequences?...
06/18/2008 9:35 AM
"Several automobile accidents" of relevance to this discussion?? May I suggest you are more careful in selecting (or rather refusing) your driver in the future.
Theoretically, if you are struck centrally from behind, the direction of acceleration should be such that neither front nor side airbags should deploy. However, in practice the effective strike is often offset so there may be sufficient rotational energy to legitimately set off side airbags, with consequences similar to those you describe.
In the UK, that would make the entire chain of events the responsibility of whoever is deemed responsible for the first collision in the chain of events - and I imagine that the same would apply in most western jurisdictions. If the initiator wished to apportion some of the blame for subsequent events to the airbag manufacturer, he would need to demonstrate to the court's satisfaction that the effect of the initial accident would have been insufficient for the driver of the struck vehicle to lose control in the absence of airbags - which would be extraordinarily difficult to prove to the satisfaction of the law.
06/18/2008 12:22 PM
First, to clarify, I now add that the incident in which I was twelve years old actually happened back in 1958... (Thanks for thinking to ask, first...) Later on, in regards to my own driving, the capacity to continue to "see" the best response to be made helped to mitigate further accident consequences, before airbags became legally required...
Second, "theory" and "reality" tend to be more like immediate "cousins" rather than "identical twins", on average, so the primary point is not that it should be unlikely that a rearend collision would trigger an airbag deployment, but that a rearend collision is only one of several plausible ways an airbag deployment could be triggered...
Third, irrespective of how an improperly designed airbag deployment is triggered, it should be relatively easy to demonstrate, with a sufficiently complete re-enactment in a courtroom, that a deployed airbag temporarily blocked a driver's vision long enough to prevent said driver from seeing what best to do next, and further, to then inhibit said driver from recovering control of said vehicle within sufficient time in order to avoid further accidents, as direct consequences of inadequately designed airbag configuation(s)...
In short, misconfigured airbags can add (windows of vulnerability) that would not exist otherwise...
06/18/2008 1:14 PM
I rather assumed the accident was a few years back - your writing style suggested a certain maturity. It was the implication of "multiple accidents since the age of twelve" that prompted my comment - that you would appear to have been at best unlucky with your chauffeurs.
The court's assumption is that, if the sideways acceleration component corresponds to levels that have been specified to set off airbags, the level is sufficiently injurious that the victim would in any case be incapacitated from driving. So it is necessary to prove that these levels have not been generated, and the only party who has any real interest in this is the perpetrator of the initial collision. Actually, it is necessary to prove rather more than this: either that the airbag provides no overall benefit on average, or that the failure to prevent unwanted deployment was both predictable and that the reason for not preventing the deployment was either simple negligence or improper cost cutting.
Even the false deployment becomes rather difficult to prove when the cars have been further damaged subsequent to the initial collision - indeed, not only would you need to show that the impact was sufficiently symmetrical, but it would be necessary to demonstrate that dangerous acceleration levels that would be ameliorate by the deployment of the airbag. Possibly the only way to demonstrate this would be using instrumented tests on cars of similar design. So that gets through stage one. Next, to prove that the reason the airbag was not designed to withstand the actual shock was legally unacceptable.
All in all, not a viable course of action unless the lacks of such proof is personally catastrophic, which would be most unusual assuming the legal minimum insurance. However, if the evidence can be found it could receive legitimate support from concerned safety campaigners.
Good Answers: 94
06/18/2008 12:48 PM
I don't think air bags would have helped in this crash test.
06/22/2008 5:13 AM
This has been an extremely interesting and informative thread. Can somebody provide links to any comparable discussion about the efficacy of automotive seat belts and locking retractors?
12/19/2008 12:52 PM
Your explanation is not completely correct. In an collision, as the car is decelerating, an unrestrained passenger continues moving forward at the cars original speed. By the time the passenger impacts the dash, the car is moving considerably slower than the passenger. This results in very rapid deceleration of the passenger, which results in severe trauma.
The purpose of the airbag and the seatbelt is to decelerate the passenger at the same rate as the vehicle by starting the passenger deceleration at the same time as the vehicle deceleration.
Also, I don't think I would describe an inflated airbag as soft. They often break arms as they inflate, and can decapitate small people (children).
12/19/2008 2:18 PM
The time to achieve zero momemtum is the only important variable here. If the time is long, you are safe; otherwise ...
Abe
Reply to Blog Entry 49 comments
AccuDave (1); amichelen (2); Anonymous Hero (7); Anonymous Poster (6); BobD (1); Cardio07 (1); Chankley (1); charsley99 (2); jim35848 (1); LP Ultima (1); Nigh (6); Physicist? (10); RickLee (2); Ried (2); seaplaneguy (4); snowboy (1); Zap (1)
