Sensors & Switches Blog
Sensors & Switches
The Sensors & Switches Blog is the place for conversation and discussion about thermal, mechanical & pressure sensors, optical & ultrasonic sensors, electrical and electromagnetic sensors, and switches and solenoids. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Staying in Control   Next in Blog: To Network or Not to Network? That is the Question
3 comments
Are You an Energy Scavenger?
Posted August 31, 2008 8:00 AM
How do you power sensors located in remote or hard-to-reach (and hard to power) locations — such as monitoring the structural vibrations on a highway bridge — if electric utility power is not available? Solar photovoltaic cells would be one way. Another is known as "energy harvesting." For example, sensors mounted on helicopter rotor blades have been powered by tiny generators that harvest the helicopter's vibrational energy. Are you using energy harvesting techniques to power any of your sensing requirements?
The preceding article is a "sneak peek" from Sensors & Switches, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Sensors & Switches today.
Re: Are You an Energy Scavenger?
09/01/2008 6:42 AM
I am working on circuitry to attempt to scavenge miniscule bits of energy. I can't say much about it but it is an interesting topic.
Good Answers: 7
09/01/2008 10:37 PM
This may be off topic. I went the the Kitchen and Bath show in Chicago last month. There is one vendor with a faucet (for household kitchens, baths and utility rooms) that has a built in turbine, generator, temperature sensor and LEDs. When water flows, the column of water in the sink glows blue if it is cold. It glows red if it is hot. It was one of the best displays I saw at the show.
09/09/2008 1:51 PM
A customer of ours installed a current transducer, which surrounded a current transformer secondary (5 amp at full range through the CT) and used the low voltage DC output to charge the wireless DAQ system batteries they needed to power. I thought this was quite clever. The transducer range was 0-10 amps AC, output 0-5 VDC, and needs nothing external to derive the output. With only 5 amps in the CT secondary, the maximum voltage would be 2.5 VDC.
Since there was plenty of high power being used by pumping equipment, they saved a great deal of time and complication by eliminating a control power transformer and a DC power supply.
Anonymous Poster (1); Paddler (1); rcapper (1)
