Sensors & Switches Blog
Sensors & Switches
The Sensors & Switches Blog is the place for conversation and discussion about thermal, mechanical & pressure sensors, optical & ultrasonic sensors, electrical and electromagnetic sensors, and switches and solenoids. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: The "Holy Grail" of Process Instrumentation?   Next in Blog: 2008 – The Year That Was
2 comments
A Simpler Vision
Posted November 21, 2008 8:20 AM
Machine vision has been has been an expensive, complicated solution, only used for complex inspection and part-placement applications. Such systems typically require experienced integrators to get them to work and stay properly tuned.
But now there's a new breed of lower-cost, almost appliance-like devices called "vision sensors," said to be far simpler to install, configure, and program than high-end vision systems.
Vision sensors may be just the ticket for simple inspection applications that don't warrant a full-blown vision system, but are a bit beyond the capability of, say, photoelectric or inductive proximity sensors. Have you worked with any of the new vision sensors, and if so, what's your experience?
The preceding article is a "sneak peek" from Sensors & Switches, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Sensors & Switches today.
Re: A Simpler Vision
11/24/2008 10:56 AM
We have two "vision sensors" at our plant. They look at little white clips that are placed on a black fixture. The clips are right angle shaped and have one hole on the RH side and two holes on the LH side. A simple switch could detect the clip, but it would be very difficult to detect which way the part is turned without a vision sensor.
The vision sensor uses blob tools to detect the presence of one or two holes. It is also programmed to be only check for one clip on pallets that only require one and to detect two clips on pallets that require two. The vision sensor has proven to be a very good solution for this scenario.
To date I have only encountered one failure that can easily create a "false failure." Further down the process clips are riveted to another piece of metal. Over time shavings from the rivets build up on the fixture. When enough shavings are present the camera does not sense the hole because of light reflecting off of the gray shavings. Operators were initially confused by this situation, but quickly learned to clean off shavings and try again.
11/24/2008 11:23 AM
I had designed a pizza crust QC with vision systems that if the pizza crust is mis-shapened, such as folded over, or not to a specified diameter the machine would eject it.
I'm impressed with the quality, sharpness, resolution as well color these vision systems are going as well as the price being very reasonable.
phoenix911
