Previous in Forum: Sunset on Mars Is Blue   Next in Forum: Increased Solar Cell Efficiency
13 comments
Drinking Water Toxins
05/17/2015 1:23 PM
Hi,I am trying to determine what a realistic amount of toxins , if any , are leeched into drinking water when using NSF rated PVC pipe for long runs of potable water, 2in , NSF schedule 40 , 2000ft. Also,Do the glues and solvents used to install pipe ," cure " to form a safe potable water surface ? , How would these values compare to using NSF polyethelene pipe , Thanks in advance
Re: Builder
05/17/2015 1:27 PM
Good luck.
You might check the MSDS for pipe and glue.
Leach rate probably won't be published.
Re: Builder
05/17/2015 2:11 PM
The NSF rating certifies that the pipe and materials used with the pipe are safe for potable water plumbing....
Re: Builder
05/17/2015 3:46 PM
If you can get a big honkin' spool of 2000' of 2" PE pipe, and just roll it out with no joints, that'll beat 1000 glue jobs with PVC.
Re: Builder
05/17/2015 4:13 PM
Oops. 100 glue joints. (Editing time expired.)
Good Answers: 102
Re: Builder
05/19/2015 4:04 AM
166 joints. PVC pipe comes in 12' (4m) lengths.
Agree with you on the choice of material.
2000' is along run for glued PVC pipes. PE is the normal choice for these sorts of runs.
Unless OP is wondering about internal plumbing in a building, but 2", that's riser and long distance sizing. Tall building, or small subdivisuion...
Re: Builder
05/17/2015 4:44 PM
Invista raptor nylon pipe is available in 2000' rolls....Don't know if it is certified for potable water yet, but would probably work well and last longer...
http://napipelines.com/invista-seizing-pipeline-industry-raptor-nylon-pipe-offers-alternative-to-steel-composites/
http://www.paintsquare.com/news/?fuseaction=view&id=12432
Re: Drinking Water Toxins
05/17/2015 5:00 PM
Surely PE pipe is potable certified. It's used everywhere.
But PVC is also certified for potable service and also used extensively.
As long as we're discussing piping, look into ABS piping, too.
05/17/2015 5:41 PM
I don't think ABS handles much pressure, though.
05/17/2015 10:12 PM
Thanks for the links and comments , after reading, my concerns were answered. I like Tornado's suggestion about using longer rolls of PE , less labor and fewer joints . I found some 500 ft rolls that would be manageable for me to handle, Thanks again for the great info
05/17/2015 11:17 PM
you have more important things to concern yourselfI'd start with whats in the water to begin with
Good Answers: 122
05/18/2015 9:05 AM
Soy Lent Green?
05/18/2015 3:43 PM
what is THAT? coagulated algae? I agree that spools of tubing will do the job he had in mind a lot better than multiple joints over that long a run. Less leaching solvent also.
05/19/2015 5:37 PM
Yuk! Look what happens when fish do what they do in it!
Switch to beer instead. ;-)
Register to Reply 13 comments
Fredski (1); James Stewart (1); Jazzman (1); lyn (2); PWSlack (1); SHOCKHISCAN (1); SolarEagle (2); Tornado (3); Wal (1)
