Previous in Forum: Deep Water Electronic Communication   Next in Forum: 240V Residential Circuit into 347 Baseboard Heater
Storage Tank Heater, Thermostat
08/27/2015 3:24 AM
I have a storage tank heater of 10 KW/415V. Recently, the thermostat of the heater started malfunctioning and so I opened to check it. The thermostat has capillary bulbs and has two set points. 90 degrees is a pre set point. It is also a 3 phase thermostat. As far as i know, with more than 10 Amps current, thermostats needs to be connected with a contactor but this heater doesnot seem to have any. Please suggest me a suitable replacement and letme know where in India can i find the same.( Please note, I donot know the name of the company who supplied the heater but the thermostat is from Cotherm).
Re: Storage tank heater, thermostat
08/27/2015 3:30 AM
Not known 3 phase thermstet.
Contact provider of thermal sensor products. see above choice. then click Productz and Zuppliers
PeeeWee
"peitschen deinen arsch" -that's what she said.
Reply Off Topic (Score 6)
08/27/2015 4:29 AM
Most water heater thermostats I know of do not involve a contactor; the ampere rating of the thermostat is already sufficient. This appears to be a 3-phase thermostat--does it have a current rating stamped on it? It might be "Contherm" rather than "Cotherm".
08/27/2015 5:13 AM
The rating says 16 A- 230 V.
08/27/2015 7:12 AM
Then I presume the elements are wired in star, which gives 230 volts on each phase to neutral. I.e., your setup looks correct. I don't know of local sources for a replacement thermostat.
Good Answers: 266
Re: Storage Tank Heater, Thermostat
08/27/2015 10:13 AM
http://www.cotherm.com/
That cream colored box is the contactor.
Looks like the temperature control from which they call a dishwater heater.
I stripped mine out and used a digital temperature control ,a solid state contactor for control and a mechanical contactor for on/off.
08/27/2015 1:40 PM
Google can find suppliers of replacement 3-phase thermostats anywhere in the universe, not just India. Highly recommended.
08/28/2015 4:01 AM
Why do you post anonymously?
I am therefore not interested in helping.
Bye.
Andy Germany (1); Anonymous Poster (1); ozzb (1); PeeeWee (1); PWSlack (1); Tornado (2)
