Previous in Forum: Computing System Demand Pressure and Flow Fire Sprinkler System   Next in Forum: Sprinkler Orifice Minimum Pressure
13 comments
Fire Pump Selection
12/07/2015 10:42 AM
Hi, what pump can you advice to my application 1800 gpm, at 4ksi, hopeful for help thank you
Good Answers: 61
Re: Fire Pump Selection
12/07/2015 11:40 AM
Try these:
Guide to Pump Selection - http://www.pumpscout.com/articles-scout-guide/pump-types-guide-aid100.html
Images of Fire Water Pumps-
http://www.directindustry.com/industrial-manufacturer/firefighting-pump-150132.html
http://www.fairbanksnijhuis.com/EngineeredProduct_A_Split_Case_Electric_Drive_Fire_Pump.aspx
Do it once and do it right
12/07/2015 12:17 PM
About 5000 hp, unless your units are a typo.
12/07/2015 12:19 PM
Pick up the phone and start talking to pump suppliers. There's no better way of learning than doing that.
Good Answers: 97
12/07/2015 12:33 PM
US or Imperial GPM ?
12/07/2015 12:56 PM
Quite.
"US Dollars or Zimbabwe Dollars?"
GA :-)
12/07/2015 12:55 PM
It takes a lot more to specify a pump. Here are some of the things that pump vendors will need to understand before making offers:
  • System temperature
  • Reservoir capacity
  • Intended operating time
  • Method of drive
  • size of inlet and outlet connections
  • method of attachment to inlet and outlet connections
  • wetted materials
  • method of starting
  • method of stopping, if any (some fire pumps are designed to run until the reservoir empties, until the fuel runs out, or until catastrophic self-destruction takes place, whichever happens first)
  • intended location
  • elevation relative to the top and bottom levels in the reservoir
  • weight constraints
  • leading dimension constraints (will it pass through that doorway or does one need to take the roof off to get it in?)
  • handing of the equipment
  • project timing (it is not worth a vendor's while to chase a contract for supply next week if other customers' orders mean that a six-month queue can be expected for new orders)
  • The facility's spares stocking arrangements and standards (there's no point in installing a Bullshine Ltd. brand pump if all the others at the facility are manufactured by Codswallop Ltd. and their spares are already in stock)
  • The facility's maintenance arrangements
  • etc.
Good luck with those phone calls. Do let the forum know how they went, though please do not disclose the chosen supplier in subsequent postings as it may prejudice commercial arrangements with other suppliers.
<unsubscribes>
12/07/2015 1:40 PM
12/07/2015 4:25 PM
Will your fire suppression plumbing be two inch or three inch diameter pipe?
Take another big hit of whatever you're smoking and us call back in the morning.
Good Answers: 181
12/07/2015 7:31 PM
"hopeful for help thank you"
Hope springs eternal, so they say.
12/08/2015 12:08 AM
What is ksi is it psi? More details are needed to suggest the right answer. Better call or consult pump manufacturer and hey will get required details from you and offer you right pump for the application.
12/08/2015 12:25 AM
ksi=1,000 psi.
Good Answers: 203
12/08/2015 12:19 AM
The absolutely first thing to do is to understand what you want and what you have to have to get it, reference #2.
Get, study and understand what the practical standards for sprinkler systems or whatever system you want need. Obtain your own copies of the following NFPA, National Fire Protection Association Standards (they are cheaper if you join the NFPA and purchase at least a year membership. Purchase a set of all the standards, available on CD or printed, since the cost of each of the 6 standards purchased individually will be more expensive than buying a whole set of all standards):
NFPA 13 Standard for the Installation of Sprinkler Systems
NFPA 14 Standard for the Installation of Standpipe and Hose Systems
NFPA 15 Standard for Water Spray Fixed Systems for Fire Protection
NFPA 20 Standard for the Installation of Stationary Pumps for Fire Protection
NFPA 22 Standard for Water Tanks for Private Fire Protection
NFPA 25 Standard for the Inspection, Testing, and Maintenance of Water-Based Fire Protection Systems
Identify what all your needs are first, study the standards and figure out what it is you need. Better yet, hire a licensed professional Fire Sprinkler designer, and have a licensed installer make and install it.
Fire is extremely dangerous, IT KILLS!
Good Luck, Old Salt
12/08/2015 12:29 AM
Are you sure this is a a fire application?
A pressure of 4ksi which I think is 4000psig (276barg) would require 2500# rated piping. My experience is for fire water systems on refineries and gas plants and similar. For those we only use 150# rated piping with a typical 5 bar required at hoses / monitors deluge systems
Also 276 barg equates to 2800m (9200ft) of head so even for a really tall building this seems a very high head. Pumps can be made to deliver this head but the motor size is prohibitive as noted above and its a very specialised pump to get this head.
Please check your details.
The flow rate 1800 USGPM (assumed) 400 m3/hr seems like it would need 8" or 10" piping which seems quite normal
Hendrik (1); lyn (2); mrswamy (1); old salt (1); PennPiper (1); PWSlack (3); simonsd (1); SolarEagle (1); TonyS (1); Tornado (1)
