Previous in Forum: Explosion Proof Certification for Luminaries   Next in Forum: Paralleled Generators' Loss of Load
35 comments
50HZ VS 60HZ
02/12/2016 1:23 AM
What happen to a bus duct with 50HZ if supplied by 60hz power?And the should output power be 60hZ??
Good Answers: 109
Re: 50HZ VS 60HZ
02/12/2016 1:44 AM
Ha, this is a trick question!
If there is 50 Hz on the duct and you supply 60Hz it will be 55 Hz as well as 50 Hz as well as 60 Hz, not? Not sure what it should be but usually if you replace 50 Hz and supply 60 Hz you will get ....
.... oh wait its coffee time. I'll come back later to see if you refined the question.....
Re: 50HZ VS 60HZ
02/12/2016 2:07 AM
Everything that branches off the bus will then run at 60Hz, unless there are VFDs or other frequency converters involved. Most AC motors will run 1.2 times as fast as on 50Hz.
Good Answers: 181
Re: 50HZ VS 60HZ
02/12/2016 4:26 AM
I've just tried superimposing 60Hz on to a 50Hz waveform.
I've got a headache now!
Good Answers: 26
Re: 50HZ VS 60HZ
02/12/2016 10:56 AM
Hertz dont it?
Re: 50HZ VS 60HZ
02/14/2016 5:54 AM
A U.S. transformer maker said to me "60 Cycles but 50 Hertz". Hmm!
Re: 50HZ VS 60HZ
02/12/2016 7:53 AM
The bus does not care which power distribution frequency gets applied to it. Depending on the nature of the load(s) attached to this bus the loads may work fine, burst into flames, or any of a number of other unpleasant scenarios.
Re: 50HZ VS 60HZ
02/12/2016 9:39 AM
The bus duct is simply a conductor. It cares not if you supply 60Hz or even military 400Hz. For that matter, it would be just fine and dandy with DC as well.
What about the equipment attached to said duct? Care to offer information on those devices?
Good Answers: 804
Re: 50HZ VS 60HZ
02/12/2016 10:44 AM
But it would need to be three phase DC, correct? ;-)
Re: 50HZ VS 60HZ
02/12/2016 10:50 AM
Not really - positive, common, and either a spare or ground. Or if we are working with OP amps we can have positive, ground, negative. Works for this argument.
Actually, the OP never did say it was 3 phase - we are just assuming that, which is the point - too little information once again.
Good Answers: 140
Re: 50HZ VS 60HZ
02/12/2016 12:38 PM
It was an attempt at humour.
Re: 50HZ VS 60HZ
02/12/2016 1:06 PM
Unfortunately, so were my poor responses.
Re: 50HZ VS 60HZ
02/12/2016 2:29 PM
do I hear a bid for 4 phase dc?????
Good Answers: 181
Re: 50HZ VS 60HZ
02/13/2016 6:08 AM
Seen it done. Separate 220V and 440V three wire systems with a common neutral.
They were supposed to be separate systems, somewhere in the mists of time the neutrals got connected together. It didn't cause problems and I couldn't be bothered to look for it.
Re: 50HZ VS 60HZ
02/16/2016 3:35 PM
Only on one side.
Good Answers: 128
Re: 50HZ VS 60HZ
02/15/2016 9:45 PM
Phys,
I have to disagree with you on this one. Although some could humorously argue that a bus duct doesn't care because an inanimate object can't have emotions, the users should care. As the frequency goes up from DC to 400Hz, the current flowing in the individual bus bars is increasingly forced onto the surface, instead of flowing equally throughout the entire cross-section of the conductor. This requires a decrease in the ampacity of the bus bars. This decrease is not uniformly proportional to the change in frequency, but depends in a complex manner on the cross section as well as the frequency. There are a few good articles that discuss this (unfortunately, I don't have their references right now). The 400/60 Hz ampacity ratio varies from 1.0 in very small conductors to less than 0.7 in large ones.
--JMM
Good Answers: 181
Re: 50HZ VS 60HZ
02/16/2016 8:02 AM
This may help http://chemandy.com/calculators/skin-effect-calculator.htm
Good Answers: 42
Re: 50HZ VS 60HZ
02/17/2016 9:47 PM
I agree with you : the busbar is a conductor. So, skin effect and proximity effect will be involved. The resistance will grow and so the losses. The temperature will rise. If it will be over the limits-it depends on insulators type, also-you have to oversize a bit.
Julius
Good Answers: 42
Re: 50HZ VS 60HZ
02/22/2016 8:47 AM
For skin and proximity effect see[for information]:
http://www.aluminum.org/sites/default/files/aecd13.pdf
[pages 13-12 up to 13-16]
Note: usually from 50 to 60 Hz the resistance increases with about 3-4%[so the losses do].
Julius
Re: 50HZ VS 60HZ
02/12/2016 3:42 PM
You will have to change the core material from Iron to Kryptonite, unless it powers a resistance heater.
Re: 50HZ VS 60HZ
02/12/2016 4:25 PM
I wonder what temperature and pressure would one need to make a crystallized noble gas?
Re: 50HZ VS 60HZ
02/15/2016 10:35 AM
really low and really high at the same time to make Krypton solid, a.k.a. Kyrptonite.
I really have no idea what to dissolve in it for the colors though. Perhaps red Kool-Aid, there seems to be plenty of that to go around these days.
Re: 50HZ VS 60HZ
02/22/2016 2:05 PM
I thought the GOP drank the red Kool-Aid, and the Democrats drank the blue? Did you mistype, did I mishear, or did you intend to slam the Republicans with that?
Re: 50HZ VS 60HZ
02/22/2016 3:49 PM
It was an allusion to red kryptonite. Usually all Kool-Aid being drank by whatever uninformed voter block (whether they vote for Dem or GOP) is red. Jonestown Kool-Aid was also red, as I recall, and Lemming Kool-Aid is also red.
Re: 50HZ VS 60HZ
02/23/2016 9:20 AM
Ah, I always thought the color was supposed to be a symbol for the ideology being consumed; GOP drinks Red, Dems, drink Blue, Eco-Terrorists drink Green, Trump supporters drink thick, black bile(1). Now I know better, people are ignoring the kool-aid color.
Notes:
  1. I WISH I was making a hyperbolic comment there as a joke, but when you listen to what he's saying, it's all so crude, offensive, and filled with utter hate, It's a wonder he gets away with it up on the debate stage. I heard on the news this morning that Trump is threatening the owners of the Chicago Cubs because they're "spending money against him," and the snippet of the e-mail read/paraphrased on the radio made it sound like classic blackmail: "...you don't want certain secrets to get out, do you?"
Good Answers: 804
Re: 50HZ VS 60HZ
02/12/2016 7:41 PM
Q: What's the difference between 50Hz DC and 60Hz DC?
Good Answers: 445
Re: 50HZ VS 60HZ
02/12/2016 9:31 PM
10Hz DC!!!
Re: 50HZ VS 60HZ
02/12/2016 9:53 PM
5Hz on each leg.
Good Answers: 445
Re: 50HZ VS 60HZ
02/12/2016 10:10 PM
That could hurt really badly...
Re: 50HZ VS 60HZ
02/13/2016 2:42 AM
Dear Friend,
You are not clear in your expression.
1. Do you have equal voltage.
2. Do you have same phase sequence
3. The following combination is possible.
a. Do you switch off 50 Hz. supply and switch on 60 Hz.
b. Do you switch on 60 Hz. supply while 50 Hz. supply is on.
Nett result - Short Circuit and fuse blow-up. happen.
Anonymous Poster #2
Re: 50HZ VS 60HZ
02/15/2016 9:39 AM
If you have 50Hz equipment and you are supplying 60Hz power, you may damage the equipment. This cannot me bade as a general call, as each piece of equipment needs to be looked at individually to see the results. A light bulb won't care, a motor will run faster (and possibly overheat) a PLC might release the Magic Blue Smoke and stop working altogether.
If you are connecting a 50Hz power supply and a 60Hz power supply to the same bus at the same time, then you are a dangerous idiot who should be fired immediately before you kill someone.
Re: 50HZ VS 60HZ
02/15/2016 10:38 AM
What did the 50Hz duck say to the 60Hz duck? Quack! If it looks like a duck, sounds like a duck, and smells like a duck, and even waddles like a duck, it must be a duck.
DUCK!
Re: 50HZ VS 60HZ
02/18/2016 1:19 AM
I am not an engineer, but the little bit of theory I learnt tells me if its a pure resistive device then frequency has no effect.
Re: 50HZ VS 60HZ
02/22/2016 2:01 PM
But IS it a pure resistive device? The OP hasn't told us yet.
We've only got part of the question so far, it's like trying to answer "What do you get when you cross - " Cross what with what?
All we know are "a power buss at 50Hz" and "a generator at 60Hz." We don't know what sort of load, we don't know if there is another 50Hz power source on the buss, we know just enough to make wild guesses, and ask leading questions to try and draw out more information, and the OP does not seem to be very forthcoming with the latter.
Re: 50HZ VS 60HZ
02/22/2016 2:38 PM
No, we can make all sorts of WAG on absolutely no information at all. Just look at all of the previous 32 replies.
Re: 50HZ VS 60HZ
02/18/2016 9:18 AM
One thing I can tell you for sure: There will not be 10Hz leaking off to one side so the bus can still run at 50 Hz. What planet are you from, once again please? Here on Earth, the frequency the power is supplied to the bus is equal to the frequency at the output side of the bus. If there are multiple frequencies, there is a problem, and usually it lets the smoke, fire escape from the conductors.
Reply to Forum Thread 35 comments
7anoter4 (2); adreasler (3); Anonymous Poster (1); dhayanandhan (1); eltech (1); IdeaSmith (1); James Stewart (4); jmueller (1); JRaef (2); lrsheldon (1); lyn (2); Munster (1); NeilA (1); North of 60 (1); Phys (3); RAMConsult (2); redfred (3); texasron (1); TonyS (3); Tornado (1)
