Previous in Forum: Permissible Tubesheet Construction from Plate Material   Next in Forum: 45*45 Elbows in Sewer
The Implosion Motor Based on the Clem Engine
04/09/2016 9:32 AM
Hi all,
This is the first test on this implosion motor based on the story of Richard Clem and Viktor Schauberger theories.
First test without pumping fluid into the upper centrifugal pump
Motor/pump test : 114.5V * 3.6A = 412.2 W
Second test pumping fluid into the upper centrifugal pump.
Motor/pump load: 115.7V * 2.89A = 334.4w
Extra energy gain of :412.2W -- 334.4W =77.8w due to centrifugal force implosion (Vacuum) effect.
First test run:
https://www.youtube.com/watch?v=ghTVMoPm1-Y
Second test run:
https://www.youtube.com/watch?v=juTqdkJVt9w
Tom
TommeyReed
This discussion was "closed" on 04/14/2016 8:00 AM. No new comments are allowed.
Message from admins:
Attacks on other users are not tolerated on CR4.
#89
In reply to #87
Find in discussion
Re: The Implosion Motor Based on the Clem Engine
04/12/2016 4:23 PM
I gave some basic numbers for the start of a debate, I'm still waiting on where these calculation are off.
Once we get past that stage, I will show where this extra energy is at.
Whats the difference between pumping fluid head pressure or pulling it the same direction?
None at all, in hydraulics you have a positive and negative pressure, my system work off the negative pressure created by rotating a mass of fluid and allowing to freely move outward at 90deg.
Does not look like many have experimented in this area at all, I would think by now someone would challenge my basic formulas even if it's not formula you're not use too.
Engineering they teach these complex numbers thinking your learning something, when in fact its a basics numbers to make your ego boost!
TommeyReed
In reply to #89
04/12/2016 5:22 PM
Pure gibberish.
#93
In reply to #91
04/12/2016 5:41 PM
Wait a second, did you not want some numbers. this is just the first parts.
I thought you where going to verify my formulas, before I explain where this energy is being created.
Tornado, what gibberish is it you can't do the math or what?
I know you all wanted me to play the engineer math skills, it's a joke to think that proves anything.
This is just as good and very simple even a caveman can do..
The extra energy is from centrifugal inertia that pulls fluid from the center outward at 90deg and creates a negative pressure at the same time.
Due to the fact it's not rotating in a pump housing, makes it even more efficient.
Yes it's a tornado oil spout that's being created, if the oil was heating up the viscosity would increase the flow adding more power output.
TOM.
TommeyReed
In reply to #93
04/12/2016 5:52 PM
No, I am not going to verify your formulas, because they are not verifiable.
The rest of your post is just word salad full of phrases that make no engineering or scientific sense.
#96
In reply to #94
04/12/2016 6:02 PM
So wait, I calculated thrust, speed and gpm and you wanted me to do it another way?
I seen this in collage also, they want you to use foolish numbers to make it harder for anyone not doing these classes, when it's a ego way of say it's to complex..
My number are correct, you can get your program out and just copy the basic specs if that makes it easy for you.
I'm starting to question your math skills, anyone can pull numbers from the internet, but my numbers are calculated in such a easy way that a cavemen could do it.
I have to question your own skills know.
Tom :-0
TommeyReed
In reply to #96
04/12/2016 7:18 PM
I don't doubt that you "seen [sic] this in collage [sic]". I went to college, too, and graduated Phi Beta Kappa and magna cum laude. I majored in math, studied physics, and am retired from over forty years of close work with designing, specifying, using, and maintaining pumps and other industrial-refrigeration-related equipment. And here you are trying to tell me I don't know stuff. So don't give me any guff about ego.
#101
In reply to #100
04/12/2016 7:26 PM
For someone who claims to know about pump, you can tell your students that, but i'm not your student so stop the ego pops!
The question is what have you learn, don't give me a history report of your life.
What patents do you have or the pumps did you design, being at your age you must have created something?
TommeyReed
In reply to #101
04/12/2016 7:43 PM
For instance, I have designed pumps built "from the ground up" out of plate formed into an Archimedean spiral and pipe sectors as impeller vanes welded to a shaft. Much more of my design work was in the form of sizing and selecting pumps and compressors, etc., for various duties; and also designing, building, and wiring UL-508 industrial control panels.
#95
In reply to #87
Find in discussion
04/12/2016 5:53 PM
First of all, the first test shows a constant load without the upper centrifugal pump connected.
The second test show a drop of input energy due to centrifugal inertia forces at work from the upper pump.
Even with the leaks and wrong hydraulic motor, you still see a drop of input energy.
Where is this energy being created, very simple take any flywheel and spin it at it's limit and what happens is it explodes.
But inside that mass, the atoms the hold the wlywheel together is being forced at a 90deg.
This same effect happens to liquid, instead of exploding it keeps pulling more fluid from the center outward.
Very simple to understand, and a real fact when you spin a flywheel.
Tom
TommeyReed
In reply to #95
04/12/2016 6:05 PM
I bet you can't tell us the formula for centripetal acceleration without looking it up. You haven't used it yet in any of your "calculations." And you are still using garbled mishmash phrases.
#104
In reply to #97
04/12/2016 8:01 PM
Second video showing the same set up, but now feed the output from the hydraulic motor into the upper vacuum cone.
https://www.youtube.com/watch?v=sYctoOGA6DY
Tom
TommeyReed
In reply to #95
04/12/2016 6:55 PM
Wrong, wrong, wrong!
You are simply, somehow reducing the load on the electric motor that drives the pump.
Do you have a pressure/flow gauge on your line?
I agree that you do not know what drives a tornado, too.
You are hopelessly in over your head and have produced nothing of any scientifically verifiable use.
While I am not a mathematician, I have been around pumps long enough to know what they will and will not do.
Again, your contraption produces no output!
Your overunity friends may fawn over your tinkered device and your DVM may wow them, but all of that impresses no one on this forum.
Facts. We're looking for facts.
#99
In reply to #98
04/12/2016 7:12 PM
https://www.youtube.com/watch?v=hKnAiVxfdNM
This video was the first load test while pumping fluid out of the lower pump and motor but not up in the centrifugal vacuum pump.
"While I am not a mathematician", I believe that one.
It's funny but if you know anything about pump, you have to know the mathematics also.
Any way this is the first load test pump fluid in the hydraulic pump/motor without the feed tube to the upper centrifugal vacuum pump.
TommeyReed
In reply to #99
04/12/2016 7:26 PM
You are completely delusional and ignorant. That is an honest observation and not intended as an insult, although you will no doubt think it is.
I keep hanging with your over-unity friends if I were you.
You'll never convince anyone here that you have any basis in fact in that useless contraption.
I'm finished wasting time here. <AMF>
#105
In reply to #102
04/12/2016 8:13 PM
CR4 ADMIN:
Please keep attacks and insults out of the discussion. Please review the CR4 Site FAQ and the CR4 Rules of Conduct.
danbuk
In reply to #105
04/12/2016 8:26 PM
You need to read the whole thread and figure out correctly who is insulting whom, how much, and how often.
#133
In reply to #106
04/13/2016 10:27 PM
Hit me once with a insult, and I hit back ten times.
Just what a bully would say when someone fights back. I only insulted once, but he insulted me ten times.
Please leave this form, cry babies are not welcome on my forum.
Have a great day, bye!
TommeyReed
In reply to #133
04/14/2016 3:21 AM
You are the only crybaby here.
#139
In reply to #135
04/14/2016 6:02 AM
CR4 Admin - Deleted Post
Personal attacks are not tolerated on CR4, and add nothing to the conversation.
TommeyReed
In reply to #139
04/14/2016 6:45 AM
Do you think God is on your side? You keep bringing up his name.
Good Answers: 70
#129
In reply to #105
04/13/2016 8:58 PM
Dan, we, (CR4 members) realize that you and other Moderators have better things to do than babysit CR4, but TommeyReed is completely out of control. If you read through the 3 different threads he makes claims "this is my site"? I didn't realize IHS sold CR4 to TommeyReed.
He is not only rude and obnoxious to all members of CR4, but he has also made threats of physical harm to members of CR4. I, myself, am not worried about him. But, in this day and age, is not the time nor funny to make threatening physical harm statements.
I'm sure the other senior members of CR4 would agree that it's time to close all of TommeyReed's Threads,
Richard Clem Engine
Restarting the Richard Clem Engine Project
I'm voting to close all 3 threads, I have more important things coming in my email than reading, as Lyn puts it, "delusional and ignorant" comments.
If anyone else agrees or disagrees, feel free to chime in.
Dan
In reply to #129
04/13/2016 9:36 PM
I can find no value in continuing this folly.
But then, I keep coming back to it, don't I.
Maybe we're the masochists. Or is it sadists? I don't know.
I find it ironic that the following quote, about Tommey Reed, was made on Aug. 7th 2013:
"He does not tolerate fools, and has no time for the endless revolving door of overunity claims made by people without data or evidence."
The Richard Clem Engine by Tommey Reed - Revolution ...
This thread reminds me of a rock opera:
Ever since I was a young boy
I've played the silver ball
From Soho down to Brighton
I must have played them all
But I ain't seen nothing like him
In any amusement hall
That deaf, dumb and blind kid
Sure plays a mean pinball
Always gets a replay
Never seen him fall
The Who
Good Answers: 70
#132
In reply to #130
04/13/2016 10:07 PM
That is toooo funny!!!!!!!!!
#108
In reply to #102
04/12/2016 8:33 PM
Bye bye, not a single data to back your own claims by the way.
I gave you numbers, but all I got from you was nothing but insults with words like delusional and ignorant.
Have you looked in the mirror lately?
Don't let the door hit you on the way out!
TommeyReed
In reply to #98
04/12/2016 8:28 PM
The reduced load is because there is reduced work being done, as you correctly point out.
Jim
#109
In reply to #107
04/12/2016 8:38 PM
What?
Are you blind, it's the same load on both test, the only different is the second test is connected to the upper vacuum chamber but still pumping the fluid from the lower pump.
It seem like I will have to redo these two video due to the fact nobody with eyes can see.
:-o
TommeyReed
In reply to #109
04/12/2016 8:44 PM
You have a vacuum, ergo;- reduced liquid flow, reduced work done, reduced energy required. You have the eyes and the hands on AND the advice of learned people, use them. Once you understand you will be able to put your superior intellect to good use to develop a new......
Jim
#111
In reply to #110
04/12/2016 8:54 PM
Again the vacuum is on the exit port of the output of the hydraulic motor, not the input of it..
What are you smoking, I explain in the past...
I would agree is a vacuum was in the pump input fluid, but it's not!
Motor rotates suck up fluid and pumps it in to a vacuum chamber, got it?
vacuum is created in the upper cone from rotation inertia, got it?
Talking about me with problems, boy looks like the other way around.
Jim, bye bye...clearly your on the wrong page in the forum..
TommeyReed
In reply to #111
04/12/2016 9:08 PM
Completely incoherent. Moreover, there are not enough gauges and meters in proper locations to tell much of anything about what is going on.
Have you specified whether the motors involved are AC or DC?
04/13/2016 1:10 AM
I went to look at the video of the second test, and YouTube says that the uploader has closed his account. Somebody is getting smarter by the minute.
#114
In reply to #113
04/13/2016 6:38 AM
CR4 ADMIN: Deleted Rude Remarks
Vulgar/Rude/Improper Behavior: This post was deleted because it did not adhere to the behavioral policies of the site. Please review Section 14 of the CR4 Site FAQ and the CR4 Rules of Conduct.
Let's start out with a pipe that is 18" long, now kids get the fingers out of your mouth.
The pipe is 0.25 id, now that's the inner diameter so pay attention.
When you drill a center tap say 0.25 and attach another pipe to it like the letter " T ", can we say " T " boys and girls?
Now lets go around in circle, yes but not in the play ground yet.
We are going to spin this " T " at a rate of 1000 rpm, like running in a circle, but very fast.
TommeyReed
In reply to #114
04/13/2016 6:51 AM
First of all - it's you're too blind (a contraction for you are) - not "your". Secondly you keep insulting the intelligence of forum members. Just GO !!!!!!
#118
In reply to #115
04/13/2016 7:12 AM
CR4 ADMIN: Deleted Post
TommeyReed
In reply to #118
04/13/2016 7:29 AM
That still didn't answer any questions of an engineering nature that have been asked. Instead, you resort to juvenile playground insults, because that's all you have.
#120
In reply to #119
04/13/2016 8:00 AM
First of all this forum is about the Clem engine, not my ego or anyone else.
I don't play to be a engineer with fancy numbers to make me look smart, that a joke and you know it.
I gave simple calculation that most can understand, boy was I wrong.
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
Albert Einstein!
TommeyReed
In reply to #120
04/13/2016 8:08 AM
You are still not addressing any engineering topics, only making mistakes and spouting insults. Engineering is not about playing with fancy numbers to make one look smart. Your comments are illiterate, innumerate, and devoid of understanding.
In reply to #114
04/13/2016 6:57 AM
More irrelevant drivel. I have been a journeyman pipefitter, so telling me about pipe is ridiculous.
#117
In reply to #116
04/13/2016 7:04 AM
TommeyReed
04/13/2016 6:13 PM
Did Tommey implode?
In reply to #124
04/13/2016 6:28 PM
Perhaps the weirdest thing is that nothing we have seen so far about this alleged engine constitutes an implosion in the first place. But then, this guy has lots of spelling, vocabulary, and phrasing issues.
In reply to #125
04/13/2016 6:39 PM
For me, the weirdest thing is that he would actually come back a THIRD TIME, with nothing new to add after be so soundly rejected as a fake the first two times he was here.
He seems to have plenty of "admirers" in the over-unity community.
In reply to #124
04/13/2016 6:37 PM
Explode --- hopefully.
#131
In reply to #126
04/13/2016 10:04 PM
Wow what babies, If you look back at the past few years who started the insults first?
All you have to do is go on a different forum, I have no problem debating.
Most of you know it's all fun and games at the end, I think it's funny when some of you take it personal.
But there are time when some are just bullies, well I can bully back fools.
Over all I posted this to have my own forum, you can all leave if you want.
I will update on my research, and if I get it running to a point I will post it here.
Remember bullies can't push me around, so be nice and I will also.
have a good day.
TommeyReed
Anonymous Poster (7); aurizon (1); danbuk (1); dj95401 (9); energyconversion (2); JIMRAT (3); justajo (1); LakeGrl (1); lyn (17); marcot (1); nick name (5); Peterpipper (5); PWSlack (1); RAMConsult (2); Rixter (2); SolarEagle (2); tcmtech (1); Tom_Consulting (1); TommeyReed (49); TonyS (1); Tornado (31)
