Previous in Forum: Earth Tag Wiring   Next in Forum: Earthing Current Limiting
10 comments
Sag of Overhead Line
04/10/2016 8:48 PM
The sag of overhead line is the distance from the centre to the support.it varies where is sag macimum
Re: sag of overheadline
04/10/2016 9:09 PM
Where do you think the minimum sag point will be? Where should it logically be?
An online search of "conductor sag" produced over 400,000 results (including the math) for your further education. Enjoy.
04/10/2016 9:31 PM
What exactly is your point of catenary sag
http://www.spaceagecontrol.com/calccabl.htm
04/10/2016 9:53 PM
Sag is always a problem.
04/10/2016 11:42 PM
A little sag is necessary when it comes to overhead line construction and operation, less so for other things.
04/10/2016 11:49 PM
Lack of sag can be an even worse problem in power lines, such as if they break or pull poles over.
The term "maximum sag" can have at least three different definitions, none of them matching that of the OP.
Good Answers: 181
04/11/2016 1:40 AM
Your local pharmacist may be able to help.
Good Answers: 804
04/11/2016 7:05 PM
"Your local pharmacist may be able to help"
LOL! I got it...
There are numerous other similar directions that could have gone as well, especially for women...
"Sag happens".
04/11/2016 7:08 AM
Not all the time,... some designs incorporated catenary sag in its designs as a natural tensioner.
Center Drive conveyors is one that comes to mind where catenary sag is used as the conveyor belt tensioner.
Re: Sag of Overhead Line
04/11/2016 2:51 AM
Y=A.cosh(x)
04/22/2016 6:24 AM
S=W*L2/8T
S=W*L (squared) /8T
W=weight of conductor
L= span length x span length
T= Tension.
Register to Reply 10 comments
IQ (1); jack of all trades (2); JRaef (1); lyn (1); phoenix911 (2); PWSlack (1); TonyS (1); Tornado (1)
