Previous in Forum: Flushing and Cleaning of Cooling Medium System   Next in Forum: Trajectory of a laser beam
15 comments
Location: South Range of Michigan's U.P. or known as da U.P.
“MORE INFO, PLEASE!”
08/16/2007 5:01 PM
8/16/07
Dear Knowledgeable Engineers,
Hello, can a person that is curious as to how a telescoping robotic arm (similar to a transistor radio antenna) or flexible device (60 or so inches) and/or unit build one. Of course that unit needs to be programmed to meet my specifications. Maybe a radio controlled unit or one that is able to comprehend what a computer is programming into the device or contraption. Can you inform me of where I could get the instructions to make it? If not, then whom could I ask to manufacture this robotic arm?
This robotic arm needs to be unsupported in reaching its destination. (No supports or supporting systems) When it leaves its home station, totally independent from everything and attaches its grabbing device onto its object it is after. That object applies resistance along its whole distance traveled but not too much. Despite the resistance, it returns to its home station with no supports guiding it along its mission.
I really appreciate the time that you spent answering my question and I just ignore the foolish answers. Every now and again there is a worthy response for me to investigate.
Sincerely, Louie
ldepuydt@charter.net
Good Answers: 53
Re: “MORE INFO, PLEASE!”
08/17/2007 1:14 AM
Is this arm intended to be used within a gravitational field?
08/18/2007 4:25 PM
NO
Good Answers: 97
08/17/2007 2:17 AM
You are in CNC and robotics.
Try google for "Robotics" and you will find dedicated groups. They have tried it all and would have some designs ready.
I think one robotics site falls under GlobalSpec - but it was a while back.
Good Answers: 32
08/18/2007 12:21 AM
If you use series of linear motors then it is possible to build such device. You can also push through pneumatic pressure and pull back through wire and small motor. Remember that length will also cause problem and motors placed at far distance will be a serious problem.
Another good mechanism is screw in a screw. Last thing first and then next. Look to Telescopic Antenna that are motorized. Perhaps a spring can also push and pull the rod from inside the telescopic rod.
You have to have some good mechanical idea for doing all this.
Good Answers: 50
08/18/2007 12:32 AM
OK, a couple of questions back at you.
  1. Does the arm (or whatever) telescope (extend) from a base unit, grab an object and then retract to deliver the object?
  2. Or do you intend this device to have its own movable base, navigate to a location, extend to grab the object, retract, and, finally, navigate its way back to you?
  3. Are you in a wheelchair or otherwise handicapped?
It would be very helpful to know the complete story regarding why you want this device. What type of terrain? Through different passages/rooms? Does it need to see or do you need to see what it sees? Is this just an industrial device? All of these questions drastically affect the design. We can shoot in the dark, but it's easier when the lights are turned on.
If you are unwilling to give us these details, that's OK. However, you would probably be much more successful Goggling robotic sites that can supply information, and you can pick and choose what fits your needs in private.
08/18/2007 12:36 AM
A long thinwalled strong Bamboo sliding thru 2 loose-fit bamboo bushes.
At fore tip end have a snap-action mechanism under ready-to-act springs' pressure.
Trip this small hinged holdback detent from backend passing thru bamboo. Nylon string?
And the snake you catch would go nowhere but back at your control!
Total price DIY =<$1
Good Answers: 32
08/18/2007 12:46 AM
Great. In my childhood I bought that snake thing which extends and contracts easily and was hardly of any price. I also like that bamboo rod idea.
How come you talk so much about bamboo?
Good Answers: 50
08/18/2007 12:56 AM
Now he said no silliness!!!
08/18/2007 12:07 PM
Denso has an excellent selection of robots. They are used for placement of computer components on boards to placing 10 lb stacks of lead plates in auto batteries. I do not understand your application, but your gripper or other end of arm tooling may cause you problems. If you just want a single linear motion, you might check on a linear servo, but you will have to use some type of guide rod since it uses a screw motion to move in and out and the rod end of the servo needs a stationary point to work. They are very fast, precise, and robust.
08/18/2007 12:24 PM
Thanks for giving me more things to research!
08/19/2007 11:45 PM
Dear Gerard,
I am calling the banks, pharmacies and jewelers in your area. Me thinks me smells a rat.
Good Answers: 94
08/20/2007 4:34 AM
I can remember seeing somewhere an extending arm made from a strip of thin steel formed into a semicircular shape, something like a steel tape measure but with a deeper formed section. It was self supporting over a long distance but retracted back into a small roll. I can't recall the name or where I saw it, can anyone else help?
Good Answers: 32
08/20/2007 6:01 AM
I think you are refering to snake arm robot.
Good Answers: 94
08/20/2007 6:28 AM
No that's not it, it was nowhere near as sophisticated as the snake arm & not steerable.
Good Answers: 32
08/20/2007 7:47 AM
Roboarm was a nice development but it is no longer produced now. I think inventor closed the production long ago. They were really nice thing. I used them for a training class in Singapore. It was having five axis stepper motors and a gripper.
Register to Reply 15 comments
Ace Boeringa (1); Anonymous Poster (2); GERARD18 (2); Hendrik (1); MUKULMAHANT (1); Nigh (2); Shyam (4); vermin (2)
You might be interested in: Robotic Tool Changers, Robotic Deburring Tools
