Previous in Forum: Where Are They Now? NASA's New Horizons Spacecraft   Next in Forum: When I Was Younger I Wish That I Had...
Powerful Changing Magnetic Field Generator - Can It Influence Human Cells Activity?
02/01/2018 6:32 AM
Can changing magnetic field generated by a spinning neodymium sphere 26mm diameter (high RPM's) influence human body cells activity?
setups : 3 V - DC motor, 26mm neo sphere (Article ID K-26-C Material NdFeB Shape Sphere Diameter 26 mm Tolerance +/- 0,1 mm Coating Chrome-plated (Ni-Cu-Ni-Cr) Manufacturing method sintered Magnetisation N38 strength approx. 9,1 kg (approx. 89,2 N) Max. working temperature 80°C Weight 69,9410 g Curie temperature 310 °C Residual magnetism Br 12200-12600 G, 1.22-1.26 T Coercive field strength bHc 10.8-11.5 kOe, 860-915 kA/m Coercive field strength iHc ≥12 kOe, ≥955 kA/m Energy product (BxH)max 36-38 MGOe, 287-303 kJ/m³), special screw pot metal case 13 mm fixed on the neo sphere between the magnetic poles N-S) , usb cable, external battery.
magnetic field : CHANGING magnetic field
category : ABSTRACT
An electric change occurring when a magnetic field is applied to the human body
magnetic fields induce circulating currents within the human body. The strength of these currents depends on the intensity of the outside magnetic field.
A human body can generate between 10 and 100 millivolts.
answers so far :
1."The broad answer is that, yes, magnetic fields can alter the electrical activity of cells. This is the basis of a technique called TMS - transcranial magnetic stimulation, whereby a powerful magnetic source is held above the scalp. It can influence the behaviour of brain regions below the magnetic wand, inhibiting some areas and facilitating activity in others."
2."Yes because the rotating magnetic field will generate microcurrents in the cell which is conductive to water,salts,etc.
look up microcurrents in google"
3."Yes a magnetic field can influence the body. How and to what postive or negative influences and levels are however undefinable at this level of resolution."
4."Externally applied EM fields obviousy can affect body cells. How else would NMR scans work?"
What is your opinion about this ?
Pathfinder Tags: changing magnetic field generator X device
User-tagged by 3 users
#107
In reply to #106
Find in discussion
Re: Powerful Changing Magnetic Field Generator
02/14/2018 1:41 PM
Rmf device effects:
1. analgesic effect
2. more energy for the body...
3. accelerates human body proceses.
no placebo effect....just science after all we are on an engineering forum not in a church.
Nihil sine Deo
I will open another thread probably.....named "pulse motor generator (PMG)" powered with mini solar panels so I will apreciate if nobody will compare it with free energy, overunity, aliens, Decebal, Dracula, Elvis, we are on an engineering forum so those words are not suitable here....(nothing is free but it can be pushed to the limits) except rmf device....because x sound like....ok guys if the name is the problem rmf device.....or you an choose one ;)
thx st
In reply to #107
02/14/2018 5:30 PM
Where is the data that proves any of this??
#102
In reply to #92
Find in discussion
02/12/2018 5:03 PM
who said somethimg about healing ? .....hmmm
In reply to #102
02/15/2018 12:57 PM
I taught my dog to heel. It was a miracle.
#110
In reply to #109
02/17/2018 2:44 PM
funny... jpfalt very funny, are you from England ?
In reply to #110
02/17/2018 3:53 PM
You are the one that is funny........
In reply to #110
02/19/2018 11:30 AM
No, I'm from Oh-Ree-Gone. Beautiful country...demented politics.
In reply to #71
Find in discussion
Re: Powerful Changing Magnetic Field Generator - Can It Influence Human Cells Activity?
02/07/2018 1:56 PM
Plausible. The biological activity is based on proteins, enzymes, amino acids, etc. going to a local site and attaching to something. The attachments are chemical and thus electrical charge based. Adding a magnetic field and the resulting electrical eddy currents could either enhance or inhibit a specific site attachment or change the availability of the chemical that the site receives. That could either enhance or inhibit the activity of the tissue or a pathogen.
Similar type concerns occur in zero gravity. Having a site attach a chemical changes the specific gravity of the cell fluid and causes natural circulation that replenishes the chemical. In zero gravity, there is no natural circulation and once the local area is depleted of a particular chemical, that reaction stops, because it has run out of the chemical needed for the activity.
I am also aware that the electric pain blockers, nerve stimulators and muscle stimulators they sell these days use a balanced AC voltage to avoid electrolysis of the skin and tissues surrounding the electrical contact pads.
02/07/2018 6:08 AM
02/07/2018 6:54 AM
I say that x device is produce a RMF. ( rotating magnetic field)
(Rotating magnetic field (RMF) means rotation of polarities. If we have a magnet of which the two opposite poles of that magnet will move around an central axis with an constant angular acceleration then the outer magnetic field will also continues to vary)
Agree ?
#82
02/07/2018 12:41 PM
at the end of this I wish to know Who scored me out of topic ? ;)))) I deserved to know :))))) in the begining of the post....(just joking)
#97
02/12/2018 11:40 AM
Related research :
1. Application of Rotating Magnetic Fields Increase the Activity of Antimicrobials Against Wound Biofilm Pathogens
A. F. Junka, R. Rakoczy, P. Szymczyk, M. Bartoszewicz, P. P. Sedghizadeh & K. Fijałkowski
2. Biologic Effects of Environmental Electromagnetism (pages 78,79)
De H. L. König,A. P. Krüger,S. Lang,W. Sönning
3. Effects of rotating magnetic field exposure on the functional parameters of different species of bacteria.
Fijałkowski K1, Nawrotek P, Struk M, Kordas M, Rakoczy R.
4. ROTATING MAGNETS PRODUCE A PROMPT
ANALGESIA EFFECT IN RATS
Zhong Chen1, *, Hui Ye2
, Haiyun Xu3
, Shukang An1
Anmin Jin1
, Chusong Zhou1
, and Shaoan Yang1
1Department of Spinal Surgery, Southern Medical University, Zhujiang
Hospital, GuangZhou 510282, China
2Department of Biology, Loyola University, Chicago, IL 60660, US
3Department of Anatomy, Medical College, Shantou University,
Guangdong 515041, China
It is just a " spinning magnet" but a apecial one.....
st
#113
07/11/2019 10:12 AM
#114
07/31/2019 9:43 AM
"Rotating Magnets Produce a Prompt Analgesia Effect in Rats "
"Our results demonstrated that rotating magnets produce analgesia effect in rats. This analgesia effect is likely due to the electric current induced by the time-varying RMF. The induced-current may depolarize or hyperpolarize the axonal membrane, thus blocks the conduction of action potential along axons. The electric field parallel to the axons has been shown to be the most effective in affecting the axonal membrane potential"
China.
artsmith (11); BestInShow (1); Codemaster (3); Hannes (1); jack of all trades (10); JE in Chicago (5); Jpfalt (13); JPool (13); PWSlack (4); Rixter (2); sciencetoolbar (51)
