Previous in Forum: Fly on a football problem.   Next in Forum: Auto Level Surface
18 comments
SIL FOS Silver Solder???
09/23/2007 2:15 PM
Very nice site here,,
I got a truck bed tool box,, the man said it had a lot of junk in it and he didn't have the time to clean it out. I paid $20 for it,, Plastic. Well it had 20lbs of silver solder in it. I know a little about it. I can't find how much it's worth. I don't need it. I have a fiend he said it may be worth around 800 dollars. I think it's 15% silver.
It's,,,,,
SIL FOS
.003 X 1.000 X 20lbs
Alloy 71--150 SIL FOS
.0030 X 1.000
What does the Alloy 71--150 SIL FOS mean. I know it's probably the chemical make up of the solder.
Thanks for the help,, Joey
Re: SIL FOS Silver Solder???
09/23/2007 11:14 PM
Find a comercial mechanical contractor. or a plumber.
Illegitimi non Carborundum.
09/23/2007 11:37 PM
Check eBay for Sil Fos auctions.
You will be pleasantly surprised. $$/Lb!
Good Answers: 50
09/24/2007 1:14 AM
For the silver content, if it is 15% silver, you're looking more at about $450.00 tops right now.
09/24/2007 3:01 AM
I believe silver solder is usually closer to 100% silver. In electronics is is typically ~97 to 99%. I don't know about plumbing but I'm not sure what else would be in it because it isn't going to have any lead in it.
Good Answers: 50
09/25/2007 12:07 AM
From what I've seen, silver solder is used in other things than electronics (usually jewelery). It has a higher melting point than regular tin-lead solder, and the surfaces to be soldered have to be flushed with an acidic pickling agent.
09/25/2007 3:47 AM
The higher melting point is sometimes a reason silver is used. Not so in electronics. The only reason for the switch is to get the lead out and the higher processing temperatures have presented a challenge to the industry.
It looks like what this guy has is more what I would think of as brazing rod but it is really out of my field so I am unfamiliar with common terminology.
09/25/2007 11:07 AM
"I believe silver solder is usually closer to 100% silver."
First you have to keep in mind that there is a definitive difference between soldering and brazing. In a nutshell it's brazing if the filler melts above 800F and soldering if the filler melts below 800F.
A common silver bearing solder like "StayBrite" has around 5% silver with the bulk being tin; these types of solders melt at about 430F give or take a little. Many silver bearing braze fillers are silver and copper in various amounts with all other stuff tossed in based on the application but basically have a mix of high to mid melting metals like zinc, copper, nickel. Silver bearing solders use lower melt things like tin, antinomy, lead.
I think for electronics there are a wide variety of solders but I don't know how common it is to use high silver content filler due to the high temps needed. Pure silver melts at 1761F and Sterling melts at 1640F. I don't think it's too often that one wants to subject electronics assemblies to those kind of heats even with the small amount of silver being melted
As for what to do with the SilFos, which is a nice cadmium free braze filler that uses phosphorus instead, I would sell it on CraigsList or ebay. FYI, McMaster-Carr sells SilFos type stuff: $80 gets you 50 20"x1/16" rods.
I wasn't here that day.
09/25/2007 10:26 PM
Thanks for the clarification between what constitutes brazing vs. soldering.
Clearly I don't know what I was thinking when I said what I said about electronic grade solder. The new lead free electronic grade solders are typically mostly tin with some silver and copper and who knows what else to distinguish brand A from brand B.
09/24/2007 3:48 AM
Nice find, check the current price if silver solder, reckon to get maybe 65% of that, maybe a tad less......
Advertise on ebay in the right section....clean well first.
09/24/2007 4:32 AM
Don't let 'Stinky Pete' find out about it!
09/24/2007 5:56 AM
You can do 2 things:
#1 Hold on till I come -I shall take over from you--I will buy you a steak
#2 Make adeal with this English Company:
at cupalloys@hotmail.co.uk
Prices for silver solder 842 which include P&P
No delivery charges - No VAT
Nothing more to add
1.0mm dia x 500
5 rods £ 8.30
10 rods £13.30
25 rods £28.50
50 rods £53.90
1.5mm dia x 500
5 rods £10.10
10 rods £17.90
25 rods £40.30
50 rods £77.40
2.0mm dia x 500
5 rods £22.30
10 rods £41.10
25 rods £98.00
2.5mm dia x 500
5 rods £33.30
10 rods £63.50
25 rods £155.70
Wire 0.5mm x 1m
£ 3.10 per metre
Wire 0.7mm dia x 1m
£ 3.60 per metre
Paste
£ 7.40 per 10gm
Prices for silver solder 840 which include P&P
09/24/2007 6:27 AM
Wow, good infos, therefore our friend has found a veritable Gold (sorry Silver)Mine!!!
09/24/2007 7:23 AM
nice find troutdog
We recently bought some Sil fos 15 I don't remember the exact price but I believe it was somewhere around 40 U.S dollars for a one pound tube. We use it for repair and fabrication of copper and brass weldments. We purchased it from our supply house but any welding supplier has it.
Good Answers: 58
09/24/2007 8:00 AM
My guess is that you have Sil-Fos which is 15% silver-80% copper-5% phosphorous. It is commonly used in the HVAC business. There are other Sil-Fos alloys, but I think this is the only one ductile enough to be rolled into strip form. You might find a retail customer for it on ebay, but with tracability so important these days, I'd sell it for scrap.
09/24/2007 10:46 AM
Electric motor shops use this material to make lead connections. If you have a local motor shop near by they will likely buy it from you slightly below retail.
Good luck,
Drew
09/24/2007 11:08 AM
Silver-Copper-Phosphorus Alloys
Material Safety Data Sheet
1. Product And Company Identification
Supplier
Lucas Milhaupt, Inc. Handy & Harman of Canada, Ltd.
5656 South
Pennsylvania Ave. 290 Carlingview Drive
Cudahy, WI 53110 Rexdale, ON M9W 5G1
Supplier Emergency Contacts & Phone Number
Lucas-Milhaupt, Inc.: 414-769-6000
Handy & Harman of Canada, Limited: 416-675-1860
Manufacturer
5656 South
Manufacturer Emergency Contacts & Phone Number
Issue Date: 04/30/2007
Product Name: Silver-Copper-Phosphorus Alloys
CAS Number: Not Established
MSDS Number: 77
Product Identification Text
This MSDS is applicable to the following products (with respective product codes): Consil 996 (15-996); Sil-Fos 1, Sil-Fos (71-150); Sil-Fos 15 (67-150);
Sil-Fos 2 (71-020); Sil-Fos 2M (71-017); Sil-Fos 5 (71-050); Sil-Fos 5F (71-
052); Sil-Fos 6 (71-060, 71-061); Sil-Fos 6M (71-062); Sil-Fos 6i (71-063);
Sil-Fos 10 (71-100); Sil-Fos 18 (71-180); Sil Fos 18M (71-181); 21-015 and 24-
863.
2. Composition/Information On Ingredients
Ingredient Name - (CAS Number) - %
Copper (7440-50-8) 0.2 - 92.6
Phosphorus (7723-14-0) 0.01 - 7.25
Silver (7440-22-4) 0.9 - 99.8
No Data Available...
3. Hazards Identification
Primary Routes(s) Of Entry
Ingestion; inhalation
Eye Hazards
Eye contact with these products in finely-divided forms may cause irritation, conjunctivitis, ulceration of the cornea, and/or argyria, a permanent blue-gray discoloration of the eyes, skin, mucous membranes, and respiratory tract.
Skin Hazards
Skin contact with these products, particularly in finely-divided forms, may cause irritation, argyria, discoloration, and/or contact dermatitis.
Ingestion Hazards
Ingestion of these products in finely-divided forms may cause nausea, vomiting, and gastrointestinal irritation.
Inhalation Hazards
Inhalation of the components of these products is not known to present a significant risk to health when used according to instructions and with appropriate protective measures (see Section #8). Inhalation of component elements has been reported to cause one or more of the following symptoms and effects upon excessively high or prolonged exposure:
COPPER: Acute exposure may cause respiratory tract irritation, fever, muscle ache, chills, cough, weakness, and a metallic taste. Chronic exposure may damage the liver, kidney, spleen, pancreas, and brain.
PHOSPHORUS: The red form of phosphorus is stable and relatively non-toxic at room temperature. When heated in the presence of air, it is converted to phosphorus pentoxide, which is corrosive and irritating to the eyes, nose, throat, and mucous membranes.
SILVER: Chronic exposure via inhalation may cause argyria.
4. First Aid Measures
Eye
Flush affected areas with water for at least fifteen minutes. Seek medical assistance if necessary.
Skin
Remove contaminated clothing. Wash affected area with large quantities of water for at least five minutes. Seek medical attention if necessary. Launder or dry-clean clothing before reuse.
Ingestion
If subject is conscious, induce vomiting. If unconscious or convulsive, seek immediate medical assistance.
Inhalation
If signs and symptoms of toxicity are observed, remove subject from area, administer oxygen, and seek medical attention. Keep the subject warm and at rest. Perform artificial respiration if breathing has stopped.
Note To Physician
None of the components are acutely toxic by ingestion, nor are they absorbed through the skin. Extensive or prolonged skin contact may cause dermatitis and/or argyria.
5. Fire Fighting Measures
Flash Point: N/A °F N/A °C
Autoignition Point: N/A °F N/A °C
Flammability Class: N/A
Lower Explosive Limit: N/A
Upper Explosive Limit: N/A
Fire And Explosion Hazards
In finely-divided form, these products may ignite when exposed to flame or by reaction with incompatible materials (see Section #10). If present in a fire or explosion, they may emit fumes of the constituent metals, metal oxides, and/or phosphorus pentoxide.
Extinguishing Media
Use dry chemical. Do not use water.
Fire Fighting Instructions
If fighting a fire in which these products are present, wear a self-contained breathing apparatus with full facepiece operated in pressure-demand or other positive pressure mode.
6. Accidental Release Measures
If a finely-divided form of product is spilled, clean up spillage so as to minimize dispersion of dust. Wet sweeping or vacuuming using HEPA filtration are recommended.
7. Handling And Storage
Handling Precautions
No special handling precautions are required.
Storage Precautions
Do not store in proximity to incompatible materials (see Section #10).
Work/Hygienic Practices
To minimize ingestion, wash hands and face before eating, drinking, applying cosmetics, or using tobacco.
8. Exposure Controls/Personal Protection
Engineering Controls
Use appropriate ventilation (e.g., dilution, local exhaust) adequate to maintain concentrations of all components to within their applicable standards.
Eye/Face Protection
Wear eye protection adequate to prevent eye contact with finely-divided product and eye injury if products are used with a flame. Plastic-frame spectacles with side shields and filter lenses (shade #3 or #4) are recommended.
Skin Protection
Wear appropriate protective gloves and clothing to prevent skin injury if these products are used with a flame and/or for prolonged or repeated contact with finely-divided forms of product. Avoid flammable fabrics.
Respiratory Protection
If an exposure level exceeds an applicable exposure standard, use a NIOSH-approved respirator having a configuration (type of facepiece, filter media, assigned protection factor, etc.) appropriate to the concentration of the
contaminant(s) generated. For guidance on selection and use of respiratory protection, consult American National Standard Z88.2 (ANSI, New York, NY 10036
USA).
Ingredient(s) - Exposure Limits
Copper
ACGIH TLVs: 0.2 mg/m3 TWA (fume); 1 mg/m3 TWA (dusts and mists)
OSHA PELs: 0.1 mg/m3 TWA (fume); 1 mg/m3 TWA (dusts and mists)
Phosphorus
No applicable ACGIH TLV(s) No applicable OSHA PEL(s)
Silver
ACGIH TLV: 0.1 mg/m3 TWA (metal) OSHA PEL: 0.01 mg/m3 TWA
9. Physical And Chemical Properties
Appearance
Odorless light-copper metals in form of wire, rod, strip, powder, tape, grain, or preformed shapes.
Chemical Type: Mixture
Physical State: Solid
Melting Point: >1190 °F >645 °C
Specific Gravity: 7.8 - 10.5
Percent Volatiles: Not Applicable (N/A)
Vapor Pressure: N/A
Vapor Density: N/A
pH Factor: N/A
Solubility: Insoluble
10. Stability And Reactivity
Stability: stable
Hazardous Polymerization: will not occur
Conditions To Avoid (Stability)
Silver and copper can form unstable acetylides if in contact with acetylene gas.
Incompatible Materials
Strong oxidizers; ammonia; azides; nitric acid; ethylene imine; chlorine trifluoride; sulfuric acid; inorganic and organic peroxides; peroxyformic acid; oxalic acid; tartaric acid; 1-bromo-2-propyne; permonosulfuric acid; bromates, chlorates, and iodates of alkali and alkali earth metals; alkaline hydroxides.
Hazardous Decomposition Products
Heating to elevated temperatures may liberate metal/metal oxide fumes and/or phosphorus pentoxide.
11. Toxicological Information
Chronic/Carcinogenicity
The products contain no chemicals classified as potential or demonstrated carcinogens by IARC, NTP, or OSHA.
Conditions Aggravated By Overexposure
Pre-existing pulmonary diseases (e.g., bronchitis, asthma) may be aggravated by inhalation overexposure, particularly as fume. Chronic overexposure by inhalation and/or ingestion may aggravate pre-existing diseases of the liver, kidneys, gastrointestinal system, and nervous system.
Ingredient(s) - Toxicological Data
Copper
LD50: No data available LC50: No data available
Phosphorus
LD50: >15,000 mg/kg (oral/rat) LC50: 4,300 mg/m3 for 1 hr (rat)
Silver
LD50: >2000 mg/kg (oral/rat) LC50: No data available
12. Ecological Information
In their intended manner of use, these products should not be released into the environment, and adverse effects on ecosystems are not anticipated under recommended conditions of use, storage, and disposal.
13. Disposal Considerations
Dispose of unused or unusable product in accordance with applicable Federal, State/Provincial, and local regulations.
14. Transport Information
These products are not Hazardous Substances or Dangerous Goods per USDOT, TDG (Canada), IATA, or IMO regulations.
15. Regulatory Information
SARA Hazard Classes
Acute Health Hazard; Chronic Health Hazard
Ingredient(s) - U.S. Regulatory Information
Copper
SARA Title III - Section 313 Form "R"/TRI Reportable Chemical
Phosphorus
Silver
Canadian Regulatory Information
WHMIS Class(es) and Division(s): none applicable
Components on Ingredients Disclosure List:
1. Copper, elemental (CASRN 7440-50-8)
2. Phosphorus (CASRN 7723-14-0)
3. Silver, elemental (CASRN 7440-22-4)
16. Other Information
Revision/Preparer Information
This MSDS Supersedes A Previous MSDS Dated: 04/29/2004
Disclaimer
Although reasonable care has been taken in the preparation of this document,
we extend no warranties and make no representations as to the accuracy or completeness of the information contained therein, and assume no responsibility regarding the suitability of this information for the user's intended purposes or for the consequences of its use. Each individual should make a determination as to the suitability of the information for their particular purpose(s).
09/27/2007 12:14 AM
Hi Joey Silfos /ASilver solder is used mainly in the HVAC and Plumbing industries for braising copper pipe. I would offer ring around your major plumbing and HVAC installers and see what you can get. I think $800.00 is a bit optomistic but then I havent bought any for years
"Multa ferunt anni venientes commoda secum, Multa recedente adimiunt". (The years as they come bring many agreeable things with them; As they go they take many away).
09/27/2007 6:17 PM
Thanks all,, I'll probably put it on ebay soon.
Register to Reply 18 comments
Andy Germany (2); Anonymous Poster (2); benemy (1); bsf (1); coconutpete (1); MechTech Gid (1); MUKULMAHANT (1); PWSlack (1); rcapper (3); Stirling Stan (1); troutdog (1); vermin (2); welderman (1)
